Author Topic: Fokker EIII vs. Fe2b "Jäger und Gejagte" Wingnut Wings 1:32  (Read 42924 times)
Re: Fokker EIII vs. Fe2b "Jäger und Gejagte" Wingnut Wings 1:32
« Reply #60 on: August 08, 2016, 09:43:07 PM »
Thank you for sharing your techniques! So these decals are the prefabricated ones especially for the Fe2b? Are they pre-cut?
Thank you!
Borsos
« Reply #61 on: August 09, 2016, 05:34:38 PM »
Hello Borsos, you're welcome! ;D
The decals were espially for the Fee, but I just used them, because they were in the HGW Superset for the Fee that I have ordered long ago.
They are not pre-cut and have an overlap of 2mm. Very annoying was the decal for the cockpit I had to cut out every hole for the instruments.
If you want to go with decals you would be well advised to take Uschis or the standard HGW decals (the HGW decals are a bit brittle but have a better print resulution compared to the Uschi decals) instead of the Fee decals.
Grüße,
« Reply #62 on: August 10, 2016, 07:44:28 AM »
Thanks again!
I like the HGW wood grain, but my method to "copy" panel after panel using masking tape and a sharp pencil does not work with them. However you reduce the sticking of the tape, it sticks too well on these HGW decals and lifts the decal from the backing paper. Therefore I prefer UvdR wood decals anyway. I would have tried these special HGW decals if they were precut and would perfectly fit - but now...
Borsos
« Reply #63 on: August 19, 2016, 04:08:02 PM »
Thank you to all of you for your kind words.
slowly I make some progress on this pusher.
I hope you like it and I hope to make now faster progress on this  build.
Cheers,Manni
« Reply #64 on: August 19, 2016, 09:34:26 PM »
Your interior looks awesome! I am certainly enjoying watching you bring these aircraft together!
« Reply #65 on: August 19, 2016, 10:14:49 PM »
Gorgeous interior, Manni!  You've convinced me to get the HGW set for mine.  That seat looks so much more to scale than the kit seat.
« Reply #66 on: August 19, 2016, 11:21:12 PM »
Wonderful nacelle, Manni, really nice! Can you tell me how much of the main fuel tank under the engine is visible once the engine is installed? I intend to convert mine into a Fe2d with a WNW Rolls Royce and that one seems to have had a rectagular main fuel tank instead of the round one. So it would be cool to know if the difference would be too visible...
Thank you!
Borsos
« Reply #67 on: August 22, 2016, 05:17:41 PM »
Thank you for your encouraging words! This build is very extensive and it pushs me to my modeling limits.
I have started now with the engine with it's PE parts and wireing.
@ coyotemagic: please take a look to the set first. i think most things are not necessary because the kit parts are very good (maybe better).
-The interieur set is in my opinion completely needless, exept the great seat.
-The decal set is not precut, so you can better do it in the old but good oil-technique or cut out your own decals.
-The seatbelts are simply stunning and I can highly reccomend them.
-The engine fret looks better, but all  theese things around the engine could be done by yourself (with skills like yours).
- If you decide to build the Fee with bombs, I can reccomend that set.
-The exterieur set seems to be ...let me say needless too, because the parts that you sand off are great right from the kit.
@Borsos
The fueltank is nearly 99% covered with the engine. I tried to see it and was not able to do so. Maybe with a torch and some artistic movements.
Cheers, Manni
« Reply #68 on: August 22, 2016, 05:45:32 PM »
Manni, thank you very much for these very valuable hints! "valuable" in its true sense and economocally understood as I''ll spend my money probabely on the single seat belts set, but not on the whole detail set.
Good to know about the fuel tank! Then I'll drive back my research in this very point...
Borsos
« Reply #69 on: August 23, 2016, 02:24:09 AM »
Thanks for the insight, Manni!  You've just saved me a ton of money.  I'll just buy the seat belts and sand down the seat.
« Reply #70 on: August 23, 2016, 03:26:24 PM »
@ Andreas and Bud,
it was a pleasure for me to save your money. Finally I throw about 50€ out the window for things I don't need. So if you save the money, you can spend it on an other kit, build it and show it on the forum so it's a win-win situation.
« Reply #71 on: September 05, 2016, 04:51:01 PM »
So, gentelmen, I have finished the engine.
Thank you for all the kind comments. THANK YOU!!!
The engine is made of about 40 plastic and 50 PE parts. The fit was excellent but alot of masking was required to paint it properly.
The complete engine was brushed with Alclad and weathered with a brown wash to tone down the blingbling of the metall. After that some engine grime and fresh oil was applied.
Offline Edo
« Reply #72 on: September 05, 2016, 05:04:42 PM »
Well MAnni,
you did acheive a great result with the engine!
I always find it a pity to seal the engine inside the fusolage... and in your case it is all the more so!
ciao
edo
« Reply #73 on: September 05, 2016, 05:08:42 PM »
Breathtaking engine, Manni, very nice!
Borsos
« Reply #74 on: September 05, 2016, 06:42:20 PM »
Superb job of the interior of the Fee, Manni, and the engine
is a work of art. The oil staining is terrific.  Excellent progress,
my friend. :D
