Author Topic: Roden Fokker D.VI 1:32  (Read 27455 times)
Re: Roden Fokker D.VI 1:32
« Reply #60 on: January 17, 2021, 01:44:06 AM »
Yikes, that's fine work on the Spandaus! Those undercarriage legs look so sturdy and beautifully in scale... nicely done, Ferry! ATB, Marc.
« Last Edit: January 17, 2021, 01:48:23 AM by Monty »
Offline Fvdm
« Reply #61 on: January 19, 2021, 05:28:58 AM »
Thanks Marc
The work continued with the wheels. I tried to allign them but the wheels are on a plastic axle. Plastic isn't real strong So I made brass axles.
Startingpoint
The wheel had to be alligned so I used my glass plate (I cut my PE on this) and i made a jig so the axle can be placed at 90 degrees
The anvil is there to make sure the jig stays at the right place. An anvil is a great tool to have. More later
I think the UC is sturdy enough now. While waiting for the Aviattic decals I worked on the N-struts. The N-struts in the kit are really weak so I toke some brass tube of 1,4 and made my own N-struts.
The holes in the wings needed to be cleared and then the N-struts could be placed.
This is real sturdy. Unfortunately you can't feel it but I have a nice piece of tool to show you. The following picture is not for the people with a weak heart  ;)
If the wings can carry an anvil then it's strong enough, right?
The wings weigh 47,7 grams, 1,68 oz
and the anvil weighs 500,9 gras, 17.67 oz, more then 10 times the weight of the wings.
I think this will never break so I'm happy
Thanks for watching.
Ferry
Offline Radarman
« Reply #62 on: January 19, 2021, 05:57:06 AM »
Wonderful job on those struts, Ferry.
                                            Kevin
« Reply #63 on: January 19, 2021, 10:01:37 AM »
Looking good  ;)
« Reply #64 on: January 19, 2021, 11:47:30 PM »
That photo with the weight is incredible  ;D Great work on the struts Ferry!
« Reply #65 on: January 20, 2021, 06:21:00 AM »
Great and clean work!
And I've never seen an anvil on a model before. You show in an impressive way how you trust your work!
And Yes, I also like robust models that can easily withstand prolonged transport.
« Reply #66 on: January 20, 2021, 02:28:31 PM »
Very fine work on MGs and struts. The anvil test resembles the static tests on made real planes with lots of sand bags  :D
Looking forward to following steps.
« Reply #67 on: January 20, 2021, 03:57:43 PM »
Nice work with the metal parts - a great improvement in strength.
Funny thing about the Model Master stuff.  At Sprue Bros here in the US, the entire MM Spandau machine gun ( PE, turned metal, and resin) is cheaper than just the PE and turned metal parts alone.  Go figure.
« Reply #68 on: January 20, 2021, 10:04:24 PM »
Metal struts are always a good option in my opinion, well done!
If you like a more aerofoil shape: for scale 1/32 our member Flugzeugwerke offers a tool on shapeways.com:
https://www.shapeways.com/product/N6N2WG6JA/1-32-fokker-d-vii-quot-strut-smasher-quot-tool
In 1/48 it is not so easy, but a colleague with a 3D-printer helped me.
Hi Frank,
It does seem to be a handy strut tool although I wonder how long it would last.
Also it's limited as to to the size of strut it can create.
Sadly it is difficult to find these days, but the 'Strutter' from 'Albion Alloy's' is the tool I use.
You can create any size of strut and any length and it's made of steel so will last,
« Last Edit: January 21, 2021, 05:32:15 AM by Mike 'Sandbagger' Norris »
« Reply #69 on: January 20, 2021, 10:12:03 PM »
Thank you all.
Your parts are huge ;D ;D in 1/48 the Master pieces are much smaller 8) The side clamp is really crazy.
The nice thing on 1/48 is, that the PE has spares.
I can recommend to black oxide finishing the parts, it keeps the details better then paint. But it has the disadvantage, that you cannot solder them (the solder will not get black).
See here (and two postings below): https://forum.ww1aircraftmodels.com/index.php?topic=10717.msg208208#msg208208
If I understand correctly the burnishing needs to be done before assembling. That means that I'm a bit late now but I'll sure order some burnishing fluid for next time.
This kind of tips and tricks are why I like the forum so much!
Hi Ferry,
Initially I used 'Master' brass machine guns, but as you've found, they can be problematic, regards soldering and blackening. That's why I switched to using the resin weapons from 'GasPatch', which I think are just as good and with none of the brass disadvantages,
Offline Fvdm
« Reply #70 on: January 21, 2021, 04:33:19 AM »
Hi Frank,
Sadly it is difficult to find these days, by the 'Strutter' from 'Albion Alloy's' is the tool I use.
Mike, if I'm correct the strutter doesn't make an airfoil shape. Or am I wrong? I will try to make a stl-file of the tool. If I have one I want to mill an tool from metal or aluminium. But first I have to learn 3d  :)
« Reply #71 on: January 21, 2021, 04:55:23 AM »
I would trust our member Flugzeugwerke, that plastic is enough. He offers also other tools in metal (shapeways can also print metal) where needed.
I have a plastic printed tool for struts and it works. This 0.1mm wall brass tube can be formed easily.
« Reply #72 on: January 21, 2021, 05:44:06 AM »
Yes it seems with most 'Strutter' type tools, its difficult to achieve a true aerofoils shape.
The 'Strutter' uses the same technique as I think the version by Bob Monroe does, in that a smaller diameter rod is passed through the tube, which is then 'crushed'.
The rod can be left inside the tube and soldered to form locating ends for holes in the model.
The 'Strutter' jaws sit in a vice and tilt as pressure is applied to the tube, which creates the shape.
The larger the tube and rod used, the more the jaws will tilt and the more aerofoil shape can be achieved.
Using smaller rod/tube combinations, such as we would use, means the jaws don't tilt as much as they'll contact each other sooner.
Consequently the shape achieved is more oval than true aerofoil.
I have used various stuff from Bob, but not his forming tools, so I can't speak from experience.
What I have had has been quality, so I've no doubt his tools work as well as any,
« Reply #73 on: January 25, 2021, 01:07:38 AM »
Lovely work on those struts, Ferry! ..and impressively sturdy... Waiting for more! Regards, Marc
« Reply #74 on: January 26, 2021, 12:34:34 AM »
I think it is very brave of you to test the struts in that manner....
Beautiful soldering job and great work on all the parts!
