Author Topic: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke  (Read 189706 times)
Re: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke
« Reply #270 on: May 22, 2020, 11:59:49 PM »
I really like your light green mix(es) Rick!  Looks very sharp.  Seeing these three in full livery will be a visual treat. ;D
Best regards,
« Reply #271 on: May 23, 2020, 12:31:15 AM »
Best regards,
Thanks Bob! Today's Mission is the tan and dark green!
« Reply #272 on: May 23, 2020, 06:11:05 AM »
So, I ran out of Tamiya thinner and Lacquer thinner and only got one more color added to the Bleriot and Kelner built SPADS. Going out tomorrow in hopes of getting both but should at least be able to find the Lacquer Thinner at Wal Mart. Probably will need to fine tune the beige areas on the fuselage as the other colors are applied.
PS: Although it appeas that there is grey in front of the beige it is lighting. The areas in front of the beige are actually light green!
PPS: The beige has the same Aluminum dope mixture as the green but it is not as evident. Wondering if the darker the color the less it shows  ::)
« Last Edit: May 23, 2020, 06:15:14 AM by RAGIII »
Offline Radarman
« Reply #273 on: May 23, 2020, 06:28:29 AM »
RAGIII,
Good luck during your hunt for thinner. I look forward to seeing the next colour you apply.
        Happy modeling,
        Kevin
« Reply #274 on: May 23, 2020, 06:30:11 AM »
RAGIII,
        Happy modeling,
        Kevin
Thanks Kevin. It is a bit frustrating as I should have been able to get the Dark green done today!
Offline smperry
« Reply #275 on: May 23, 2020, 06:34:51 AM »
That is majorly annoying. I sympathize. Air brush ran out of CO2 in the middle of a job, so I know the feeling.
sp
« Reply #276 on: May 23, 2020, 07:04:05 AM »
sp
Well It is annoying but I guess it could be Much worse! Just really wanted to get the other color done today  8)
« Reply #277 on: May 23, 2020, 08:04:16 AM »
How annoying but hopefully the hunt for thinner will be successful. The paint is going on very smoothly though and the colours look  fantastic.
Offline RLWP
  • Bodger
« Reply #278 on: May 23, 2020, 08:13:23 AM »
When you get there, there is something weird about the undercarriage in this kit
The legs are square, the bottom part moulded on the axle is correctly profiled
I've just sorted that on mine
« Reply #279 on: May 23, 2020, 08:18:34 AM »
Thanks Richie. Like I said I am sure I can get Lacquer thinner. I Like the Tamiya X20A better for thinning the paint but the Lacquer thinner works!
Well Damn, Hurry up and post because I can use your insight!
Offline RLWP
  • Bodger
« Reply #280 on: May 23, 2020, 08:29:10 AM »
Can't find my camera
« Reply #281 on: May 23, 2020, 08:41:17 AM »
That is NO excuse Richard! I have been using My Phone as My Camera seems to have gone Belly Up    ;D
« Last Edit: May 23, 2020, 09:38:12 PM by RAGIII »
« Reply #282 on: May 24, 2020, 08:20:40 AM »
I managed to pick up the Lacquer thinner today so I did make some progress. I masked for the Dark Green then sprayed it on both Models. I had mentioned earlier that I had a sophisticated Masking Method, Silly Putty! Just a bit of re shaping needed on some areas but overall it went well!
« Reply #283 on: May 24, 2020, 08:23:20 AM »
Moving along nicely !
« Reply #284 on: May 24, 2020, 08:31:27 AM »
Thanks Amigo! By the way photo 3 &4 are Lukes Bleriot built SPAD and #5 will be Rickenbackers Kelner built bird!
One or two more:
« Last Edit: May 24, 2020, 09:05:34 AM by RAGIII »
