Author Topic: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 23.1.18 100% scratch floats  (Read 50345 times)
Offline jeroen_R90S
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 12.11.2017 alu sheet
« Reply #90 on: November 13, 2017, 06:44:04 AM »
Fantastic work, Frank!
Those wheels, aluminium panels and the engine in particular are stunning!
« Reply #91 on: November 13, 2017, 06:45:51 AM »
Outstanding Frank, like always.
« Reply #92 on: November 13, 2017, 06:24:07 PM »
Impressive work Frank, nothing to add to comments by our  colleagues...
Just one "technical" question, how did you glue the alu sheet to the plastic?
Antonio
Offline RLWP
  • Bodger
« Reply #93 on: November 13, 2017, 07:36:53 PM »
Covering with sheet metal can be very effective:
http://imodeler.com/2017/11/scale-modelworld-2017-best-in-show/
« Reply #94 on: November 14, 2017, 12:34:02 AM »
Awesome work on the cowl panel! As you say nothing looks better than real metal!
« Reply #95 on: November 14, 2017, 04:42:41 AM »
Wow, what a great feedback! Thank you, my friends :)
It's a very interesting project - it started as small thing, not many parts, should be possible to do it quick. But with every little problem of this kit I start to think about a solution, which turned it into a very special model module by module, hope to be able go the way to the end now without further interruptions.
Antonio, this was done with cyanoacrylate, a gel variant. I used the brand "100% Sekundenkleber"
Source: hornbach.de
Oh yeah Richard, totally true. I followed this build by Peter from airscale in another forum, it plays in its own league!
Offline RLWP
  • Bodger
« Reply #96 on: November 14, 2017, 05:06:03 AM »
I found that build awe inspiring, yet still accessible. Looks like you took some inspiration from it too
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, 18.11.2017 But it does move!
« Reply #97 on: November 19, 2017, 06:57:43 AM »
But it does move!
Let's continue with the metal work, but this time more towards the front.
The kit contains PE for the side "gills", but it do not look really like open open vents.
So I did 3 cuts, ...
... pressed them against a sharp edge (green GfK) and finally formed with flat twezzers.
A kit error prevents the free rotation of the engine: the lower struts is straight, but a curve is needed. Removed.
Cutted after a paper template, edges are bend, glued an secured wioth rivets.
The plate could be bend easily, so I secured it with a new frame made of steam bend pear wood.
The other side is added too. The back frame is plated with a very thin wood.
All is prepared for the engine installation:
The marks are done with a rubber polishing tool, at very low rpm.
The bonnet was finalized and two vents are added at the front.
View from below:
But it does move! Now the engine is able to rotate! The engine can be seen from below.
This was a lot of work! A oil washing will be added later.
Offline RLWP
  • Bodger
« Reply #98 on: November 19, 2017, 07:46:18 AM »
Damn - wish I hadn't seen that
This looks a great way of doing thin metal parts
Excellent work
« Reply #99 on: November 19, 2017, 07:47:26 AM »
Truly spectacular work, Frank! Master craftsmanship at it's finest.
« Reply #100 on: November 19, 2017, 08:30:05 AM »
Could not agree more, just masterful.
« Reply #101 on: November 19, 2017, 11:21:44 AM »
Great work
« Reply #102 on: November 20, 2017, 05:35:39 AM »
Every update a new wonder. Superb model.
Giuseppe.
« Reply #103 on: November 20, 2017, 09:03:31 AM »
As always I agree completely with Bud!
« Reply #104 on: November 20, 2017, 11:37:50 AM »
Absolutely outstanding metalwork. I couldn't agree more that only metal looks like metal, and is thin enough in scale. I used a beer can for the panels on my scratchbuilt Bleriot, but this is way above what I achieved.
Fantastic work indeed!
