Author Topic: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals  (Read 56273 times)
Re: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals
« Reply #105 on: June 15, 2018, 07:06:10 AM »
I applied the roundels to the upper wing. Like Many before me with the last couple of WNW releases I had a small amount of difficulty with the decals. I had to use a combination of heat, future, and Micro Sol to get them to lay down. On one aileron all went well initially then when I looked later the whole right corner, about 1/4 of an inch all the way across the corner, was gone! I was able to use the Valejo blue that seems to match very well, to touch up.
« Last Edit: June 15, 2018, 07:21:54 AM by RAGIII »
« Reply #106 on: June 15, 2018, 08:12:25 AM »
   That's a fortunate and nicely executed recovery Rick! Has anyone queried Wingnut Wings on these recurrent decal problems? They have obviously changed something as their decals used to be terrific.
« Reply #107 on: June 15, 2018, 08:33:21 AM »
Thanks Lance. As for reporting the issues to WNW I don't know. I do know Many have reported cracking and breaking as well as issues with the decals conforming to ribs, in particular the Camel and Dolphin roundels.
« Reply #108 on: June 15, 2018, 02:26:12 PM »
This is looking even better at every update. Decals touch ups are invisible.
« Reply #109 on: June 15, 2018, 09:43:31 PM »
Thanks for the comment. I went back and looked this morning and I must admit I exaggerated a bit. The missing piece was only about 1/8th of an inch across the corner. Still annoying!
« Reply #110 on: June 16, 2018, 06:23:30 AM »
Roundels look great!  I've never been really comfortable with large decals, usually modelling in 1/48.  These 1/32 nat'l markings stretch my sensitivities a bit.
Gaz
« Reply #111 on: June 16, 2018, 08:49:02 AM »
Gaz
Thanks Gaz. As for Large roundels I have built the Snipe and SE5a and had No Issues. Many others have built DH9, Ninaks, FE2bs, DH2s etc. with no issues. It seems that with the release of the Camels suddenly there was a difference in how the WNW roundel decals perform. Some have had No Issues but many more have!
Offline Iancshippee
« Reply #112 on: June 16, 2018, 11:57:50 AM »
With my Triplane, I didn’t have any roundel issues, but I did have a lot of issues with rudder blazes. Both the kit ones and the pair i’ve nabbed from the RFC Pup kit refuse to settle down and got very brittle when trying to coax them! I have a Pheon set for a Pup to try at some point. Your repair is excellent, you’d never know by looking.
« Reply #113 on: June 16, 2018, 09:22:15 PM »
Thanks for the comment on the repair. Come to think of it I also built a Triplane with No Roundel issues  8) As for the rudder stripes I have been in the habit of painting them for years. Never could get any decals to look quite right...by any Manufacturer  :-[
« Reply #114 on: June 20, 2018, 08:16:48 AM »
I added the upper wings today. It took about 15 to 20 minutes to place the struts in place, slide the wing panels on, and then use Tamiya Extra thin Cement to glue.
I also added the exhaust , windscreen, and gunsight.
No Jig Needed   8)
« Last Edit: August 02, 2019, 10:15:01 PM by RAGIII »
Offline Iancshippee
« Reply #115 on: June 20, 2018, 11:16:49 AM »
Truly excellent! It just keeps looking better and better!
« Reply #116 on: June 20, 2018, 11:26:24 AM »
Looking good Rick, she is turning out quite nicely (serious understatement).   :D :D :D
« Reply #117 on: June 20, 2018, 06:25:38 PM »
Thanks for the compliment! I appreciate you following along
« Reply #118 on: June 20, 2018, 07:47:47 PM »
Thanks Juan. I always appreciate your kind comments.
« Reply #119 on: June 20, 2018, 08:08:57 PM »
looking good, Rick!
