Author Topic: 1:72 Maquette Ilya Muromets  (Read 78197 times)
Re: 1:72 Maquette Ilya Muromets
« Reply #45 on: October 02, 2013, 04:20:25 AM »
  Ian,
Just keeps getting better and better with each new update my old friend. Outstanding project.
« Reply #46 on: October 04, 2013, 08:26:17 AM »
The interior is looking excellent Ian, I hope you have some luck finding a ladder.
Offline Zabu
« Reply #47 on: October 04, 2013, 09:56:30 AM »
Very nice update Ian.
The interior, seat and steering wheel are nicely done.
Offline Adam
« Reply #48 on: October 04, 2013, 05:16:37 PM »
It's nice to see the progress, it looks great.
Adam.
Offline xmald
« Reply #49 on: October 05, 2013, 09:19:51 PM »
 :o :o :o :o :o :o :o :o :o
Best regards
Filip
« Reply #50 on: October 06, 2013, 02:39:44 AM »
Excellent interior work! This one is really starting to come together nicely!!
« Reply #51 on: October 06, 2013, 06:45:09 AM »
What a beast this will be Ian! It's looking very impressive so far and I can't wait to see what you make of the gun positions.
« Reply #52 on: October 08, 2013, 01:40:11 AM »
Beautiful work on the interiors as everyone says... I look forward to getting more pictures!!!!
 :D
Offline Cimmerian
« Reply #53 on: October 08, 2013, 04:33:54 AM »
I have a question...are you really going to put a lid on it and hide all that awesomeness inside?
Incredible work.
Regards, Ken
« Reply #54 on: October 14, 2013, 02:08:39 AM »
The fuselage on this beast is now closed up.
 The ladder came from a set of railway ladders and stairs. It needed a little thinning and I narrowed it slightly and it looks fine. I had to remove the control frame and shorten it a little as it sat too high, I haven't yet reinserted it as I want to finish off the main bodywork first. That is well on its way. This weekend I've finished the interior rigging and added the rear floor, so when that's properly dried I'll fill and sand the gaps, work on the horizontal tail surfaces and fit those, then she should be ready for a coat of primer and no doubt more filling and prep work!
« Last Edit: July 02, 2017, 04:34:51 AM by IanB »
Offline xmald
« Reply #55 on: October 14, 2013, 02:39:44 AM »
When I`m looking at your effort on this model, and how nice it looks makes me want to buy one someday.
One of my favourite under construction threads ever!
Best regards
Filip
« Reply #56 on: October 14, 2013, 02:45:18 AM »
Sorry Ian,
Only just caught up with this - fabulous work!  ;)
« Reply #57 on: October 27, 2013, 01:19:07 PM »
Thanks for all the comments folks!
@xmald - it may well be easier to scratch the whole thing! I believe the ICM kit has better engines, but the wheels on this one are better, so take your pick....
Here's the latest on the "beast":
 I've taken a new approach on the batons which held the fabric in place. I scribed the lines into the wing/tail surfaces and then glued monofilament using ordinary plastic glue. The scribing helps keep it straight and also gives it a little more "bite" to attach and hold firmly - it's not scribed deeply, only two light passes with a scriber is enough. It seems to work, the primer will be the teller....
 I decided to use the kit wings as they are not too bad in profile. Surface detail has all been removed. They have been thinned drastically and corrected for aerofoil section (not perfect, but a heck of a lot better). The lower wings had the rear tips rounded off and the upper wings have been narrowed slightly in chord and lengthened by adding 3mm and 1.5mm plastic strip to the inner edges of the main and outer sections respectively. The wing tips have also been reshaped and thinned so they don't look like the scaffold planks they originally resembled. Ailerons have been scratched from stock sheet.
The wing centre section has been corrected by removing the pointed rear ends, adding .5mm plastic stock on either side to widen it and 1mm at the rear to move the rear edge further aft. I then filed out the inner edges of the sides to widen the gap, and the front edge of the rear spar to move it back to its correct position. Pins will be added to attach the wings. The additions to the wings add a whole 1cm to the winspan!
I've attached the outer sections to the main upper wings and will finish sanding them to obtain the same thickness and section before I scribe and add the "batons".
Thanks for looking in!
« Last Edit: July 02, 2017, 04:41:31 AM by IanB »
« Reply #58 on: October 27, 2013, 01:30:29 PM »
Looking really great Ian! Terrific idea using the monofilament!
« Reply #59 on: October 27, 2013, 03:52:14 PM »
You are making great progress on this model Ian, the use of the mono is a good idea and appears to work well.
