Author Topic: N-17 Triplane 1/48  (Read 23227 times)
Re: N-17 Triplane 1/48
« Reply #60 on: December 07, 2020, 01:18:33 AM »
Terri, I would call that a big progress! Beautiful enhancements and painting. Really pity, that many things will be hidden between three wings and a fuselage.
I have so many kits crying "Start me!" and this is one of them ::) ???
« Reply #61 on: December 07, 2020, 01:38:31 AM »
Thanks Frank  :)
True that must of the pit won't been seen once the top wing is in place , but at different angles some can be viewed  ;)
« Reply #62 on: December 07, 2020, 07:37:45 AM »
Beautiful internal details Terri.
« Reply #63 on: December 07, 2020, 12:40:12 PM »
Thanks for the kind comment Stephen  :)
Weathering complete and wiring bracing is finished on the right side of the fuselage . Rudder bar and control column are mounted with their control wires . A seat cushion was made up with plastic card and seat belts are from the spare part box .
Next up-date I should have rest of the rigging and parts in place with the halves closed up .
« Reply #64 on: December 07, 2020, 12:40:37 PM »
« Reply #65 on: December 07, 2020, 10:21:13 PM »
A fine looking interior, Terri.  You're making good progress on this one.
« Reply #66 on: December 07, 2020, 11:20:00 PM »
Fine Terri, but please do not forget to clean the glue line on the fuselage halves!
Offline Radarman
« Reply #67 on: December 08, 2020, 12:05:14 AM »
Terri,
Looks like you have touched all the bases in the cockpit. Like I've said before, you are setting the standard
for Nieuport builds.
                                                  Kevin
« Reply #68 on: December 08, 2020, 05:01:43 AM »
Beautiful job on the innards, T!
« Reply #69 on: December 08, 2020, 11:27:32 AM »
Thanks a lot for dropping by with positive comments , they mean a lot  :)
Frank , no worries the glue edges will be free of paint before gluing .  ;)
« Reply #70 on: December 08, 2020, 01:08:32 PM »
Here is the last look of the pit before the halves are glued together forever and ever !!! I didn't have to trim anything to get stuff to fit . All of the framing matches the other side  :o
Halves are glued up and yes Frank all of the edges are cleaned up of paint before gluing  ;) Lower wing is also glued in place and this is set aside to dry over night . Then the body work can start . All of the top mounting locations for the struts need to be filled . There are a few more details to add and sure but more on those later .
« Reply #71 on: December 08, 2020, 01:08:57 PM »
« Reply #72 on: December 08, 2020, 01:09:23 PM »
« Reply #73 on: December 08, 2020, 01:09:47 PM »
« Reply #74 on: December 08, 2020, 01:10:13 PM »
