Author Topic: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 23.1.18 100% scratch floats  (Read 50332 times)
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 15.9.2017 Fittings
« Reply #75 on: September 19, 2017, 07:05:16 AM »
Wow!!! That undercarriage with all those details is mindblowing!
« Reply #76 on: September 20, 2017, 12:45:04 AM »
Looks Decent....  ;D OK AWESOME, Beautiful, etc, etc, !!!!!
« Reply #77 on: September 20, 2017, 03:35:19 AM »
As has been commented, the combination of different materials and the attention to such small detail (even in this scale) marks out this model as something very superior. I do not envy you trying to get those bungee cords to look right!
Offline Jim
« Reply #78 on: September 22, 2017, 08:24:14 PM »
Awesome work, Frank.  By coincidence, I recently began building the Special Hobby Sopwith Schneider but got a bit stuck in the build not having any references to work from. However, after seeing what you're doing I am not only inspired to keep going, but also try a few of the extra details you have done. I may even start my first build post!
Woof!
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 24.9.2017 New toy
« Reply #79 on: September 25, 2017, 07:12:27 AM »
Thank you all!
Jim, nice to hear my build could inspire you, looking forward to your build post!
New toy
There was not really time for this model, but I have a new toy!
The wheels are painted, then I added the spokes and painted finally the rim with alu:
If you can drill small holes that evenly, you don't need a dividing head!
Anyway Richard, now I have a new toy: a small dividing head! It matches to my small milling machine, and is usable for the drilling one too.
I wanted to try it immediately! What is missing here? A fuel cap!
On some high resolution pics of the Hendon Tabloid the cap is visible. So I turned one from brass on my lathe, put it into the dividing head and milled every 30° with 0,8mm.
The result:
« Last Edit: September 25, 2017, 07:16:49 AM by Bughunter »
Offline RLWP
  • Bodger
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 24.9.2017 New toy
« Reply #80 on: September 25, 2017, 07:35:26 AM »
Lovely!
« Reply #81 on: September 27, 2017, 05:28:36 AM »
That's gorgeous, Frank!
Also I missed all that chat about your landing gear legs - just beautiful work! I'm lost for words.
« Reply #82 on: September 27, 2017, 07:26:02 AM »
Superb work with the undercarriage Frank.
« Reply #83 on: September 27, 2017, 10:17:50 AM »
Wow, this is above and beyond...beautiful work!
« Reply #84 on: September 27, 2017, 10:26:05 AM »
Great stuff I like it
« Reply #85 on: September 27, 2017, 04:56:28 PM »
I like it a lot!
vB   :o
Offline KrzysiekK
« Reply #86 on: September 27, 2017, 05:36:26 PM »
the most wooden platic plane I have ever seen..
astonishing!
regards
K
Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 12.11.2017 alu sheet
« Reply #87 on: November 13, 2017, 06:19:25 AM »
Hello,
after a long time I have to say at first thank you very much for your nice comments!
I was a bit out of ideas here, so I have done another small project, was busy with other things and finally something, which have to kept non-public until December (stay tuned!) but now I'm back here.
Alu metal plate
With handling of the fuselage the bonding opened a bit, so I take the chance and added some sheet. Now it is wider and has a bit more space for the engine.
With a back side of a brush I formed aluminium from grilling tray into a bonnet prototype. The resin part of the kit was to thick and flat. Not bad so far, only very thin on the top.
If aluminium bonnet, what about the rest? I have to rework the sides anyway, because this are not bolts from a tank, this is an aircraft!
Top and sides are done.
The top plate was hard to done, but then I detected on pictures from Hendon a second plate just in front of the cockpit. That way it works!
You can see small rivets on the pictures. Those are brass ones: 0,3 with 0,5mm head and 0,2 with 0,3mm head.
I tinned them prior cutting and mounting, which take a lot of time!
The front is mounted and the crossing to the lower side was rounded.
Front and lower side is a one piece:
Drilled from both sides of the engine, for a new longer axle for engine, both bearings and airscrew.
All plugged together for testing purposes.
And with the bonnet:
That was a lot of work, but sheet of real metal looks best like sheet of metal!
Re: Lebed VII (Sopwith Tabloid), Special Hobby 1/48, Upd 12.11.2017 alu sheet
« Reply #88 on: November 13, 2017, 06:34:02 AM »
This is truly lovely work Frank. The amount of detail that you have there is exceptional.
Online Juan
« Reply #89 on: November 13, 2017, 06:36:17 AM »
Wow Frank, simply outstanding (all-around)
