Author Topic: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals  (Read 56091 times)
Re: WNW Sopwith Dolphin 1/32nd scale. 19 Squadron RAF: Pheon Decals
« Reply #75 on: May 30, 2018, 09:51:49 PM »
A couple of not so great photos showing where I am now. All of the cowl pieces are attached as well as the Vickers. I also drilled out all of the rigging holes. Only broke 5 bits during the process  ::)  Some touch up painting was done after the photos, in particular the left wing root and adjoining fuselage. I have taped off the upper surfaces this morning in order to spray the unders CDL. Better photos later...I hope.
Offline Trackpad
« Reply #76 on: May 31, 2018, 07:23:49 AM »
Rick, very nice work. It's really beginning to look the part, I'd say. I've got your thread bookmarked against the time when I start my Dolphin. Keep up the excellent work!  8)
Cheers!
« Reply #77 on: May 31, 2018, 08:02:45 AM »
Thanks Gary. Personally I have Przemo and a couple of others bookmarked  ;D
« Reply #78 on: May 31, 2018, 03:13:21 PM »
Great updates, and looks very nice at this stage.
« Reply #79 on: May 31, 2018, 06:02:37 PM »
Very nice looking Rick.  I like the bit of fabric behind the seat.
Gaz
« Reply #80 on: May 31, 2018, 09:17:17 PM »
Thanks for looking in and commenting Giuseppe!
Gaz
Thanks Gaz!
« Reply #81 on: June 03, 2018, 05:36:23 AM »
I have been working on the Dolphin in the last couple of days. The undersurface colors have been added and a slight turnaround of PC 10 using Tamiya Tape for Curves.  I will post photos later.
A question: The Osprey book shows the Interplane struts as wood and the Pheon Decals Battleship Grey. Now I trust Rowans research so will most likely go with the grey but thought it couldn't hurt to ask  8)
« Last Edit: June 03, 2018, 04:05:35 PM by RAGIII »
Offline ondra
« Reply #82 on: June 03, 2018, 05:00:06 PM »
Lovely work, Rick, well done!
Ondra
« Reply #83 on: June 03, 2018, 11:48:05 PM »
Rick,
    The Cross and Cockade Dolphin book has numerous references to "tubular steel' cabane struts on the production version but I couldn't find a definite statement on the interplane main struts. It also mentions that the wood (ash) undercarriage struts on the early prototypes were replaced by tubular steel on the production versions.
    The section on the restoration of C3988 however illustrates new carved ash wing struts used in the project. I'd say they were wood as shown in the book and often painted in that common "Battleship Grey" we see on other Bristish aircraft of the period.
    Hope this helps.
« Reply #84 on: June 04, 2018, 03:13:06 AM »
Ondra
Thanks Ondra. I appreciate you looking in and commenting!
Rick,
    Hope this helps.
Thanks for taking the time to look Lance. I think I will go with the Battleship Grey unless other info is provided soon.
« Reply #85 on: June 04, 2018, 07:17:23 AM »
 "I think I will go with the Battleship Grey unless other info is provided soon."
   That's the direction I'm going to go on mine Rick.
« Reply #86 on: June 10, 2018, 10:08:47 AM »
The Latest on the Dolphin. I have started applying the Pheon Decals and have done an Oil Dot weathering technique to the wings. Not really visible in the photos but the effect gives some texture and variance in colors.
« Reply #87 on: June 10, 2018, 07:54:44 PM »
Nice!
« Reply #88 on: June 10, 2018, 09:38:35 PM »
It is looking great, Rick!
« Reply #89 on: June 10, 2018, 11:35:15 PM »
Nice!
Thanks Gaz.
Thanks Andreas. Your comments are appreciated.
