Author Topic: Fokker EIII vs. Fe2b "Jäger und Gejagte" Wingnut Wings 1:32  (Read 42809 times)
Re: Fokker EIII vs. Fe2b "Jäger und Gejagte" Wingnut Wings 1:32
« Reply #45 on: August 02, 2016, 12:14:06 AM »
    Beautifully done Manni! The finish on this model is superb and with the prop and the way you've "streamed" the figure's scarfs it looks like it's moving, I'm really looking forward to seeing what you do with the Fee, keep up the terrific work!
« Reply #46 on: August 02, 2016, 04:26:50 AM »
Very nice Fokker, Manni! Well done! These rotating props are really cool...
Borsos
« Reply #47 on: August 02, 2016, 04:05:48 PM »
Thank you all for the nice words Icarroll and Borsos.
I will soon post some new pics of the progress of the fee. This time I will do the whole Wood with decals (I am working on it now) but I think it will be the last time I will do that. Oilsor an very easy acrylic-technique of a fellow modeller is more satisfying and a bit less "cheating".
« Reply #48 on: August 02, 2016, 11:04:01 PM »
Manni, Your Eindecker looks great! Love the spinning prop representation.
« Reply #49 on: August 03, 2016, 02:41:29 AM »
This is a magnificent eindecker, looking for the whole big diorama with great interest.
« Reply #50 on: August 04, 2016, 09:09:55 PM »
Thank you gents for your kind words, that keeps me on modeling.
Now I have started with the Fee.
I decided to take on the following scheme, because it is not so common like the zanzibar scheme:
Als usual I have started with the cockpit.
As all WNW Kit it is highly detailed and there are a lot of parts in the box, that are nearly all needed for the cockpit and the engine.
I also use here a PE set from HGW, but I can say only the seatbelts are required the rest is detailed enough or could be done with homemade details.
The weathering of the wood was done just with burned umbra oils. But i still have to do a lot of work on the weathering, the decals and some custom details.
More to come soon...
« Reply #51 on: August 04, 2016, 09:33:15 PM »
You have made a fantastic start on the Fee Mannie, what you have done so far looks excellent.
Offline Edo
« Reply #52 on: August 04, 2016, 09:43:55 PM »
Yes Manni, you are doing a great job.
To my eye the weathering of the floor is particularly well done!
ciao
Edo
« Reply #53 on: August 05, 2016, 01:03:51 AM »
Lovely work on the interior, Manni!  Your wood and metal work are truly remarkable!
Offline steveb
« Reply #54 on: August 05, 2016, 11:09:50 AM »
Very cool! Thanks for sharing your techniques.
« Reply #55 on: August 05, 2016, 03:48:02 PM »
Great cockpit!
« Reply #56 on: August 05, 2016, 11:33:10 PM »
The cockpit floor is drop dead gorgeous! The whole assembly is outstanding!
« Reply #57 on: August 07, 2016, 11:51:32 PM »
Awesome start on the Fe2, Manni! The Sheme is my favoured too (I prefer the modified landing gears) and your woodwork is extraordinary fine. Can you tell us more about that? Did you use wood decals or just oils?
Best wishes from the Northern Sea
Borsos
« Reply #58 on: August 08, 2016, 07:00:10 PM »
Thank You all for theese kind words and your interest.
Borsos asked me to point out some details of my woodwork.
Here I have used the HGW decals on Alclad white primer, but I must say in future projects I will go on with my own technique of simulating wood.
I apply a base of decktan and take some burned sienna or umbra on a cardboard to get rid of the most oil. After that I take a brush and paint it in one direction on the surface, after that I take a toothpick and scratch a grain texture like pattern into the fresh oilpaint (You don't need to do the toothpick step when you would like to create very fine/knotless plywood).
Then I let it dry for 5 minutes. After that I take a nearly dry brush (white spirit) and brush it in one direction over the surface. I repeat this step (but always with cleaned brushes) until I like the grain.
After one day of drying I spray over it with some clear yellow or orange thinned down with some satin varnish as I like to generate different tones.
The now following step I have done also on the decals. I put some burned umbra on a cardboard and apply it on the ready decaled part with a Q-tip on the outer sections of a part and the edges were 2 parts join. Then I take complete dry brushes to rub the paint into the parts center (just 3-5 strokes and then a new clean, dry brush)
When I am happy with the result I make the apperance a bit more even with a Q-tip, that I rub over the nearly dry paint.
If there is too much paint on it, or you want to get rid of some colour at some edges I put some bul-tak or Uhu-Pattafix on a toothpick and rub overtheese points. This works like a rubber and takes the oilpaint away.
Hope that is a help for you.
Offline KitRookie37
« Reply #59 on: August 08, 2016, 09:37:06 PM »
Hello ladies and gentlemen,
Such a beautiful paint !! BRAVO !!
Best regards.
Alain.
Use the force, Luke.
