Author Topic: Hannover Cl.II, Jakob Gfrör, WNW-Kit in 1/32  (Read 13016 times)
Offline MichaelStieber
Re: Hannover Cl.II, Jakob Gfrör, WNW-Kit in 1/32
« Reply #45 on: August 13, 2021, 10:12:07 AM »
A big thank you to all of you  :)
I very appreciated your comments.
Soon I will post the next part of the report.
Greetings,
Michael
« Reply #46 on: August 15, 2021, 01:03:09 AM »
Your build on this model is shaping up beautifully. As everyone has said - your paintwork is exemplary.
Offline Syd Solo
« Reply #47 on: September 01, 2021, 12:45:20 PM »
Absolutely top rate work! You have been so incredibly diligent with this build.
Syd
Offline rhwinter
« Reply #48 on: September 01, 2021, 05:05:18 PM »
Great artistry! I love the Hannover and admire your build of WnW‘s kit!
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
« Reply #49 on: September 01, 2021, 05:16:00 PM »
I just saw this thread. Terrific work! Fantastic painting!!
Best regards
Rafael
« Reply #50 on: September 01, 2021, 05:56:51 PM »
I like the front seat with the built-in loo...
 ;D
« Reply #51 on: September 18, 2021, 07:42:55 AM »
Hello,
First of all I have to apologize for the long delay of this report.
I have had weeks with really a lot of work so I didn'd found the mood to write any reports, sorry...
...but now I have more time and so this report will be continued now  :)
Of course I also want to thank you all for your very kind comments, they meant a lot to me.  :-*
In the last parts of this building-report I prepared most of the bigger parts of the plane. So I could start to assemble them.
I started with the undercarriage, the design of this kit is so good that it was really easy going...everything fitted perfectly.
Next I went to the tail section, here I assembled both tailplanes and the elevators and also the rudder and the small struts between the tailplanes. Again everything fits perfectly so that the whole step was done in less than an hour...oh how I love WNW  :-*
I had a flow...so I hurried to the cabane struts, and glued the middle section of the top-wing on them.
Now I was satisfied for that day and gave the glue the time to harden through overnight.
Here are some pictures that I made at the end of that step:
As you can see on the pictures I also assembled the turnbuckles on all those parts before glueing them together, I forgot to mention that before.
Then again, it was time for some small parts so I started to work on the observers armament.
The ring is good designed so I just added two steel-springs and one handle, both made of thin wire. I dont even had to drill the holes for the handle for they are already in the molding, so all I had to do was bending a piece of wire and glue it in  8)
The painting was fun and so I took some time for it and added some wear to the edges of the ring. All of this wear is just brush-painted with Vallejo-Metal Color.
I prefer painting the wear instead of using any chipping-fluid (hairspray, masking-fluid, chipping-products...), I have much better control with the brush than I would have with rubbing away the paint over a chipping-fluid. Besides that it is a lot more faster  :)
The Parabellum LMG14 I basecoated with Tamiya X18 (a little bit thinned down). Then I used metal-pigment (Uschi van der Rosten Iron-Pigment) to give it some metal-appearance. For the small parts I used Vallejo Colors.
Thats all for now, thank you for reading this  :)
...next part will be the Propeller...
Have a nice time,
Michael
Greetings,
Michael
Offline rhwinter
« Reply #52 on: September 18, 2021, 04:44:22 PM »
WONDERFUL!!
« Reply #53 on: September 18, 2021, 07:30:20 PM »
No rush, modeling is not a race :)
Great things need their time and this one is really great.
« Reply #54 on: September 18, 2021, 11:00:00 PM »
Excellent work!!
« Reply #55 on: September 19, 2021, 02:47:55 AM »
Glad to see this again.  Your detail painting is second to none!
« Reply #56 on: September 21, 2021, 06:43:11 PM »
Wow, Michaell. This looks so amazing, I am totaly blown away by your paintjob.
Bye,
« Reply #57 on: September 21, 2021, 10:27:09 PM »
Lovely work Michael, the update was well worth waiting for.
« Reply #58 on: September 25, 2021, 02:32:40 AM »
Beautiful work on the painting and Machine Gun! Stunning work!
« Reply #59 on: September 27, 2021, 06:20:34 AM »
Thank you all for the very nice comments  :)
Today I have a rather small update, it's just the propeller...
On the original pictures the specific plane that I am building shows a Niendorf-Propeller with its beautiful course-lines of the dark and light wood layers.
So I choose this brand of propellers, that thankfully was one of the nine different propellers that were included in the kit.
I always paint propellers by hand, for me this is the only way to achieve acceptable results.
The basecoat was Vallejo-Air 028 (this one of course sprayed with the airbrush), the dark wood was painted with Vallejo-Air 035 with the brush.
Simultanously I always had to correct the shapes of the two colors with the brush until I was satisfied with them.
...alone this steps took about two hours of work in a quiet relaxed mood, while hearing a good audio-book...
When I was happy with the shape of the basic colors I started to paint some wood-grain with thinned-down Vallejo Model Color (#142 for the light wood, #150 for the dark wood).
This has been done rather fast, I just wanted some kind of additional structure.
Here is the result so far:
Now I wanted to simulate the effect of a glaze to get the right shine and a bit warmer color.
I mixed two Inks with Tamiya X-20A until I was happy with the color. The Inks can be thinned down very well and they bring the right amount of shine, so I dont have to use another kind of clearcoat afterwards.
I applied my mix with a big brush with one brush-stroke on each side of the propeller, it was very important to get a very even layer of glaze without any accumulation of color on any place.
Now I just had to paint the middle-part of the propeller with metal-color and a dark wash and the painting was complete.
The decals I will apply in a later step...
Soo, the completion of the plane comes nearer, next time I will build a base and some small parts and then we will do the final steps...
Have a nice time and as usual I will apprecciate any comments.
Michael
Greetings,
Michael
