Author Topic: Wingnut Wings 1:32 LVG C.VI  (Read 55934 times)
Offline aliluke
Re: Wingnut Wings 1:32 LVG C.VI
« Reply #195 on: November 20, 2018, 02:52:46 PM »
Superb Lance - a masterpiece and this is certainly my favourite WNW build to date. I'm going to have to try this wood carving one day - I have a huge stockpile of wood from my ship modelling days - what timbers did you use here?
A
« Reply #196 on: November 20, 2018, 10:40:40 PM »
Alistair,
       Thanks for looking and commenting. I'm still using wood veneer from a sample pack I bought years ago and the sheets aren't labelled. Only about 25% of the stock is useable and I'm running out of good straight grain and hard wood stock. I just choose the right color contrast from what's useable but will have to go shopping for more soon.
« Reply #197 on: November 21, 2018, 03:14:56 AM »
First class carving of the propellor Lance. I too must try using veneer for propellors if I build any more large scale models.
« Reply #198 on: November 21, 2018, 04:57:17 AM »
Oh Lance, the LVG biplane is a beauty!
but lots of red stuff on the bench
I hope you recover soon.
Yes, can be a bit dangerous trying to cut hard wood with sharp blades, that's why I prefer a carpenter's plane and sanding.
Your dark wood seems to be mahogany. This I tried but in 1/48 it has to much grain, so I do not use it. Some dark fruitwood is a better replacement.
If you need another prop hub - Proper Plane sell also hubs alone.
This will be a great model after all you careful work on it! :-*
« Reply #199 on: November 21, 2018, 08:43:21 AM »
   Thanks Stephen and Frank. I hope to locate a source for more veneer on line, some of that "pear" that you use, Frank, would be perfect. For the laminated props with a very high contrast I can source light pine stock locally but as you point out mahogany, the darker shade I have, often has too much and a very "open" grain.
« Reply #200 on: November 21, 2018, 09:50:12 AM »
Beautiful prop Lance. The icing on the cake to an  excellent build!
Offline aliluke
« Reply #201 on: November 21, 2018, 03:18:43 PM »
Hi Lance
For wood supplies try here: https://www.syrenshipmodelcompany.com/milled-lumber.php
Boxwood is an amazing timber - very tight grained and brilliant for carving - probably the very best there is. You could mix this in with Swiss Pear for contrast?
Alistair
Offline IvotB
« Reply #202 on: November 21, 2018, 06:14:35 PM »
Beautiful woodwork. And the real thing. It's impressive!
regards,
Ivo
« Reply #203 on: November 21, 2018, 11:34:58 PM »
Thanks Rick and Ivo. Alistair, I really appreciate the link to the wood source, just what I have been looking for! It's book marked and I'll be placing an order soon, will let you know how it works out!
Offline Europapete
« Reply #204 on: November 22, 2018, 01:40:50 AM »
Looking great Lance, well done. I should drag mine out of the stash and continue with it, been over a year since. Regards Pete in RI
« Reply #205 on: November 22, 2018, 03:20:34 AM »
Lance, I was hoping too that someone knows a source on your side of the ocean ;) I only know sources in Europe, but the veneer packs are often huge and heavy so end up with high shipping costs.
The source Alistair posted, seems to be a good one. Boxwood is available as veneer, something I have not found in Europe, and also in different thickness. May be you need in 1/32 more thick layers than me. Pear available also in all forms.
Another great stuff seems to be "Alaskan Yellow Cedar", a wood which is not available here (I found something on ebay for guitars, but shipment from canada). I found a great description here (for the german capable readers). It is easy workable and very uniform.
https://www.holzvomfach.de/fachwissen-holz/holz-abc/yellow-cedar/
Lance, you should give it a try too. Please let me/us know, if this wood is a option for our propellers.
« Reply #206 on: November 22, 2018, 06:39:38 AM »
  Thank you Pete, very much appreciated!
Frank,
   I'm going to place an order soon, probably with a sample of the tree types you mention. I'll do a post and some photos when it arrives. I th ink this may be a great source, especially for this side of the world!
« Reply #207 on: November 22, 2018, 04:58:42 PM »
That prop is brilliant!
Offline xmald
« Reply #208 on: November 23, 2018, 07:49:22 AM »
Terrific progress Lance! You are truly a master modeller.
Best regards
Filip
« Reply #209 on: November 23, 2018, 05:25:13 PM »
Inspired by your prop, Lance! Magic!!  :o
vB
