Author Topic: Fokker D.VII (OAW), Rudolf Stark, Jasta 35b. Eduard 1/48 (finished)  (Read 16630 times)
Offline Robin
Re: Fokker D.VII (OAW), Rudolf Stark, Jasta 35b. Eduard 1/48
« Reply #30 on: November 07, 2019, 01:27:52 AM »
Thanks gentlemen,
Wings are ready....yay!
Final touches took me the whole day, but ready now.
166 decals plus about a dozen of small decal patches to fix a few mistakes.
I enjoyed doing this "hardcore lozenge"....hell of a job, but fun. I happily do it again. :)
I love the smell of Microsol in the morning. 8)
These Microsculpt decals respond fantastic to Sol.
The leading edge and wing tip tapes were not in the Eduard manual, but I had enough spares to make them.
Wasn't easy to put them on the edge...lots of Microsol to get them in place.
Some crazy small, but still readable decals.
With this out of the way...done the internal rigging...for what's worth.
Next...engine and close the fuselage.
Robin  :)
« Reply #31 on: November 07, 2019, 03:21:56 AM »
This is really shaping up to be a superb model. Looking forward to more.
« Reply #32 on: November 07, 2019, 07:30:10 AM »
Superb indeed! Looking absolutely gorgeous!
« Reply #33 on: November 07, 2019, 09:37:59 PM »
Inspiring work!
Offline Robin
« Reply #34 on: November 09, 2019, 08:56:33 AM »
Thanks gentlemen. :)
Did the engine...
Since almost nothing will be visible in the end, I put very little effort in it.
Only added the spark plug cable tubes...and those won't be visible either. ;D
After adding the MG support bar....closed the fuselage...
I can now start working on the outside. Lozenge, paint, tail...bits and bobs. All fun jobs. :)
Oh...and did the basic painting of the prop with my prop painting tool.
Don't expect wonders from it. The result gives me a starting point for brush painting the prop.
1. Start with a light colour for good contrast...
2. Clamp prop behind the louvres...
3. Airbrush....
4. Done...ready for brush painting now.
Some new goodies to play with....
More soon,
Robin :)
« Reply #35 on: November 09, 2019, 11:32:34 AM »
Absolutely top-notch work, Robin. Thanks for sharing it.
« Reply #36 on: November 09, 2019, 09:21:28 PM »
Ahh, now I understand how your prop painting tool works.  Very inventive.
Great looking work on all the bits, Robin.  Clean work on the engine and interior.
Offline Gene K
« Reply #37 on: November 09, 2019, 10:43:13 PM »
Wish I had your understanding.  :-[
Gene K
« Reply #38 on: November 09, 2019, 11:34:03 PM »
Nice job on the wings Robin  :)
Offline Robin
« Reply #39 on: November 10, 2019, 09:44:10 AM »
Thanks guys and gal.
"The Case Of The Two Lilacs" ;D
My take on them....
Tomorrow: varnish and lozenge.
And finally received the Maxima Chameleon line...
I was wondering about BvB's expensive taste for rigging line, but it seems I ordered 1000 metres of it. :o
Well, I can also do the Albi D.II rigging now.
Robin  :)
« Reply #40 on: November 10, 2019, 08:05:36 PM »
What brass tubes do you use for that rigging line?
0.12mm sound a bit thick to get it two time trough my 0.4mm brass (inside 0.2). For my Gaspatch 1/48 turnbuckles even 0.4mm looks thick, but I have not found 0.35mm tubes.
By the way, you prop masking tool is available commercially in 1/32 scale here:
http://www.radubstore.com/index.php?main_page=product_info&products_id=429
Offline AndRoby67
« Reply #41 on: November 10, 2019, 11:40:41 PM »
Many compliments for your steps, clean work.
Roberto
« Reply #42 on: November 11, 2019, 02:19:45 AM »
A thousand metres... that's going to take a lot of models! 😀
Offline Robin
« Reply #43 on: November 11, 2019, 03:02:03 AM »
Thanks guys,
Frank, I'll use 0,5mm tubes....I know they're out of scale, but I can live with that.  :)
I've seen the 1/32 prop painting tool. I was first! 2011. ;D Maybe they "borrowed" my idea, or came up with the same idea...not knowing about mine.
I showed it on the Aerodrome forum in 2011.
Fredrik...yeah...I need more models!   8)
Today was another nice day at the bench...
Eduard has the placement of the Balkenkreuzen on the fuselage wrong.
In front of the lilac painted rear....they should be partly covered by it.
Easy to fix.
Also wrong....the width of the lilac fuselage band...too narrow. Of course also easy to fix.
A bit more work will be making new "Li" letters. The decals are way too skimpy and a bit too tall. they look stretched. I can make new ones, not a big deal.
Robin  :)
« Last Edit: November 11, 2019, 03:10:12 AM by Robin »
« Reply #44 on: November 11, 2019, 03:55:03 AM »
Well, I can't see any other solution to the problem of too much rigging material! 😁
