Author Topic: Morane-Saulnier Type "N", Special Hobby 1/32  (Read 63230 times)
Offline Umlaufmotor
Re: Morane-Saulnier Type "N", Special Hobby 1/32
« Reply #135 on: May 16, 2022, 04:41:24 AM »
Lightly sand and polish with steel wool, add some paint - done.
The little thing works  8)
Servus
Bertl
Offline Umlaufmotor
« Reply #136 on: May 16, 2022, 04:45:43 AM »
Here the air pump is attached in the cockpit.
.....something faint to see, the hole in the end cap.
From there, the pressure line runs via a shut-off valve to the Fueltank.
That's all for today.
Maybe I'll get around to posting more pictures next week.
Thank you for watching - I wish you all a nice week.  ;)
Servus
Bertl
« Reply #137 on: May 16, 2022, 04:55:35 AM »
« Reply #138 on: May 16, 2022, 06:13:32 AM »
This is So Impressive I don't think I am even worthy of comment  8)
Me too - I just shake my head in amazement!!
« Reply #139 on: May 16, 2022, 07:04:29 AM »
Champions League!!!
Offline Umlaufmotor
« Reply #140 on: May 17, 2022, 03:51:53 AM »
Thank you all so much for your wonderful comments.  ;D
Servus
Bertl
Offline Umlaufmotor
« Reply #141 on: May 17, 2022, 03:57:06 AM »
The next instrument in the Morane's cockpit was the altimeter.
Again, the kit part was not to my liking.
A plastic part with a casting ridge and a film as a dial.
Not so bad the kit-part, but it would have taken too much of my patience to build an altimeter usable for my project from this piece of plastic.
Servus
Bertl
Offline Umlaufmotor
« Reply #142 on: May 17, 2022, 04:09:44 AM »
I made myself a new altimeter out of scrap plastic.
A ww1 cockpit decal from airscale and the clear part of a packaging were also used.
The kit part served me as a template.
Here I took the appropriate dimensions.
An original picture of the cockpit and various photos of a museum altimeter served me for detailing.
Here the decals:
And here the waste plastic-sprues:
From these plastic sprues I filed myself two round bars of different thickness.
Here it was important that the thinner rod fit exactly into the thicker one.:
Servus
Bertl
Offline Umlaufmotor
« Reply #143 on: May 17, 2022, 04:16:36 AM »
The next step:
Cut a narrow ring from the thicker round bar.
I used a resin saw for this.
The ring was reworked with file and sandpaper according to my mind.
Now a suitable part was punched out of the clear part of the packaging which was used as a glass pane.
The finished ring serves as a bezel for the altimeter housing.
Here with the corresponding decal
Servus
Bertl
« Last Edit: May 17, 2022, 04:21:08 AM by Umlaufmotor »
Offline Beto
« Reply #144 on: May 17, 2022, 04:23:50 AM »
The next step:
 :o :o :o - and now comes the part when you have the outer casing of the altimeter and make the inner parts to make it functional.  ;)
What you do is absolutely amazing Bertl, I'm speechless...
Offline Umlaufmotor
« Reply #145 on: May 17, 2022, 04:30:21 AM »
The thinner plastic rod is modeled into an altimeter housing using a needle file and grinding tool.
Here in the picture the cover on the housing.
The cover - or the bezel - is ground even smaller in the outer diameter.
The altimeter case has now been painted in Nato black.
A challenge was to place the decal exactly in the center of the housing.
The bezel was provided with small holes on the edge to indicate the screws.
It was painted with Mr. Metalcolor "brass
Servus
Bertl
Offline ondra
« Reply #146 on: May 17, 2022, 04:37:53 AM »
Great to see you back and watch another masterpiece in the works, Bertl!
Excellent progress so far and thanks for sharing the inspirative methods you use.
Ondra
Offline Umlaufmotor
« Reply #147 on: May 17, 2022, 04:40:33 AM »
The altimeter was mounted on a wooden board in the original.
This wooden board itself was screwed on the left side in the front area of the cockpit.
The wooden board was made from a piece of waste plastic.
(there is a lot of Wingnut Wing waste plastic in the model)  ;)
After the wooden board was fixed in the cockpit it was painted with Gunze "Radome".
I did the wood grain with oil paint.
The scratch built altimeter has not yet been installed in the model.
This was actually done towards the end of the build so that it could not be damaged.
Here is the only really meaningful picture of the cockpit that I found on the web.
The altimeter is very prominent here.
Servus
Bertl
Offline Umlaufmotor
« Reply #148 on: May 17, 2022, 04:52:23 AM »
@Beto
Thank you Beto.
Well, the altimeter does not work - unfortunately  >:(  ....  ;D
But the air pump can be moved  ::)
And if you have patience, there is still an instrument coming which will be movable...... but more on that later  ;)
@ondra
Thank you very much ondra for the praise.  :D
Offline Umlaufmotor
« Reply #149 on: May 17, 2022, 04:59:48 AM »
Now a tiny little something to finish off for today.
The ignition switch.
Completely scratch built from various materials such as Evergreen rod, copperwire and - of course - waste plastic from Wingnut  ::)
The pictures in order of how the part was built.
Part one:
Servus
Bertl
