Author Topic: Fokker D.V, Special Hobby 1/48; Update 21.12.20 Finished  (Read 41662 times)
Re: Fokker D.V, Special Hobby 1/48; Update 15.11.20 Axle
« Reply #45 on: November 16, 2020, 11:29:10 AM »
Now that is some really nice work on the seat and the axle Frank , does the hand pump work ?  ;)
« Reply #46 on: November 16, 2020, 10:54:22 PM »
As always the details are Superb Frank! Prop, seat, gear, and Pump look Fantastic!
« Reply #47 on: November 19, 2020, 04:36:32 AM »
Thank you Dave, Terri and Rick!
Of course, what did you think? ;D
« Reply #48 on: November 21, 2020, 03:44:02 AM »
Frank,
I am sorry not to have commented recently, but as I explained to Lance, things have been rather stressful over the last few days. What a pleasure it is to see the work of a master model maker in progress: the seat and floor, propellor and pump are as always, works of art in their own right.
Fokker D.V, Special Hobby 1/48; Update 21.11.20 Cockpit
« Reply #49 on: November 22, 2020, 02:29:16 AM »
Thanks Stephen, but no need to apologize!
Cockpit
To be able to close the fuselage I continued to work on the cockpit parts.
The mostly self made stick and rudder pedal.
A better viewing angle
Rigging added.
According to the original pictures I formed some alu plates.
After painting control stick and rudder bar all parts are mounted.
And again in a side view.
The seat belts from HGW/Eduard are in place. A light washing with oils are also done.
A dry fitting shows, that some of the created details are visible later.
Ok, the original pictures shows even more details, but enough is enough.
The cockpit is mounted into one halve.
Last check: Anything forgotten? Control wires! Added some.
Fuselage is finally closed and drying now.
Again a big step done.
Offline Dave Brewer
Re: Fokker D.V, Special Hobby 1/48; Update 21.11.20 Cockpit
« Reply #50 on: November 22, 2020, 04:42:36 AM »
Superb cockpit Frank, really looks terrific.
Dave.
« Reply #51 on: November 22, 2020, 07:36:36 AM »
Great work on the cockpit! It's a pity though that so much of it is hidden now the fuselage halves are closed.
« Reply #52 on: November 22, 2020, 10:25:57 AM »
Excellent work Frank  :)
« Reply #53 on: November 22, 2020, 11:00:40 AM »
    Exceptional Frank, just great work and a beautiful result! Don't ever lose or compromise those wonderfully high standards of yours!
« Reply #54 on: November 22, 2020, 05:06:24 PM »
“the original pictures shows even more details, but enough is enough.”
Honestly Frank, this lazy laissez-faire approach to modelling is indicative of the low standards of modern society   ;D
Apart from that, it’s fabulous!
« Reply #55 on: November 23, 2020, 03:41:51 AM »
Great office for the pilot, Frank. The Fokker D. V is a really pretty aircraft, i am keen on seing it finished by your magical hands.
« Reply #56 on: November 23, 2020, 04:31:27 AM »
Such a shame that all of that detail is being largely hidden forever. At least you have the photos to show that it is there.
« Reply #57 on: November 23, 2020, 05:24:56 AM »
Great work, Frank! And lots is now hidden... but we know it's there! Lovely to watch and experience.... Regards, Marc.
« Reply #58 on: November 23, 2020, 06:33:33 AM »
Thank you Dave, Willem, Terri, Lance, Guy, Andreas, Stephen and Marc fro your kind words!
Oh Lance, you are right - I should stick to my principle to do as much as possible.
Now it becomes philosophical - but you are right!
With good light most of the details can be seen with naked eye through the cockpit opening, only with a camera lens it is hard to capture.
With a bit luck I'm able to finish it this year as model number 8. I will start to spray the primer to the fuselage soon.
The cowling is again a tricky part, very tight fit as usual.
« Reply #59 on: November 23, 2020, 06:44:05 AM »
Great work on your cockpit, I'm always amazed by tiny soldered joints in your builds and the overall look is highly realistic.
