Author Topic: Eduards SSW D.III  (Read 44491 times)
Re: Eduards SSW D.III
« Reply #150 on: August 18, 2014, 05:23:47 AM »
Thank's guy's  :)
Okay , here we go . Lozenge on the tail feathers are from the kit . No point on using Aviattic's lozenge when it is pretty much going to be covered in red paint . Over all effect turned out not to bad . Rudder has it's base coat of white paint and shading done in Tamiya smoke waiting for it's top coat of white for better blending of this effect ( went to heavy with the smoke )
Axle wing , inter struts and the cab struts are painted as well as the wheels . The wheel covers have lozenge as well done in the same manner as the tail feathers .
« Reply #151 on: August 18, 2014, 05:24:19 AM »
« Reply #152 on: August 18, 2014, 05:24:50 AM »
« Reply #153 on: August 18, 2014, 05:25:18 AM »
« Reply #154 on: August 18, 2014, 05:25:48 AM »
« Reply #155 on: August 18, 2014, 05:26:40 AM »
And these items are up next ...
Offline Vickers
« Reply #156 on: August 18, 2014, 05:39:57 AM »
Fantastic, Terri!  That red is suitably vibrant and will really jump from the lozenge.  Very nice work, indeed!
Offline Epeeman
« Reply #157 on: August 18, 2014, 05:43:28 AM »
Coming along well, Terri -
It's great to see the model start to change once you get a splash of paint on ............
« Reply #158 on: August 18, 2014, 10:21:38 AM »
Brilliant work, T!  The lozenge see-thru effect is superb.
« Reply #159 on: August 18, 2014, 10:50:09 AM »
Thanks a lot guy's  :) I just finished applying the last coat of future and will let this set for a few days . It has been pretty humid here of late so just to be on the safe side I want things nice a cured . In the mean time I will start work on the guns and figure out what the hell I'm going to about the engine !
« Reply #160 on: August 18, 2014, 11:13:05 AM »
Terri, I agree with my Amigo! Very well done on the see through on the tail!
« Reply #161 on: August 18, 2014, 11:17:09 AM »
Excellent work, Terri.  As Rick mentioned, great job on the tail.  Looking forward
to the next updates. :)
« Reply #162 on: August 19, 2014, 02:54:24 AM »
Wounderfull! ;D
« Reply #163 on: August 19, 2014, 08:08:20 AM »
This model is shaping up really well Terri, the red is a great colour and your pre shading is looking good, nice work on the tail.
« Reply #164 on: August 19, 2014, 09:32:10 AM »
Thank-you very much guy's for the feed back  :)
I've looking over the engine in the kit and it is basically wrong in the shape of the crank case and the cylinders  :( Then the thought of using the Siemens engine from Tom's Modelworks Pfalz D.VII/III kit and this has a few issue with it as well . The cylinders aren't lined up  :( and it's crack case isn't right either even though the detail is done rather well ! Well what about the Vector resin one ! As much as I would love to get one , it's not in the cards and it won't fit in the cowl . An easy fix by just shorting the cylinders where the meet the crank case , shorting the push rods and the induction pips . saving all that wonderful detail on the cylinder tops !
Now the question is ...do I scratch build one , this could take awhile or just use what is in the kit ...
I'm not a fan of white metal so I will swap out the metal one for a resin one and go from there .
