Author Topic: 1/32 WNW Albatros D.V Richthofen  (Read 38626 times)
Offline xan
Re: 1/32 WNW Albatros D.V Richthofen
« Reply #45 on: October 22, 2018, 02:45:01 PM »
Very beautifull work !
Loocking for your brushes i find that in Amazone...
it seems ok for our works isn't it iI mean, we didn't need larger...
Xan
Offline Ryan
« Reply #46 on: October 22, 2018, 11:05:03 PM »
Thanks for checking in Xan.
You can find an assortment pack of those in different sizes, I would get those.
https://www.amazon.com/Value-Pack-10-Pc-Foam-Paint-Brush/dp/B003UHJDAS
I probably need to show a step by step process as the effects don't always require a foam brush.
Ryan
Upcoming: Not sure!
« Reply #47 on: October 23, 2018, 05:31:44 AM »
I really like what you are doing here Ryan! Looking great.
Agree, looking good as it moves along !
« Reply #48 on: October 23, 2018, 06:51:45 AM »
Some of that wood graining is just excellent.
Offline Ryan
« Reply #49 on: October 23, 2018, 06:57:32 AM »
Only some of it!  ;D
Hehe just kidding, thanks again GazzaS
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #50 on: October 25, 2018, 01:23:30 PM »
Evening builders,
This hardly counts as a true update, but I was pretty pleased with the outcome. The wood process was explained earlier, the grey green is hand painted from Vajello and the wash is Tamiya Dark Brown Panel Liner.
Still needs a flat coat and the wash my be too dark for some, but in shadow, at the back of the engine it should be just fine.
Red Baron by The 3rd Placer, on Flickr
Thanks
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #51 on: November 05, 2018, 11:50:54 PM »
Taking a break from simulated wood, I started the engine construction.
I have a the PE HGW/ Eduard ignition harness en route and should have it today, more work after I get that installed.
Thanks
Ryan
Upcoming: Not sure!
« Reply #52 on: November 06, 2018, 12:06:35 AM »
Nice clean start on the engine Ryan
Offline Ryan
« Reply #53 on: November 06, 2018, 12:38:56 AM »
Thanks RAGIII, do you recall how tightly the lower wings fit into the fuse?
Will the wing root fit into the contoured notch on the fuse sides, did you have to clean it up a bit to fit tightly?
Ryan
Upcoming: Not sure!
« Reply #54 on: November 06, 2018, 04:34:23 AM »
Very effective wood simulation!!
« Reply #55 on: November 06, 2018, 04:54:42 AM »
Ryan
They are like the rest of the kit a tight fit. During my build there was some discussion on slightly sanding and or scraping the root portion to get the right dihedral. It started on this page of my build log.
https://forum.ww1aircraftmodels.com/index.php?topic=8732.315
There were also other comments in either Trackpads, GazzaS build or another about removing a tab. Can't remember for sure but others might.
« Last Edit: November 06, 2018, 07:20:02 AM by RAGIII »
Offline Ryan
« Reply #56 on: November 06, 2018, 05:35:46 AM »
Thanks RAG, very helpful!
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #57 on: November 06, 2018, 05:56:35 AM »
Steve, thanks its been fun...still learning as this will be my first bi-plane model.
Ryan
Upcoming: Not sure!
« Reply #58 on: November 06, 2018, 07:23:00 AM »
Ryan
One other thing that was probably just my build. I found that the dihedral turned to anhidral depending on which wing I inserted first. Test Fit SEVERAL times before gluing!
Offline Vicious
« Reply #59 on: November 06, 2018, 07:28:18 AM »
Since I'm doing just the same model ... plus it's my first WnW and biplane ... I'm greedy looking at your post, I used the same set of HGW but I found that the electrical wiring in PE being flat are ugly but the rest is fine, I thought to use the plates with the information on the engine to give a little 'texture and then glue on the decals of the kit ... hoping that has the desired effect
