Author Topic: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals  (Read 56714 times)
Offline krow113
Re: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals
« Reply #90 on: June 11, 2018, 12:52:49 AM »
Slowly , exorbitantly ,expertly ,  the Dolphin proceeds.
Watching.
« Reply #91 on: June 11, 2018, 02:32:23 AM »
Watching.
Thanks Steve  ;D I am now at the point where all 3 of my builds need similar weathering techniques so I can proceed from one to the next with little delay. At least two of them " should" speed up a bit now  :o
Offline krow113
« Reply #92 on: June 11, 2018, 02:35:03 AM »
Hmmmm...
A little cheating perhaps!? lol
I don't blame you , I have numerous kits parked at the paint shop door. Its a good way to focus but don't use all the same procedures on alla the models!
Best of luck.
« Reply #93 on: June 11, 2018, 02:39:45 AM »
Hmmmm...
Best of luck.
Actually I am varying the techniques on the same aircraft for different surfaces  ;D
Offline Iancshippee
« Reply #94 on: June 12, 2018, 07:26:21 AM »
Your Dolphin is looking excellent, Rick! I like this scheme so much i think i’ll do that one first! I love the way the blue pops
« Reply #95 on: June 12, 2018, 08:11:01 AM »
Thanks for looking in and the kind comment Ian. I am looking forward to seeing your build of this one!
« Reply #96 on: June 13, 2018, 05:59:10 AM »
Looking  good, await weathering !
« Reply #97 on: June 13, 2018, 07:12:49 AM »
Thanks Amigo! The weathering has begun on this one and the other builds.
« Reply #98 on: June 14, 2018, 03:03:41 AM »
I have used a Filter/Wash of Oils on the undersurfaces. I will add some Earth Tones on the lower wing after rigging and decaling. I had an OH SH"? moment while applying the sealing coat of future. My water trap was apparently too full and had a spray of future mixed with water come out of the airbrush. ( I was actually spraying the Albatros DV at the time ) with the Dolphin wings drying on the bench. So...I tapped the moisture release and sent water everywhere in puddles all over the Dolphin wings.  I managed not to panic and as hoped the water dried and left no ill effects  8) I read that several Dolphins in 19 Sq. were retired from oil soaked wings so I went fairly heavy near the fuselage with the weathering.
The upper surfaces showing the results of the Oil Dot weathering a little better than last update...I hope!
« Last Edit: August 02, 2019, 10:13:51 PM by RAGIII »
guitarlute101
« Reply #99 on: June 14, 2018, 03:16:48 AM »
Shaping up nicely Rick, I really like the underwing staining.
« Reply #100 on: June 14, 2018, 03:19:38 AM »
Thanks Mark. Your comment is greatly appreciated!
« Reply #101 on: June 14, 2018, 03:51:19 AM »
You're really cruising along on this Dolphin.  I like the subtle staining around the engine area.  Should be rigging in no-time.
Gaz
« Reply #102 on: June 14, 2018, 04:26:05 AM »
Thanks Gaz! Still a bit to do once the final clear finishes are applied. That being said I can see having the upper wing mounted on this one and the Albatros DV this week  8)
Offline NinetythirdLiberator
« Reply #103 on: June 14, 2018, 05:14:44 AM »
I like the wash and oil spots!  Looks great.  This will look awesome when done.  Hurry up, Rick!!!  ::)
Dan
« Reply #104 on: June 14, 2018, 05:34:48 AM »
Dan
Thanks Dan, I appreciate the compliments! As for Hurrying, for me I am  ::)
