Author Topic: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 23.1.18 100% scratch floats  (Read 50322 times)
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 17.12.2017 Decals
« Reply #120 on: December 18, 2017, 04:39:53 AM »
Thanks Syd!
Decals
After clear coat I added the decals.
The decals of the kit are very thin! Sol or something like that was not needed.
The length of the struts was cut according to the drawing.
Further metal parts was needed.
In this state, with plug-in gear the piece was shown in the mentioned medeler meeting as WIP.
The holes in the wings are matching.
Then I started to work on another detail.
This brass guide pulleys has a diameter of 1,5mm:
As casing I soldered a box from thin brass, with a brass rivet on the upper side.
The boxes are sitting on the backside struts and the first rigging work is done.
The small pulleys are finalized with chemical black and sitting crossways to allow a wing warping.
I hope you will like it!
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 17.12.2017 Decals
« Reply #121 on: December 18, 2017, 04:57:06 AM »
"I hope you will like it!
Frank"
Wow Frank, this is simply stunning.  What's not to like....     ;D
« Reply #122 on: December 18, 2017, 07:21:41 AM »
I love it!!  Truly amazing work, Frank!  Thank you for doing all of this and sharing it with us.
« Reply #123 on: December 18, 2017, 09:02:03 AM »
It doesn't get any better than this Frank! Just Gorgeous!
Offline jeroen_R90S
« Reply #124 on: December 23, 2017, 05:24:40 AM »
Gorgeous work -very inspirational!
« Reply #125 on: December 24, 2017, 12:17:27 AM »
How could anyone not like this? It's inspiring, and very well executed work!
« Reply #126 on: December 24, 2017, 07:24:45 AM »
INCREDIBLE cool. Really great. I hope to see it in march at Fürstenfeldbruck!
« Reply #127 on: December 25, 2017, 03:16:59 AM »
What you are doing is beyond incredible.... but I do not know of any words to describe it!!
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 30.12.2017 Mounting
« Reply #128 on: December 31, 2017, 04:35:22 AM »
Thank you very much my friends four your incredible comments! That is a great motivation :)
Mounting
At first some remarks regarding the color of the fittings. I thought about some grey, like the Tabloid in Hendon, but at the moment I think to let them as raw metallic.
Slowly I start to hit the home stretch!
The tail gets the control wires.
From below the one for the rudder is visible too. Added also struts made from squished brass.
The upper wing was painted with a additional thin layer to reduce the strong contrast to the fuselage. After that I added the last decals. Later after a clear coat layer the wing was CA'ed to the fuselage.
On the gear I added a big amount of Gaspatch turnbuckles (type "One end") and eyelets. I was a bit afraid of this task because of possible damage to the wooden construction. Together with some metal fittings the gear was mounted to the fuselage.
The next step was adding the rigging of the gear ...
... with nine wires!
The middle one needed most of the time, adding it at first instead as last one seems to be easier!
This was the last update of the old year! I like to wish all readers a great year to come!
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 30.12.2017 Mounting
« Reply #129 on: December 31, 2017, 06:15:02 AM »
The gear mounting and rigging looks gorgeous! Very well done! Looks great with the upper wing mounted!
RAIII
« Reply #130 on: December 31, 2017, 06:46:08 PM »
 8) WOW
Offline ondra
« Reply #131 on: December 31, 2017, 11:13:17 PM »
Every up-date is a pure gem and joy to follow, Frank, my hat is off to your skills!
Cheers and all the best in the new year or "einen guten Rutsch". ;)
Ondra
« Reply #132 on: December 31, 2017, 11:15:13 PM »
I am at a loss for words....   Outstanding is inadequate      :D
« Last Edit: December 31, 2017, 11:48:40 PM by Juan »
« Reply #133 on: January 01, 2018, 12:07:55 AM »
   Beautifully done Frank, your work is in a class of it's own!
   And Happy New Year to you as well!
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 1.1.2018 Rigging
« Reply #134 on: January 02, 2018, 06:43:27 AM »
Thank you very much!
Rigging
At first a small amount of wood and brass parts are needed:
The upper right parts are for the tail skid, two layers of wood.
After mounting it looks nice, luckily it could not be directed.
The upper right part in first pic is a small strut, which could be added due to change of the kit layout of the front. It is clearly visible on the orig pictures.
I started the rigging of the upper wing, much easier in this state.
On the lower wing there is a problem! There are only cones, with makes a) the line up and b) the secure mounting very hard.
My solution: I drilled holes in both wings on the backwards cone and plugged in 0.6mm nickel silver.
Just plugged both parts stays strongly on the fuselage.
After the careful mounting of the struts the rigging could be finalized.
For location of the turnbuckles I used pictures of the Tabloid in Hendon due to missing other sources. E.g. here is a turnbuckle for the wing warping, the wire ...
... goes over the pulley in the upper struts to the other side.
The Gaspatch turnbuckles are mostly of type "One End" and anchor points, but here I have used two of type "Albatros", ...
... to connect the foremost struts to the gear.
So the battle against the rigging is over!
The air screw and the wheels need some care and the whole biplane a bit weathering - this project come to an end soon!
