Author Topic: ANSALDO SVA 5 - 1/48 Fly - Ten. Aldo Finzi  (Read 34496 times)
Re: ANSALDO SVA 5 - 1/48 Fly - Ten. Aldo Finzi
« Reply #45 on: July 09, 2013, 05:26:02 PM »
bello, anto'! ;)
really a nice work!
to paint the 5s, probably I would have used the 5s cut in the tape protecting the white base. after painting the final finish, I would have removed the tape. easy easy! ;)
Grazie!
Yes that was the solution, I didn't think at all to that easy easy way, although I saw it in many WIPs...
Will take note for next time!!!!
« Reply #46 on: July 09, 2013, 09:53:15 PM »
Nice work!
« Reply #47 on: July 09, 2013, 10:05:00 PM »
Thanks Bo!
Offline mc65
« Reply #48 on: July 10, 2013, 01:07:16 AM »
really, antonio,
it's a piece of cake! ;)
just try on a dummy kit first, if you are not at ease about...
1356
1358
1490
« Reply #49 on: July 10, 2013, 01:14:00 AM »
Thanks again Paolo,
I think the best for me is to paint the basis in the marking colour, cut the shape with the scissors from masking tape, apply the shape and paint it over.
I've seen your D III and it's really astonishing, hats off!
Antonio
« Reply #50 on: July 10, 2013, 02:49:31 AM »
Hello Antonio:
This is really a neat looking airplane.  I have seen this done before and it is such an impressive looking model when finished with all the wood work, the colorful wings etc.  In fact, I think yours was one I had seen before.  Anyway, you are doing a great job here and I look forward to seeing it as you progress.
Offline Zabu
« Reply #51 on: July 10, 2013, 05:16:20 AM »
Real nice work.
I'm following this one as i have a 1/72 to build too!
Thank you for posting.
« Reply #52 on: July 29, 2013, 07:45:47 AM »
Hallo everybody, thanks Mark and Zabu for following my WIP!
Here are some progress done during the weekend:
Decal work on the fuselage sides:
Rigging coming out of the fuselage were set in place and the two halves were closed:
I had to carve again the openings on the floor after sanding the joint
This is how th model looks like tonite...
In the pas days I studied how to create the anchor points where the rigging is attached on the wings and sketched a drawing of  the solution:
Then I prepared 24 bits of Nickel tube (Inner diam. 0.4 mm / Outer diam. 0.6 mm) each 3 mm long:
Next step will be to complete the upper surfaces of the fuselage, then fix the lower wings and tail planes.
I know the "Acqua / Glicerina" decal is too big... but that was the smaller size I was able to get from my Inkjet without smudging the letters.
Ciao!
Antonio
Offline xmald
« Reply #53 on: July 29, 2013, 07:06:39 PM »
I love your updates Antonio! I remember building one of Smer`s SVA 5 really long time ago... I like this plane very much and yours will be a beauty.
Best regards
Filip
Offline Pete Nottingham
« Reply #54 on: July 29, 2013, 08:43:51 PM »
Doing a good job Antonio.
Pete.
« Last Edit: July 30, 2013, 02:15:42 AM by Pete Nottingham »
« Reply #55 on: July 29, 2013, 11:16:03 PM »
All the hard work you have put into this build
is very evident, Antonio....you are doing a super
job!  Enjoying the updates.  Thank you!
« Reply #56 on: July 30, 2013, 05:14:25 AM »
   Antonio,
 Simply put an Outstanding update my old friend. I love how well the fuselage halves have turned out. Beautifully painted and decaled. Looking forward to what wonders the next will hold.
Offline Zabu
« Reply #57 on: July 30, 2013, 06:23:47 AM »
Molto bello! Very nice!
Great work Antonio. Loving it all the way.
Ciao. Cheers.
« Reply #58 on: August 05, 2013, 07:48:46 AM »
Hi folks!
Thanks everybody for looking and commenting...
I made some small advancements during the WE:
Thank you Mark,
here is some steps ahead made during this weekend:
I decided to made a new tail skid from scratch, the provided in the box (on the left in the pic) was unacceptable to me.
On the right is my tail skid, it's overall 1 cm long and the zoom was so high that the quality of the image turned out bad.
The skid will be painted and completed once glued below the fuselage: the metal piece fixing it to the metalworks on the tail is still missing.
Here is the radiator, I painted  with flat aluminum to make it come out of the dark background painted in Tamiya Burnt Iron.
I added the brass rim closing the hole in the metal grid opening around the prop hub and added the top water tank cork as well.
Top wooden panels and metal engine cowling were painted
Just a couple of shots of the IP just to remember the work done !
I decided to add the leather trim on the cockpit opening. I used a thin plastic pipe painted with vallejo leather colour
Goodnight everybody!
Online RAGIII
« Reply #59 on: August 05, 2013, 08:42:21 AM »
Really nice work Antonio! I like the way that leather cockpit coming came out!
