Author Topic: Wingnut Wings 1:32 LVG C.VI  (Read 55964 times)
Re: Wingnut Wings 1:32 LVG C.VI
« Reply #60 on: September 14, 2018, 02:27:34 AM »
No micro-vacuum cleaner I am afraid Lance. The leather of the seats and wood finish are completely realistic - wonderful finish. I especially like the wear pattern on the pilot's seat.
« Reply #61 on: September 14, 2018, 03:26:48 AM »
Truly superb interior, Lance!  Your detail work is absolutely brilliant.  I'm really enjoying watching this one come together.
« Reply #62 on: September 14, 2018, 06:32:08 AM »
Thanks Stephen and Bud,
     I used Tamiya's Weathering Master Oil Pastel Packs (Soot and Mud) for the wear effects on the leather seat. The lozenge application is now slowly underway, I'll log some more photos when that's complete.
« Reply #63 on: September 15, 2018, 06:04:04 AM »
Lance, to view your work is always a great pleasure!
Ha, the same on my side, really time consuming :(
« Reply #64 on: September 17, 2018, 07:47:38 AM »
Interior looks great Lance.  I am especially drawn to the cableing that you did for the throttle and fuel mixtures, very nice and perks up that part of the model.  I will have to review this when I tackle my next LVG.  Get ready for some real modeling excitement as you enter the lozenge stage.  It's too bad there isn't a "cookie cutter" version for the LVG as it is quite a time consuming effort.  Steady on, as they say.
« Reply #65 on: September 17, 2018, 08:39:30 AM »
Mark,
    Yes, I'm discovering more by the hour how long this step takes, and then there's a million rib tapes to follow! Modelling excitement at it's peak! :o
« Reply #66 on: September 17, 2018, 10:24:04 AM »
Mark,
Hang in there Lance:  Remember, we're in this together.  8)
Offline aliluke
« Reply #67 on: September 17, 2018, 04:05:06 PM »
Hi Lance
I remeber those rib tapes very fondly... 8) Worth it in the end and at that certain point when you realise "I've only got one to go" your smile should be recorded  ;D.
Alistair
« Reply #68 on: September 18, 2018, 01:16:45 AM »
"when you realise "I've only got one to go" your smile should be recorded" ;D.
Alistair,
     Great inspiration, I'll keep that firmly in mind!
Mark,
    You bet; at least there's no rib tapes on a Voodoo! ::)
« Reply #69 on: September 25, 2018, 03:01:52 AM »
   Finally this step is complete, the lozenge and tapes are done!
   The Aviattic Lozenge went on well as usual. It was applied over a coat of Future and once dried over night was trimmed with a fresh double edge razor blade. I used Aviattic's un-joined bolt width version and applied it per the aircraft in slightly trimmed 54 inch wide (scale) strips.
   The lozenge was given a coat of Future and, once thoroughly dry the rib tapes applied and again given one last coat of Future to seal them in place.
     Next the wing markings will be applied and a few very light mist coats of a Buff/light brown filter,  and final protective coat of semi-gloss to satin clear and the flying surfaces can be installed.
     And yes, I did smile widely when the last rib tape was in place! :D :D :D
« Reply #70 on: September 25, 2018, 03:18:34 AM »
Wow! Lance, that is a Macro compatible apply of Aviattic decals, much better than mine. Had some small trouble points, which I was not able to solve even with multiple applying of different softers.
One question, even it is a bit back in your report: how do you paint the leather of the seat? I like the satin gloss!
« Reply #71 on: September 25, 2018, 04:46:38 AM »
Thank you Frank. For the seat I used Model Master Enamel "Burnt Sienna". Once dry I rub the wear areas like the edge of the cushion and arm rests with my fingers to achieve a gloss or semi gloss wear effect and then work the folds and depressions with Tamiya Weathering Master oil pastel using a combination of their "rust" and "soot". There's no sealer or satin overcoat, just the shine from rubbing the original flat paint.
« Reply #72 on: September 25, 2018, 03:26:41 PM »
Getting better and better, Lance. The wings with the ribtapes give that certain something to the model.
Bye,
Offline aliluke
« Reply #73 on: September 25, 2018, 04:52:08 PM »
Wonderful Lance - well deserving of a big smile!!!  :) :) :)
Alistair
Offline Ryan
« Reply #74 on: September 26, 2018, 01:51:14 AM »
Lance, that seat looks like a worn catchers mit, superb!
Ryan
Upcoming: Not sure!
