Author Topic: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 23.1.18 100% scratch floats  (Read 50315 times)
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 1.1.2018 Rigging
« Reply #135 on: January 03, 2018, 03:36:25 AM »
A fantastic start to the New Year Frank, she really is looking absolutely outstanding!
Happy New Year!
« Reply #136 on: January 03, 2018, 05:22:55 AM »
Rigging is beutiful as all the build. Chapeau!
« Reply #137 on: January 03, 2018, 05:36:38 AM »
You have done a brilliant job with this model, the rigging and the undercarriage are superb.
« Reply #138 on: January 03, 2018, 07:16:41 AM »
Thank you my freinds!
The model is finished now, please see the final pictures in Completed models:
https://forum.ww1aircraftmodels.com/index.php?topic=9167.0
Thank you all for escorting me through this build! See you in next project :)
This build report was assumed as finished, but ...
During stow away I looked again into the Windsock Datafile - the pictures of the Sopwith Schneider, the famous float plane, are very nice too! There is also a second Datafile 60 about Sopwith Baby, which contains also drawings of the  Schneider including floats.
And yesterday morning there we had snow chaos on the streets. After long time on the street without progress, I turned and was 7 minutes later back at home to call the boss - take a day off for modeling!
Since I was still in the "scratch" mode since the Nieuport cowling on weekend and I wanted to to something with wood I started to create ...
Floats
Cut stripes of plywood. 3 of them are thick enough for one float. At first glued two, drilled bling holes to be filled up with a bad alloy of solder. I want to avoid tail sitter!
After gluing the last stripe the lead is no more visible. With my small Proxxon disc sander the floats reaches the final form within seconds.
The sides are also slightly sanded to reach nearly the needed width. After that it was planked with my nice pear wood.
After the dry glue a sanded the veneer carefully to reach the contour.
For the up and down layer I had to bend the veneer with steam and glue it to the floats.
The beading was intended and mentioned the the Datafile drawing. I have to reduce the thickness further and sand the beading to the final size.
After primer and clear varnish it will hopefully looks like spar varnish!
Source:www.ctie.monash.edu.au
I really like the outcome! No, I will not replace the undercarriage of the Lebed. One day I want to build a Sopwith Schneider (or Baby) with the 100hp engine on this floats. I do not want to start a new build report now, but it matches this aircraft and kit very closely. And with a idea in my head sometimes I need to check immediately if it works or not ;)
Those floats look gorgeous Frank. I'm looking forward to seeing a Baby being "born"!
I totally agree with Ian!
Great, Frank!
I like the idea with the solder taken as counter weight.
No need to talk about your wood work. Top as always.
Bye,
As always, a cut above!
Lovely,
Awesome floats and I am also looking forward to your Baby!
Online lcarroll
Frank,
     Results like that from rescuing a bad day!? Great result for sure, and your project for the future is now assured. Nicely done!
Wow Frank, your snow day was not a total loss, those floats are the beginning to another masterpiece.
Thank you my friends for such overwhelming feedback! I promise to write a build report here, if the final project is running.
The easy shape of those very early floats invites me to try it that way. With more modern rounded shapes it would not be that easy and is may be better to stay with plastic and wood simulation with oils.
Offline AndRoby67
Hi Frank!
You sent me a message about this work. So, it's really amazing, I enjoyed every steps!
I "stole" other ideas, for example the wooden floats. I work only in 72nd scale so I must to be more carefully for the reduced dimensions, but really I think I will use some of your ideas in the future! I worked sometimes with real wood, I never tried only to build a carved airscrew. Also because I have a good amount of produced ones from Martin Digmayer and sometimes I used oil colors to represent wood. I was convinced that in 72nd scale is not possible to see veener, everytime I saw this I think that they are overscale.
Finally, your Lebed is really a great work!
Roberto
Thank you very much, Roberto!
I tried it only once in 1/72 and I must admit, that a aircrew in 1/48 is easier to do, but it works:
https://forum.ww1aircraftmodels.com/index.php?topic=8721.msg160381#msg160381
