Author Topic: Eduards SSW D.III  (Read 44851 times)
Re: Eduards SSW D.III
« Reply #180 on: August 21, 2014, 09:59:27 PM »
Thanks guy's !
Last night I tried a small piece of 32 scale lozenge and had no issue at all . After 30 seconds the decal slid right of the backing .
Rick , Lance . Seems that Edmonton's water is fine after all and is the decal paper itself . I have these since this time last year so I think your right Rick . These are from the first batch before Aviattic starting using a different paper .
I really do like how these decal adhere to the surface and the amount of pulling and tugging , other decals would break apart .
« Reply #181 on: August 24, 2014, 11:39:59 PM »
Work continues with bit of painting . Rudder has it's coat of white toning down the per-shading . Prop blades have their base coat on ready for the lamination and the top wing has the lozenge applied .
Next step is applying a few coats of future in prep for starting the rib tapes . First part I will spray some old Eduard lozenge with Tamiya deck tan . I will only do one lozenge bolt at a time . Don't want the paint to cure for to long or it will crack when laying them down . Once this is all done , round two will be going over then again with the Aviattic lozenge ....
« Reply #182 on: August 24, 2014, 11:40:28 PM »
« Reply #183 on: August 24, 2014, 11:41:00 PM »
« Reply #184 on: August 24, 2014, 11:41:43 PM »
« Reply #185 on: August 25, 2014, 06:48:17 AM »
Great paint and wonderful Lozenge.
Offline Umlaufmotor
« Reply #186 on: August 25, 2014, 07:23:04 AM »
Jepp - I like the rudder and also the prop.
Do you need any colored pencils for the prop, Terri??  :D
Servus
Bertl
« Reply #187 on: August 25, 2014, 10:21:18 AM »
Thanks Martin  ;D
Bertl my friend , I'm one step a head of you ...already have my very own pencil  ;) I have been toying with them for a few years now and so far I'm pleased with my efforts . Still though practice makes perfect  ;D
« Reply #188 on: August 31, 2014, 12:26:35 AM »
I'm using my time to go through things and do some long over do clean up and found a 3/4 bolt of Mircosculpt 5 colour lozenge upper and a bit of the lower . I thought I tossed this long ago !
With this in mind , I think these would work well for the rib tapes , saving a bit of time . They will need to be toned down with touch of smoke . Weathering should tie this in well .
What is your guy's view on this ?
« Reply #189 on: August 31, 2014, 09:52:32 AM »
Hello Terri:
From what you describe, it sounds like a good idea.  No sense tossing the decal if  you can use it for the rib tapes.
« Reply #190 on: August 31, 2014, 01:23:57 PM »
Sounds like a plan T!
Offline xmald
« Reply #191 on: September 01, 2014, 09:52:42 PM »
Great job Terri! Loz looks really neat and sharp. I can`t wait to see the final effect!
Best regards
Filip
Offline ondra
« Reply #192 on: September 02, 2014, 12:21:04 AM »
Great job, Terri, really jaw-dropping.
I admire your sense for colours.
Btw. if it is not a rude question - are you really a woman? That would explain your great work with the shades and the astonishing sense for colours.
Sorry if it is a stupid question from a newbie.
« Reply #193 on: September 02, 2014, 05:40:39 AM »
Thank you guy's !
Mark , Rick . I hope so , taking me a long time to get to this stage and there is this fear that it won't like right and I'll end up having to strip it all off and start over . Not something I want to be doing .
Xmald , I'm really looking forward to this myself , hopefully I will be back at the bench soon .
ondra , It is not a rude or stupid question and no need to be sorry for asking . Yes , yes I'm  ;D
Offline vincentm
« Reply #194 on: September 03, 2014, 10:41:20 AM »
Not sure I've got it right about the ribs see-through: you have painted them with light tan on the lozenge decal itself?? the effect is really interesting, looks like the entire wing is translucent.
