Author Topic: Roden Fokker D.VI 1:32  (Read 27384 times)
Re: Roden Fokker D.VI 1:32
« Reply #45 on: January 02, 2021, 02:15:52 AM »
Nice work on the Spandaus even if they were the wrong ones  8) I am sure when you get the correct ones they will be equally well done!
Offline Fvdm
« Reply #46 on: January 09, 2021, 08:07:45 PM »
Thanks Rick.
The new parts arrived so finally I could continue with the MG's. First thing I noticed was that the back part must be used from the kitpart.
The differences are obvious, the cooling jacket and the nozzle at the end of the barrel are totally different. For the first one I used CA-glue. For the second however I used my soldering iron and that went very well. I prefer soldering above glue for strenght. When the first part is ready and the backend of the kitpart is separated from the barrel we have the following parts
When these parts are glued together it's time for the visor can be placed.
When I was working on the second visor the part suddenly jumped out of the tweezers and is eaten by the carpetmonster. I decided to use the visor from the 08 despite the very small difference in diameter. At the front of the jacket there was a bracket to be placed. You can see the parts in the middle.
I think these are very small but the artists who are modelling in 1:72 or 1:144 would laugh at this I reckon. As you can see there are two foldinglines and when the part is folded this is the result
I used a 10 cent coin so you can see the bracket, and yes, this one is folded twice.Last the mounting bracket had to be placed
I'm not even going to try to bend the bracket because 'll certainly break it. O, the large chunk of Non-ferro is the 10 cent coin
And finally an overal shot
Thanks for watching.
Ferry
Offline rhwinter
« Reply #47 on: January 09, 2021, 08:54:05 PM »
😳 GOSH! Tiny, tiny bits...
« Reply #48 on: January 09, 2021, 11:20:49 PM »
Nice work on the guns parts  :)
« Reply #49 on: January 10, 2021, 12:19:14 AM »
Your parts are huge ;D ;D in 1/48 the Master pieces are much smaller 8) The side clamp is really crazy.
The nice thing on 1/48 is, that the PE has spares.
I can recommend to black oxide finishing the parts, it keeps the details better then paint. But it has the disadvantage, that you cannot solder them (the solder will not get black).
See here (and two postings below): https://forum.ww1aircraftmodels.com/index.php?topic=10717.msg208208#msg208208
« Reply #50 on: January 10, 2021, 01:00:14 AM »
Your Spandaus' came out great! I am looking forward to seeing them blackened!
Offline Fvdm
« Reply #51 on: January 10, 2021, 06:59:51 PM »
Thank you all.
If I understand correctly the burnishing needs to be done before assembling. That means that I'm a bit late now but I'll sure order some burnishing fluid for next time.
This kind of tips and tricks are why I like the forum so much!
« Reply #52 on: January 10, 2021, 10:40:16 PM »
Yes, the (my) fluid will only attack the brass, so the color of the solder stays unchanged.
Same with already glued with CA - the fluid cannot reach the glue points (like masking) ;)
« Reply #53 on: January 11, 2021, 07:18:27 AM »
Great work on the guns... both times! 😉
Very clean modelling!
« Reply #54 on: January 13, 2021, 08:49:57 AM »
Great work on the guns. And another reminder for me, how much I love Gaspatch ready made guns...  :)
Offline fredjocko
« Reply #55 on: January 14, 2021, 02:36:09 AM »
The guns look amazing! I cannot wait to see the finished product.
Offline Fvdm
« Reply #56 on: January 15, 2021, 06:45:06 PM »
Thank you all.
Last week I was working on the landinggear and I started decalling the underside of the wings. I don't understand these decals from Roden because there where not enough for the topwing?? I wouldn't buy to much AM for this kit but I decided to buy the Aviattic decals afterall. I hope they are in sone but you never know with the Brexit. We'll see.
So, the landinggear. Th ekit parts are real weak so I binned it en toke the some brass rod 0,8mm en brass tube 1,6mm od x 1,4mm id.
It has to be a streamlined profile. I put the rod in the tube, the tube in the vise en closed the vise. When ready you get this ( I know this is probally already known but I just describe the method for the WIP)
For now I like it. The rod can be provided with flux and put in the rod again together with some solder. A quick heating with the torch and voila.
When I got 4 tubes I put them in the small wing and glued it with 2 components glue............
For sure this is real sturdy. Now I can make the struts for the wings.
Ferry
« Reply #57 on: January 16, 2021, 01:30:59 AM »
Impressive work on the gear! This is something I need to learn soon  ::) Looking forward to more!
« Reply #58 on: January 16, 2021, 04:36:57 AM »
Metal struts are always a good option in my opinion, well done!
If you like a more aerofoil shape: for scale 1/32 our member Flugzeugwerke offers a tool on shapeways.com:
https://www.shapeways.com/product/N6N2WG6JA/1-32-fokker-d-vii-quot-strut-smasher-quot-tool
In 1/48 it is not so easy, but a colleague with a 3D-printer helped me.
Offline Fvdm
« Reply #59 on: January 16, 2021, 09:13:51 PM »
That's a real nice tool Frank. I only wonder if the plastic is durable enough. I'll order one nevertheless and give it a try.
Everyone can do this Rick. You only need some tube and a vise.
