Author Topic: 1/32 WNW Albatros D.V Richthofen  (Read 38610 times)
Re: 1/32 WNW Albatros D.V Richthofen
« Reply #15 on: October 09, 2018, 03:48:05 AM »
That's no doubt a fine representation for wood. You used a sponge instead of a brush? I also have a small set of Abteilung Oil paints and I am not too convinced of their quality, but that shade obviously does what it should do.
Offline Ryan
« Reply #16 on: October 09, 2018, 04:00:49 AM »
I find the quality to be very good.
This was used to make the grain, I notched it to fit the size I needed.
Foam Brush by The 3rd Placer, on Flickr
I applied pretty wet to get this effect and of course trial and error.
Ryan
Upcoming: Not sure!
« Reply #17 on: October 09, 2018, 05:32:10 AM »
Looks like a great tool, thanks for showing.
i have those, mainly for creating chipping effects, but they are a little bit on the soft side
Offline Ryan
« Reply #18 on: October 09, 2018, 06:41:45 AM »
Those sponge brushes are quite stiff and really inexpensive.
Upcoming: Not sure!
« Reply #19 on: October 09, 2018, 07:08:16 AM »
Ordered. Great stuff.
I am keen on seeing your Albatros coming together.
Offline Ryan
« Reply #20 on: October 09, 2018, 07:12:20 AM »
I was drawn to them because of the chisel edge, I'll take some pics of the ones I modified to fit the Albatros.
When I tried to use a sponge clamped in tweezers I kept chipping my paint job with the tweezers.
Thanks for your comments Borsos.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #21 on: October 09, 2018, 10:16:19 PM »
Borsos,
Here are the other participants in the wood technique.
The regular brushes are used to spread the oil and the sponge is used to clean up and refine the grain effect.
You can see the notch I cut into the sponge to allow it to custom fit the area I needed. (I imagine also could have cut it to a radius edge to work a little better)
Sponge applicator by The 3rd Placer, on Flickr
Ryan
Upcoming: Not sure!
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #22 on: October 09, 2018, 11:18:31 PM »
Great progress so far!
In regards to the sponge brushes...well I just cut a piece of sponge to the required size, stick it to my lockable pliers and use it absolutely the same way.... it costs me generally nothing as tehre are some sponges coming with aftermarket for example :)
Think globally, act locally!
Offline Ryan
« Reply #23 on: October 09, 2018, 11:32:01 PM »
Absolutely, the problem I was having is I was nicking the paint off of corners with my locking tweezers, there is no chance of this wit the brush pictured.
Thanks for your comments.
Ryan
Upcoming: Not sure!
« Reply #24 on: October 09, 2018, 11:34:27 PM »
Thanks Ryan!
I too worked with sponges in pliers (for chipping effects, not for woidgrain) and I always found the Sponge being too soft for the things I wanted to do with it.
Offline Ryan
« Reply #25 on: October 09, 2018, 11:51:40 PM »
You will like these I hope, there is a hidden plastic support inside the foam to keep it stiff.
Ryan
Upcoming: Not sure!
Offline kornbeef
« Reply #26 on: October 10, 2018, 05:07:04 PM »
I have a question for the Albatros experts (or in general German AC production) regarding the finish of aluminum interior parts.
Are these dressed like the Fokker Eindecker cowling?
Thanks for any help, some grainy pics suggests that these parts were simply not an even finish.
Ryan
No the aluminium sheet wasnt machined like Fokker not from what I've seen anyway. Just plain unpolished metal
Offline Ryan
« Reply #27 on: October 11, 2018, 12:05:04 AM »
Thanks, I noticed the reproduction pics at the Vintage Aviator did not show the turning...should have looked there first!
Ryan
Upcoming: Not sure!
« Reply #28 on: October 14, 2018, 07:15:13 PM »
Nice!
Gaz
Offline Ryan
« Reply #29 on: October 14, 2018, 10:28:03 PM »
Thanks Gaz, I hope to update later with more progress.
Ryan
Upcoming: Not sure!
