Author Topic: 1/32 WNW Albatros D.V Richthofen  (Read 38803 times)
Offline Ryan
Re: 1/32 WNW Albatros D.V Richthofen
« Reply #60 on: November 06, 2018, 07:47:47 AM »
Thanks RAG, very helpful!
Ryan
One other thing that was probably just my build. I found that the dihedral turned to anhidral depending on which wing I inserted first. Test Fit SEVERAL times before gluing!
Yes, good advice.
Upcoming: Not sure!
Offline Ryan
« Reply #61 on: November 06, 2018, 07:50:50 AM »
Since I'm doing just the same model ... plus it's my first WnW and biplane ... I'm greedy looking at your post, I used the same set of HGW but I found that the electrical wiring in PE being flat are ugly but the rest is fine, I thought to use the plates with the information on the engine to give a little 'texture and then glue on the decals of the kit ... hoping that has the desired effect
Yes the PE is flat, but it will be just fine for me...I esp like the distributer bundles.
I might thicken them up with paint, haven't decided yet, thanks for looking and chiming in sir, good luck with your build.
Ryan
Upcoming: Not sure!
Offline Vicious
« Reply #62 on: November 06, 2018, 08:02:37 AM »
the distribution are ok but the spark plug cable for me looks also little bit short and not so easy to handle,i tried one,i think i go with some lead wire 0.2mm or something similar....anyway great looking wood!!... ;)
Offline Ryan
« Reply #63 on: November 06, 2018, 08:15:24 AM »
I'll check it out, thanks for the warning. :)
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #64 on: November 12, 2018, 11:02:14 AM »
Work continues on the D.V, the following pics are the fitment of the engine bay bulkheads to the fuselage.
Red Baron by The 3rd Placer, on Flickr
And with the engine test fit.
Make no mistake this is a really tight fit is was a lot of work just to get it this far...but eventually it got much better.
Also did a little work on the seat and bulkhead.
More soon.
Ryan
Upcoming: Not sure!
« Reply #65 on: November 12, 2018, 04:42:12 PM »
Very nice work, You have matched the wood tones really good.This will be a great tribute to Manfred (Manni ;)) Richthofen.
Bye,
Offline Ryan
« Reply #66 on: November 12, 2018, 05:17:06 PM »
Thanks very much Manni, it’s been a chore not to damage it during construction, the Vajello based effect is quite fragile.
Ryan
Upcoming: Not sure!
« Reply #67 on: November 13, 2018, 01:13:03 AM »
Frames and engine bearers look great in place! Your wood tones look outstanding!
Offline Ryan
« Reply #68 on: November 13, 2018, 04:30:46 AM »
Yeah I eventually wrangled them in there!
Thanks.
Ryan
« Last Edit: November 13, 2018, 08:09:35 AM by Ryan »
Upcoming: Not sure!
« Reply #69 on: November 14, 2018, 02:16:25 AM »
As others have commented, the wood tones are truly realistic. A wonderful build going on here - much to learn obviously.
Offline Ryan
« Reply #70 on: November 14, 2018, 04:46:40 AM »
Thanks Stephen, I have much to learn though...this is my first Biplane.
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #71 on: November 14, 2018, 12:45:45 PM »
No build update tonight, but I did want to show the Hobby Zone Jig I am assembling. The pics, I hope, give a sense of how large this thing is.
Zee Jig is Up by The 3rd Placer, on Flickr
And finally as a further illustration of size, this is the 1/32 Special Hobby Morane!
Ryan
Upcoming: Not sure!
Offline Ryan
« Reply #72 on: November 14, 2018, 12:50:49 PM »
Like all HZ products it is of particle board construction and very well made, just need wood glue and patience.
Ryan
Upcoming: Not sure!
« Reply #73 on: November 19, 2018, 02:16:12 AM »
Wow!! That's a Gotha sized jig!!
« Reply #74 on: November 19, 2018, 03:26:58 AM »
Jig? Who needs a jig when there are paint pots, blocks of wood, books etc lying around the place!
Lokks really good to me but I think a litlle too large for True Scale models.
