Author Topic: N-17 Triplane 1/48  (Read 23196 times)
Re: N-17 Triplane 1/48
« Reply #75 on: December 08, 2020, 01:10:33 PM »
 :) Up-date starts on the end on last page  ;)
« Reply #76 on: December 08, 2020, 01:20:06 PM »
That interior is absolutely amazing...and now it is gone  ::) Lovely work T!
« Reply #77 on: December 08, 2020, 11:02:38 PM »
Thanks Rick  :)
Even though that nothing will be seen . I'm glad that I did add the detail , really enjoyed myself and found it to be relaxing .
« Reply #78 on: December 09, 2020, 09:51:50 AM »
Seems have been address which turned out to be quick work . This will get polished out once the the decking is filled . The lacing will get lost in the process but I do have PE to use for replacing that detail .
« Reply #79 on: December 09, 2020, 09:52:14 AM »
« Reply #80 on: December 09, 2020, 09:57:19 AM »
Excellent Terri. I am looking forward to the next two wings  8)
« Reply #81 on: December 09, 2020, 11:19:41 PM »
... and we all know it is there! 8)
really enjoyed myself and found it to be relaxing.
That is the most underestimated and the most important part of the game!
« Reply #82 on: December 10, 2020, 01:02:32 AM »
Thanks Rick and Frank  :)
I filled the front strut mounting locations last night with bits of plastic card . To really pack the hole once the piece is in place I go back over it a few times more with Tamiya extra thin , using the back of the knife handle I press the plastic down until it totally fills it in . Sand this will give a pretty finish then using putty .
Now I can start with more sanding
« Reply #83 on: December 10, 2020, 04:35:27 AM »
Your are working fast on this one Terri - I can barely keep up with you. There is no loss of quality of finish though.
« Reply #84 on: December 10, 2020, 04:40:10 AM »
There is some stunning modelling happening here, Terri! Great progress.... ATB, Marc.
« Reply #85 on: December 10, 2020, 11:53:02 AM »
Thank you Stephen and Marc  :) 8)
Bit more progress done today . The holes are filled on the top decking and sanded smooth . The stitching will be added once the engine and cowl issue is resolved . The engine needs a fair bit of the cylinders removed , but I will thin down the inside on the cowl first . The pencil marks on the fire wall is for the oil tank placement which i still need to cut out of card and sand to shape .This is the only detail I will add to this area , nothing else will be seen . While I was at it I also made up valve stems for the wheels .
« Reply #86 on: December 10, 2020, 11:53:27 AM »
« Reply #87 on: December 10, 2020, 11:53:51 AM »
« Reply #88 on: December 10, 2020, 11:54:17 AM »
« Reply #89 on: December 11, 2020, 01:37:35 PM »
Okay , I came up with a very cunning plan on how to make the engine fit inside the cowl . I spent a few hours thinning the inside down to the point that it is almost paper thin ...okay two sheets thin  ;) But what about the engine !!! Out came the saw and i cut off the flange and removed part of the lower cylinder , a fair bit was removed . and glued back on top of the flange and it now fit's inside the cowl . I managed to break off three off the rocker arms so those will face up wards in the cowl .  Fuselage is polished and the rest of the details have been started . For the lacing I used taiya cut cut 2mm in with and Eduards PE for the rest and wipe up an oil tank .
