Author Topic: Fokker D.V, Special Hobby 1/48; Update 21.12.20 Finished  (Read 41532 times)
Offline Fvdm
Re: Fokker D.V, Special Hobby 1/48; Update 4.12.20 Streaking
« Reply #75 on: December 05, 2020, 07:42:09 AM »
Great build Frank. I can learn a lot from this and I think the streaking looks real nice.
« Reply #76 on: December 05, 2020, 08:33:56 AM »
Thank you all!
As written above after seeing the pictures I don't like the result. Now the streaking is more finer, after I removed more paint and made a finer structure, especially in the areas with less paint.
I will try to make pictures in daylight tomorrow.
When the oil paint is oxidized, I will add clear coat for the decals.  I am very curious about the look with the white "X", the crosses and markings!
« Reply #77 on: December 05, 2020, 10:53:03 PM »
The detail work is spectacular Frank. As for the streaking, I liked your first effort so I am really looking forward to the second version!
« Reply #78 on: December 05, 2020, 11:54:54 PM »
Looks good Frank , looking forward on seeing the final results on how the effect turned out .
Fokker D.V, Special Hobby 1/48; Update 5.12.20 Final streaking
« Reply #79 on: December 06, 2020, 04:46:06 AM »
Final streaking
Okay Rick and Terri, if you are waiting so impatiently ;) , this is the final version:
During the hardening time I thinned the cowling, because it was very thick. I would be possible to fit the engine, but at the end the two parts (because of the lower cut outs) separates again.
So I started the lathe!
This time I used brass because it is easier to work with and it is not easy to apply paint to aluminum.
The rotary has enough space now. The linked article above say 107cm diameter, +/-1cm. So I used 108cm which is 22.5mm in 1/48. The wall thickness is 0.4mm.
Now I need to mill the lower cutouts and I have also an idea for safe mounting  :)
« Reply #80 on: December 06, 2020, 04:54:13 AM »
The streaking is indeed even better  8) The Cowling is your Usual Magic!!
« Reply #81 on: December 06, 2020, 12:21:19 PM »
Hard to argue with that , well done Frank ! :)
« Reply #82 on: December 06, 2020, 06:20:55 PM »
The cowling looks fabulous Frank!
This is a still from "War machines" on Discovery of how they hammered the engine cowling of German (don't know which) WWII aircraft.
Very labor intensive...
Fokker D.V, Special Hobby 1/48; Update 6.12.20 Cowling
« Reply #83 on: December 07, 2020, 01:41:08 AM »
Thank you Rick, Terri and Willem!
Willem, you are right, the best would be to peen a cowling, but I don't know how to do this in this small scale. The way with a lathe creates a lot of waste, but works ;)
Cowling
As planned I milled the cutouts on a dividing header.
I polished the cowling and since it is a bit on the heavy side, I soldered thin brass wires in for an easier mounting, but at the end it doesn't work as expected.
The tinned cowling prepared to be painted dark green with the rest of the metal panels of the fuselage. But I need to wait for the hardening of the oil paint before.
Re: Fokker D.V, Special Hobby 1/48; Update 6.12.20 Cowling
« Reply #84 on: December 07, 2020, 02:03:52 AM »
That is truly Stunning Frank!
Offline rhwinter
« Reply #85 on: December 07, 2020, 04:05:44 AM »
WOW, Frank! What skilled craftmanship and artistry!
« Reply #86 on: December 07, 2020, 04:14:39 AM »
As always when you produce things on your lathe, I feel like adding one to my Christmas wishlist! Truly stunning work!
« Reply #87 on: December 07, 2020, 07:40:49 AM »
Your metalwork is just out of this world Frank. You manage to add such fine details to your models in this way.
« Reply #88 on: December 07, 2020, 10:45:40 PM »
Your streaking looks great, Frank.  Just like the box top art.
When you turned the inside of the cowling, how did you determine the radius of the front rounded part?
Did you turn the whole cowling with just one lathe setup?
What is the outside diameter of your cowling?
Your cowling looks great.  I haven't made a cowling from brass but getting the thickness to 0.4mm is an accomplishment.  Bravo.
To mount my cowlings, I remake the firewall by machining a sheet of styrene with a step that fits within the inside edge of the cowling.  This works well in 1/32 scale.
I hope you will excuse all the questions, but I try to learn from other's experiences.
Again, great job on the cowling!
« Reply #89 on: December 08, 2020, 12:46:17 AM »
Thank you Rick, Richard, Fredrik, Stephen and Ken! Your comments are highly appreciated!
It is a nice tool, but really not a toy! Such beast can really be dangerous and the possible forces should not be underestimated. One example is to forget the chuck key and switch on - that wrench will fly away with high speed! Luckily my lathe has a security mechanism against this particular mistake.
That is also not a cheap toy, not only the lathe itself but you will need also many accessories. May be for our purpose a watchmaker lathe is an option, but it you find a good one with accessories on ebay the price is going crazy.
Thanks, that was the intention.
The only bad thing is, that the color is not completely the same as the wings done weeks ago. I was impatient, but this should be done in one go.
The is the most tricky part of the game!
I made only another complete cowling for my Nieuport "Flyboys" (in alu that time), and if you want to much, you have two rings instead of one cowling ::) Made the experience in that project. So only slow approach, measure and feel with the finger helps. At first I have done the outer diameter, then the inner radius.
Yesterday I thought about grinding a HSS turning tools into shape, but I never grind a HSS tool.
EDIT: I should mention, that I made the spinner of the Deperdussin Monocoque also to thin so it cracked. I rescued the part with soldering the crack.
Yes, for two reasons: First, I have learned that you should not wrap around a part if it can be avoided. And my three-jaw chuck is too big (or the cowling too small), so I can't clamp from the inside.
At first face turning, the outer diameter.
Next I drilled with 10mm (my biggest drill),  enhancing to 14mm with a inside turning steel (front opening later 15mm).
Then I cut from the side to a 15,5mm diameter, them enhanced the cut to the right side to get the front radius.
Enhanced the inside diameter in the straight part, create a thin wall.
Then the tricky inside front radius.
Enhanced the inner diameter to 15mm at the front.
Finally cut from the side at the front until it separates.
After final polishing 22,45mm
The Nieuport alu cowling was comparable in that point. I only had the material problem, no paint sticks to it, and the CA-glue does not hold well either.
At the model exhibition here some guys always sell "Aluminium bowl for superglue, easy to clean" ;)
If a cowling was made of alu on an aircraft and don't need to be painted, I will use alu again.
I had the same idea, but I thought about a small ring due to limited space. The outer ring diameter should have a tight fit into the cowling. The brass one is much heavier compared to my previous alu one!
No problem, I tried to answer. But I'm still a beginner, may be an experienced lathe worker would do this differently ???
« Last Edit: December 08, 2020, 06:02:12 AM by Bughunter »
