Author Topic: Roden SPAD VII 19 Sq. RFC 1/32nd scale:SPAD VII Lafayette:Nieuport 28 94th Aero  (Read 110182 times)
Re: Roden SPAD VII 19 Squadron RFC 1/32nd scale: Plus SPAD VII Lafayette
« Reply #150 on: March 03, 2021, 01:08:00 AM »
Holding out on us, eh?
Only a couple of days  ;D Two all day sessions.
Oh dear Rick, you do seem to have a run of bad luck with your models, now it is hitting you on a SPAD. I do hope that you can find a solution to the strut and holes in fuselage problem as the RFC model is a gem in the making.
As for the N28 I suggest that it came from your frustration with the SPAD! Here's hoping that that one will not cause you problems.
Offline petrov27
ooh nice a N28 - which pilot/scheme for the 94th?
-Patrick
Thanks Stephen. Not bad luck at all. Making Stupid mistakes is different  :-[ I am not giving up on the RFC SPAD, it is just sidelined temporarily while I think about how to fix it! The Nieuport is challenging but I hope to get it to at least the same standard as the one I built several years ago.
The Nieuport will be #1 of Major Huffer. Red, white, and blue bands on the cowling.
Really ?
Another one !
Right one Rick !
Really ?
Another one !
Right one Rick !
Yep another one  ;D I had to do it  8)
Offline Fvdm
Sorry to hear about the cabanas. I hope Roden can deliver the sprue with them on. The planes look fantastic.
Thanks for the comments on the Builds! As for the Cabanes I hope Roden sends them but if not I will figure out the length and scratch Build them. After all it was MY Fault  :'(
I have done a little rigging work. I still need to paint, add some turnbuckles, and tighten up the wires as much as possible. Not the best rigged SPAD ever but it is OK.
« Last Edit: March 07, 2021, 01:23:25 AM by RAGIII »
Ok, Moving along from My previous post I have painted and tightened the rigging.( I also ended up replacing one of the double wrapped wires). For the record I used HSS for the lines and Evergreen strip for the wrapped lines. After painting and adding Smoke and Mirror Turnbuckles I am feeling much better about the overall look  8) I also started the filling and sanding on the Nieuport 28.
« Last Edit: March 07, 2021, 12:29:16 PM by RAGIII »
Happy face !  :)
Happy face !  :)
Thanks Alexis!
Looks good to me Rick!
Thanks Guy. Like I said I am feeling better about it after finishing the process...on the wings that is  8)
