Author Topic: WnW Jeannin Stahltaube  (Read 11471 times)
Offline GB
« on: May 12, 2018, 06:59:50 AM »
I picked this kit up along with the J.1 at the Wingnut Wings Scale Model Expo stand last month. There is something quite beautiful about this ungainly looking plane and after deciding to put any fears of that rigging to one side, have pulled this out of the stash for my next build.
Planning on using some HGW belts, Uschi woodgrain and Aviattic decals and probably some Gaspatch turnbuckles where appropriate.
Will be making a start shortly, so stay tuned....
Re: WnW Jeannin Stahltaube
« Reply #1 on: May 12, 2018, 08:26:40 AM »
Looking forward to following your build!
« Reply #2 on: May 12, 2018, 08:48:48 AM »
Nice choice, I too look forward to your progress.
Offline eclarson
« Reply #3 on: May 12, 2018, 02:00:54 PM »
Cool!  Glad to see another Taube build starting.  :)
Eric
« Reply #4 on: May 12, 2018, 02:11:17 PM »
Following, will be interesting to see this.
Offline GB
« Reply #5 on: May 12, 2018, 07:07:32 PM »
Welcome along chaps. Hope you enjoy the ride  :D
Okay, first step is the cockpit floor. Started by spraying the rear section gloss white (pre shading with Tamiya Smoke), masked off the frame and sprayed that light green and used Aviattic's CDL clear decal. Ezi-Line was then used for the bracing wires....
Offline GB
« Reply #6 on: May 12, 2018, 08:04:03 PM »
Front section is again painted white. This time I pre-shaded the section with clear orange and a little smoke. Then I used some Uschi wood grain decals with plenty of micro sol to help them sit snugly over all teh detail....
Set aside overnight now to fully dry.
« Reply #7 on: May 12, 2018, 08:23:01 PM »
Awesome start! The fabric and wood look perfect!
« Reply #8 on: May 12, 2018, 08:25:25 PM »
Very nice indeed!  Those wood grain decals are awesome!
Offline aliluke
« Reply #9 on: May 12, 2018, 08:59:47 PM »
Hi Gary
It already looks really great! Man you are faster than Ben Lam (Kiwi reference from a Hurricanes fan)! I struggle to do half of what you do in ten times the time. I look forward to more updates.
Alistair
Offline rhwinter
« Reply #10 on: May 13, 2018, 12:05:24 AM »
Good to see another Taube being beautifully built!
Offline GB
« Reply #11 on: May 13, 2018, 07:21:34 PM »
Thanks guys.
Couple of steps forward. Uschi woodgrain decals applied over white basecoat tinted with clear orange. Ezi-line for rigging and control cables. Fuel filter is replaced with a scratchbuilt glass tube made from heat stretched sytrene and replacement cable on the tacho...
Offline hiddeous1973
« Reply #12 on: May 13, 2018, 08:09:18 PM »
Very, very nice!
will be following this one as well, sure to be an other winner.
What sceme are you planning to do?
Offline rhwinter
« Reply #13 on: May 13, 2018, 08:39:29 PM »
Wow, what a lot of rigging inside the fuselage! Wasn't aware of that before.
« Reply #14 on: May 14, 2018, 08:30:57 AM »
Colors, weathering, rigging, and detail all look beautiful.
