Author Topic: Eduards SSW D.III  (Read 44383 times)
Eduards SSW D.III
« on: June 04, 2014, 09:26:08 AM »
Over on another forum I started this build for a GB , even though that the GB is over I didn't even come close on getting this one finished and had many stalls during the build as conflicting info went with answers . Any way for those of you who have been following this bear with me please .
So far a fair bit has been done on the kit . Fuselage insides got sanded down to round it off a bit more including the lower wing and chin pan . Next the louvers were opened out with care the plastic in this area is now very thin ! lower wing was then glued to the fuselage followed but the rear tail feathers which have the control surfaces cut free . More sanding was done on the inside of the fuselage with putty applied to the seems on the inside and more sanding . Next was thinning down the upper wing and lower wing . More sanding and heck of a lot of it ! With this part of the build done ; time to start the cockpit structure . All this is scratched . Only kit parts used so far is the seat ( I was lazy ) better seat belts from the parts bin and the hand grip . I did forget one part , the shell ejection tube   :(  But it is what it is .
The gun deck does not fit and to solve this problem it was split down the middle and 2.5 mm added to the front where it meets the cowl . And 2mm at the rear . Cowl fitted in place as well . Yup , you guess it , more sanding which at this point seems to be the only thing I'm doing ! With all the sanding panel lines needed restoring . Outcomes the dymo tape and scriber and these are replaced . Still have to do the separation  between cowl and fuselage . Now I can start detailing the fuselage . Control surface will be cut free on the main wings as well so I can do the hinges .
Re: Eduards SSW D.III
« Reply #1 on: June 04, 2014, 09:27:23 AM »
I do have more pic's right up to were I'm on this , they don'tseem to be in their file ....more coming later  :)
« Reply #2 on: June 04, 2014, 09:50:58 AM »
Terri,
I absolutely love what you are doing with my old relic kit  8) Your scratch built interior is awesome and I hope you find the pics to prove it !
« Reply #3 on: June 04, 2014, 10:14:51 AM »
Truly stunning interior work, T!  I especially love the engine mount/carburetor.  With all the additional detail you're adding, I'm betting that yours will be better than Eduard's new release.  Where is that thing, anyway? ???
« Reply #4 on: June 04, 2014, 11:31:56 AM »
Looks awesome, I like the backend of that rotary...
« Reply #5 on: June 04, 2014, 11:42:57 AM »
Lovely work on the interior Terri, your scratch building skills are excellent.
« Reply #6 on: June 04, 2014, 12:28:30 PM »
Hey Rick , if it wasn't for you on sending said kit this wouldn't have been possible . I found a few more pic's but nothing of just the cockpit . Those are gone west of the doh-doh bird .
Bud , Bo , not as much detail as I was shooting for , but since this area won't even be seen it was best not to get to gun ho . Next one will have more detail for the excess hatches will be off to peer inside .
Bud , I'm really looking forward on Eduards retooling of this kit and the level of detail it will have . Hopefully soon , rumor is some time in June but could be later . Nothing on their web site which indicates it's release . I do hope if fairs better and not a huge error as in their new 109 G6 .
Thanks Des ! I think which aids in these skill is the subject itself . I have a keen interest in this aircraft . Just love the shape of it and that spinner gives it a sinister look .
Okay found a few more photo's . Will have to re-take my last ones ....don't know what the hell happened to them . Is there a photo monster out there which folks aren't talking about here ....
« Reply #7 on: June 04, 2014, 12:29:28 PM »
and a few more ....
« Reply #8 on: June 04, 2014, 12:55:27 PM »
hey terri ,looking good, i saw the newer posts on aeroscale. thanks for all your hard work its nice to look at.
guitarlute101
« Reply #9 on: June 04, 2014, 01:15:03 PM »
There it is, love this build Terri!
« Reply #10 on: June 05, 2014, 01:03:17 AM »
Hello Terri:
Welcome to the Forum and a great entry into it.  Per usual, great work, as has been mentioned, your attention to detail in the engine compartment is especially noteworthy.  Looking forward to your next update.
« Reply #11 on: June 05, 2014, 01:57:43 AM »
it is an exellent work.
I wait to build with my SSW when the new Eduard will come out.
My old would be then a conversation to a D IV.
« Reply #12 on: June 05, 2014, 09:41:42 AM »
Hi Scott , yeah I don't know what happen with my photo's . It has sat for a long time on the bench while I did a couple of WW 2 subjects and modern of all things , but turn out very well . The sanding burnt me out and I lost interest ...
Mark , It is coming along well . Glad you are enjoying the build !
mgunns , nice to hear from you and thanks for the welcome . I'm rather pleased with how it turned out . Scratching the cockpit structure as a separate item I was able and add a bit more detail .
Hi Martin , I hope Eduard release this kit or let us know when it will be coming out . Koster has the D.IV . It's a vac kit with resin wings and other parts and some very nice PE as well .
Offline dtomko
« Reply #13 on: June 05, 2014, 10:36:05 AM »
Good to see you here and to see this build continue.
Drew
« Reply #14 on: June 06, 2014, 09:19:23 AM »
Thanks Drew  :)
