Author Topic: CSM 1/48 Armstrong Withworth FK8 Early  (Read 17073 times)
Re: CSM 1/48 Armstrong Withworth FK8 Early
« Reply #75 on: September 04, 2021, 10:17:55 PM »
Excellent progress. Your rigging prep should make the process go smoothly!
« Reply #76 on: September 05, 2021, 05:00:09 AM »
Great progress Fredrik!
I, too, like the effect. If you tried to do that I bet you couldn’t!
« Reply #77 on: September 06, 2021, 12:33:24 AM »
What a huge spider :D
Good luck and have fun with the rigging!
« Reply #78 on: September 13, 2021, 05:27:09 AM »
Hi again... life again... good to have one though.
Thanks Rick! One would have thought that the rigging would be smooth sailing, but not really. My fault probably, but it has been sorted now. I'll explain more below.
Ohh, a dare! I have actually been thinking about how to make conscious use of this effect... We'll see on the next model if I dare try that. Good progress on the Bismarck! I am following, just so you know... but from a back seat.
Thanks Frank! I brought the model up to show the rest of the family and was greeted with "What a hairy aircraft!?", so spider or hairy monster?!
Since the last update I have been tinkering with rigging and other small details. It might actually be finished before next weekend, unless life gets in the way again...
I realised that I needed a way to tighten the rudder control wires and that I should have thought about that before I closed the fuselage. I solved it by drilling a hole from the underside and then I used a bit of brass tube to guide the wire from the top. It worked but one can see that the wires aren't really running forward... if one looks closely.
The struts went in like they should and the top wing came on with a bit of work. Quite tricky to align all eight interplane struts and the cabane ones and as it turned out, the top wing went on a bit off the mark. Probably my fault though. The main problem was that I didn't catch this until I had completed the rigging!
In the end I was able to solve the top wing problem by replacing one of the rigging wires , the one from the left top wing to the front of the engine and tightening this a lot (red line marked 1 in the picture below)! You can see, in the image below, the wires coming out from the left side  of the engine (marked 2 in the picture). I simply did away with the anchor point and drilled a new hole that allowed me to pull the monofilament through to the other side and pull .
The Cooper bombs have been painted and instead of painting the red and green stripes I painted thin masking tape and then applied that onto the bombs. They are now awaiting a clear coat and then some metallic colours on their noses.
Radiators are on, top wing tank (gravity tank?), and some other bits and pieces.
At least in one period picture there is a Rotherham pump. So I thought I'd add one according to that picture. I recently bought small resin versions from Eduard, they're designed for the Camel but with a few additions it worked here as well.
And here it is attached to the fuselage. Without the propeller so far since that has been painted and is now drying in a box.
« Last Edit: September 13, 2021, 06:47:18 PM by FAf »
« Reply #79 on: September 13, 2021, 06:09:42 AM »
What a nice, but big bird! I like the state, where are the prepared parts are coming together!
I need to double check if it fits into my cabinet ::)
Offline Early Bird Fan
« Reply #80 on: September 13, 2021, 07:13:42 AM »
amazing details  8)
« Reply #81 on: September 13, 2021, 08:17:46 AM »
Brilliant microscopic details. When I zoomed in on the last photo I really thought I was looking at a real aircraft. 👏👏👏
« Reply #82 on: September 13, 2021, 09:44:08 PM »
Well done on the details.  Lots of rigging on this one!
Looking forward to seeing it done soon.
« Reply #83 on: September 14, 2021, 06:58:08 AM »
I couldn't agree more!
« Reply #84 on: September 15, 2021, 04:03:37 AM »
Your builds always impress me , fantastic results so far Fredrik
« Reply #85 on: September 15, 2021, 10:37:02 PM »
Stunning detail work! Really looks awesome!!
« Reply #86 on: September 17, 2021, 03:34:19 PM »
Incredible Fredrik!
It looks at least 1/32 with that level of detail.
Ps I’d lock your doors at night - sounds like Frank is going to try a heist!
Offline jeroen_R90S
« Reply #87 on: September 18, 2021, 12:49:16 AM »
Just caught up with this build from the start -looking great!
« Reply #88 on: September 29, 2021, 05:10:42 PM »
Thank you all for your continued interest and your supportive posts!
I have now disentagled myself from the rigging and finished the build - at last. Although, for me, it was a fairly quick build.
Take care!
« Reply #89 on: September 29, 2021, 05:38:14 PM »
Hi Fredrik,
What a beautiful end result. You can certainly be proud of this model! You have shown that the PC10 / Olive drab on British aircraft doesn't have to be dull. Far from it!
Great detailing and rigging.
« Last Edit: September 30, 2021, 07:03:03 AM by Rookie »
