Author Topic: Eduards SSW D.III  (Read 44290 times)
Re: Eduards SSW D.III
« Reply #15 on: June 06, 2014, 02:25:50 PM »
i know what you mean, its easy to get sick of sanding when you work on alot of short run and vacs. my favorite of yours was the fe8.
« Reply #16 on: June 06, 2014, 10:14:22 PM »
Hey Scott , still will be more sanding but not as involved as before . Once the fuselage details are done next will be rib tapes , primer and a lot of masking ! Will be using Aviattic 5 colour lozenge . Still need to finish off the prop and spinner and start detailing the engine , new cab struts and the landing gear as well . Will have to dust off the FE-8 and get some pic's up . It's one of my favorites as well .
Will have some progress pic's up this weekend .
Offline Bolman
« Reply #17 on: June 08, 2014, 12:30:28 AM »
Excellent progress Terri, you truely are a master. Can't wait to see the finished product. Definately a master piece in the making!
John
Offline vincentm
« Reply #18 on: June 08, 2014, 08:49:47 AM »
Very good idea, I love the SSW D-III. I'll be glad to follow your build.
« Reply #19 on: June 08, 2014, 11:26:39 AM »
Thanks John for the kind complement  :) Nice to have a mojo boost !
Hi Vincent , one of my all time favorites ! Glad your liking the build  :)
Made some more progress placing the PE access hatches , fuel/oil cap which are to far forward and will be moved back . Gun decks panels where made out of foil paper type stuff with alum . Found at the dollar store in the crafting section . I have bare metal foil , but this is too thin . 0.5 thou card is too thick . The thickness of the paper foil is 2mm  Prefect ! Once the backing is removed it is quit sticky and adheres very well . Hard to peel it off once it's laid down . Also started on the rear bungee cord .
« Reply #20 on: June 08, 2014, 11:30:12 AM »
Here is a shot of the faire wall and work already done on the spinner and work done on the lower louvers .
« Reply #21 on: June 08, 2014, 11:31:05 AM »
And the prop ...
« Reply #22 on: June 08, 2014, 01:13:55 PM »
Terri,
Really awesome work on everything!
« Reply #23 on: June 08, 2014, 02:15:38 PM »
Truly brilliant work all 'round, T!  This is shaping up to be your best yet.
« Reply #24 on: June 08, 2014, 08:34:52 PM »
A nice and great Progress about your build. I love it Terri.
« Reply #25 on: June 08, 2014, 10:56:20 PM »
Thank-you very much for the kind comments guy's  :)  Today's goal is start work on the control hinges on the tail section and a few other details here and there . Slowly getting closer to the painting stage or at least primer .
Offline Epeeman
« Reply #26 on: June 09, 2014, 07:06:42 AM »
Coming together nicely, Terri.
Look forward to seeing this progress.
« Reply #27 on: June 09, 2014, 08:32:25 AM »
Hi Dave ,
Thanks for dropping by and having a peek . I did make some progress today and have the tail section almost wrap up . Form sanding on the rudder fin strips of 30x30 stock was glued on the back and top replacing what was lost . Once the glue set this was sanded to shape and hinges added using 30x30 scraps . The stabilizer was face with half round and blended in with more sanding . Slots where made with a fine file so the new hinges will fit .
Online Brad Cancian
    • Brad's Models
« Reply #28 on: June 09, 2014, 09:43:26 AM »
Excellent progress on this one Terri!  I have it in the stash and am taking notes on your build :)
« Reply #29 on: June 09, 2014, 08:49:51 PM »
Great work Terri, wait for your next.
