Author Topic: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals  (Read 56794 times)
Online dr 1 ace
Re: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals
« Reply #135 on: July 13, 2018, 03:30:32 AM »
Whole project is coming along nicely, really shaping up !!!!
« Reply #136 on: July 13, 2018, 08:28:23 PM »
Thanks Amigo! I started another 10 days off from work yesterday so I hope to post this in the Completed Models section soon  ::)
« Reply #137 on: July 19, 2018, 08:41:29 AM »
The inner bay has been rigged. Need to paint the wires then add the bracing between the interplane struts.
« Reply #138 on: July 23, 2018, 03:08:36 AM »
In her blue dress even this lady starts to attract me. Very nice progrss Rick!
« Reply #139 on: July 23, 2018, 03:42:03 AM »
I am due to be away for a few days so I just dropped by to see if any progress has been made. I suspect that when I return this one will be finished - and in your growing collection of mini-masterpieces. Good luck.
« Reply #140 on: July 23, 2018, 04:43:34 AM »
Thanks Andreas. The Dolphin is not a graceful aircraft but it does kind of grow on you. This scheme is one of a few that are more than just plain old PC10.
Thanks as always Stephen. As for being completed I am getting closer I am attaching another update The rigging is complete with the exception of a few control surface lines and horns. Touching up the rigging exit holes is underway
« Reply #141 on: July 24, 2018, 07:05:51 PM »
Just awesome, Rick!
Gaz
« Reply #142 on: July 24, 2018, 11:29:51 PM »
Just awesome, Rick!
Gaz
Thanks for looking in and commenting Gaz! The ailerons are now attached to the lower wings, rigging lines are painted steel, Lower wing roundels are on, ( with NO Issues), etc. Speaking of the roundels I tried something unheard of I used room temp. water instead of hot or warm water. The roundels took a few seconds longer to come off of the backing but didn't tear and actually adhered tp the detail better. Could be dumb luck but I think I will try this when I build my Camel  :-X
Offline aliluke
« Reply #143 on: July 25, 2018, 02:44:58 PM »
Just been back through your log Rick. Wonderful building and the result looks really great. I'm still at odds with the look of the Dolphin as an aircraft but you've made a beauty of one.
Alistair
« Reply #144 on: July 25, 2018, 11:25:41 PM »
Alistair
Thanks Alistair. I appreciate the comment. As for the "Look" of the Dolphin as an aircraft she may be ungainly but does grow on you  8) Performance wise one of the best in the war by all accounts.
Offline ondra
« Reply #145 on: July 26, 2018, 04:40:28 AM »
Brilliant work, old friend, very well done!
Ondra
« Reply #146 on: July 26, 2018, 10:16:41 PM »
Sure looks like a nice, clean build.  Are you planning on some weathering?
« Reply #147 on: July 27, 2018, 08:04:53 PM »
Ondra
Thanks Ondra. I always appreciate your support.
Thanks for the positive comment. As for weathering I have already done some oil dot stuff on the wings just hard to tell from the glossy finish and my photography/ I will add just a bit during the final finishing stage.
« Last Edit: July 27, 2018, 09:49:45 PM by RAGIII »
« Reply #148 on: July 31, 2018, 11:48:22 PM »
The last update for this build log. I have completed the rigging. Now just a bit of weathering and a couple of small touch ups and parts to add.
More Photos in Completed Models:
https://forum.ww1aircraftmodels.com/index.php?topic=9779.msg178437#msg178437
« Last Edit: May 28, 2019, 11:35:47 PM by RAGIII »
