Author Topic: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 23.1.18 100% scratch floats  (Read 50328 times)
Offline Iancshippee
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 12.11.2017 alu sheet
« Reply #105 on: November 20, 2017, 11:44:41 AM »
absolutely amazing! Frank, with skills like these, you could start building the real thing!
« Reply #106 on: November 20, 2017, 04:35:03 PM »
Stunning, Frank! You are a real master modeler. The Metal works look fantastic,
Chapeau!
« Reply #107 on: November 20, 2017, 06:01:18 PM »
Wow Frank! I never get enough when looking at this WIP, I always want to see more!!!
Can't wait for the next update.
Antonio
« Reply #108 on: November 21, 2017, 04:52:26 AM »
Beide Daumen hoch!
Great progress on this one. Absolutely amazing!
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 20.11.2017 fuselage painted
« Reply #109 on: November 21, 2017, 06:24:57 AM »
Wow my friends, you find always so nice words for my work! Thank you very much, highly appreciated!
Today only a small update, also because I forgot to mention steps.
Fuselage painted
As usual prior to mounting I added some ignition wires to the engine. To a piece of round sheet painted reddish brown (isolation) I added seven copper wires and placed it behind the engine on the axle, the glued/cutted to the plugs (picture of the last update):
The was a small gap between "leather" bulge and the metal, so I added a lacing (Eduard PE, also used on the Sopwith Pup)
I forgot to take a picture of the side view - only that shows, how much the alu has to be widened!
On the back I added brass pipes for the control wires.
The rudders was separated, new hinges added and mounted. After protecting the metal the fuselage was primed with white ALclad.
I used this pictures of a Tabloid in Hendon ...
Quelle: https://hiveminer.com/Tags/factory,warbird
... and a drawing on the backside of the Datafile for painting the struts using a acryl pencil.
Finally it was painted with Gunze H338 grey (according to the manual). But I think I have used to much paint layers?!?
Should I redo the painting to have better visible struts?
Offline RLWP
  • Bodger
In my opinion, no you shouldn't. I'm not a great fan of paint schemes that try to show every lighting effect under the sun
I rarely look at a WW1 aeroplane and think 'wow, look at those ribs/struts/longerons'
On the other hand, it's your model, how do you want it to look?
Richard, thank you for your wake up call  ;)
It was a problem of the light: now in Winter here I'm leaving and coming back in the dark, so I've seen that only in artificial light. Today I was a bit earlier at home and could look at it with rest of daylight, even on a cloudy grey day.  But in that light it looks much better, so I decided to let it as it is.
Moving along nicely, await your decision on painting.
Offline RLWP
  • Bodger
Glad to be of help, Frank
The painting looks excellent to me! Really moving along on this one!
I agree with Richard and am pleased that you are leaving things as they are. Sometimes modellers overdo things and forget that what we see on the real thing is very much larger and therefore more apparant than would be the case if the size of object in question (the model) is properly taken into account. This is an excellent model - keep it as it is pleae!
I agree with all the above comments: it just looks right as it is.
And very well done.
Offline rayb24
I just read all the way through this build, what a beautiful model. A work of art and craftsmanship in the making imho... I’d leave the fuselage just the way it is. It’s subtle which looks better.
Ray
Hello my friends,
thanks for all your nice answers and recommendations - yes, I will leave it as it is.
Really pity, that I have no time on this weekend and both the next ones for modeling. May be some hours during the week.
Hopefully I can finish it until Christmas, at least that is the plan.
PS: Stay tuned for another surprise 8)
Offline Syd Solo
Peerless. A masterclass.
Syd
