Author Topic: Fokker D.V, Special Hobby 1/48; Update 21.12.20 Finished  (Read 42218 times)
Re: Fokker D.V, Special Hobby 1/48; Update 1.11.20 Tail plane
« Reply #30 on: November 03, 2020, 12:19:57 AM »
Awesome work on the tail Frank  :)
« Reply #31 on: November 03, 2020, 04:47:19 AM »
Stunning, as always! It's always nice to see what you have done and how you've solved things.
Fokker D.V, Special Hobby 1/48; Update 13.11.20 Airscrew
« Reply #32 on: November 14, 2020, 07:50:35 AM »
Thank you all for your kind comments!
After a stroke of fate (hopefully the year 2020 will be over soon!) I tried to distract myself a little by continuing to build on the Fokker.
Air screw
As usual for that time there were different air screw types mounted to the Fokker D.V
Some are very comparable to types I created already but some pictures shows a Garuda. Due to the wide blades those are looking interesting and since there is no air screw shown on my Fokker on the two known crash pictures I will go with that.
As additional references I used the "Fokker Eindecker Compendium 1" (great book!) and the book "German Propeller Makers of WWI: Part One", which includes Garuda. The shape is really complicated so my first try failed. This is the second one.
Front view. I used very wide veneer strips so the grain goes straight through.
The back view:
And the interesting side view. It shows a thicker wood on the back side but thinner at hub.
Dry fitting with cowling and spinner.
The painted airscrew together with the mentioned failed one and the kit propeller.
Not my best to date, but I will use it. The shape of the Garuda is really difficult.
Offline Dave Brewer
Re: Fokker D.V, Special Hobby 1/48; Update 13.11.20 Airscrew
« Reply #33 on: November 14, 2020, 09:06:03 AM »
Beautiful work Frank, that's an incredible improvement and well worth the effort,
Dave.
« Reply #34 on: November 14, 2020, 03:04:19 PM »
Well , that's a 1000 times better then what my hands would be able to carve up , well done Frank  :)
« Reply #35 on: November 14, 2020, 06:47:46 PM »
Your propeller is great, and of the correct shape. I like it.
« Reply #36 on: November 14, 2020, 06:54:30 PM »
That is one lovely propeller! Well done! Marc.
« Reply #37 on: November 14, 2020, 11:13:29 PM »
    Beautifully done Frank, that shape would be a real challenge with the varied thickness. Very impressive!
« Reply #38 on: November 15, 2020, 01:58:59 AM »
As the others have said, great work on the prop.  Nice to include the thickness detail.
« Reply #39 on: November 15, 2020, 04:38:13 AM »
Thank you all!
Thank you Dave, most of the effort was the need of a second one ::)
Terri, one day you will also carve your first wooden airscrew, I'm sure!
Giuseppe, some pictures in the Mini Datafile shows machines with that type of airscrew, and the outer part shows mostly straight lines between the layers. I tried to get this lines, but I should have used more layers.
Yes Marc, I want to have this lovely type in my cabinet!
Lance, since I know you also carve your own airscrews your words are even more meaningful for me.
Ken, the reduction of inner thickness is needed to get the right outer shape.
The next detail follows soon :)
Fokker D.V, Special Hobby 1/48; Update 14.11.20 Seat
« Reply #40 on: November 15, 2020, 07:10:08 AM »
Seat
Of course there is a seat in the kit, but if I look on the reference pictures, there is a big difference. The seat looks very special for a specific reason.
The rotary with 100 h.p. was not very powerful for its time, so the Fokker designers tried all to save weight. The fuselage structure looks very fragile and so also the seat.
It is may be a bit too much work for a detail mostly hidden later, but I wanted to try also the Connecto crosses by Albion Alloy and want to use the seat as prototype for a bigger project. Stephen always try to convince me to do a scratch project and at least I have an idea now.
The pipes are 0.6mm brass, on the front the Connecto crosses are used.
The frame is completed with soldering.
The seat is plugged to the side frames with thin pins. The floor is replaced by a thin layer birch wood.
Also for the seat I glued two layers birch veneer and sanded it very thin.
Tinned in comparison to the kit seat:
After painting the kit frame grey green and the seat black (I know, normally only moving parts black, but the seat frame looks very dark on the photos) I mounted it. The back of the seat is a left over from HGW seat belts - a piece of linen.
I removed some kit details, which where not on the pictures, so I have to add some again. Here a switch on a PE rest and a switch in brass (PE from Parts).
The frame fits in the fuselage halves.
Now I have to add the rest of the cockpit details.
Re: Fokker D.V, Special Hobby 1/48; Update 14.11.20 Seat
« Reply #41 on: November 15, 2020, 03:18:21 PM »
Incredible micro soldering Frank!
« Reply #42 on: November 16, 2020, 01:12:40 AM »
Nice work, as always, Frank.  I think the connectors would be very handy to use.  Thanks for showing us about them.
Fokker D.V, Special Hobby 1/48; Update 15.11.20 Axle
« Reply #43 on: November 16, 2020, 02:17:54 AM »
Thank you Guy and Ken!
Now it gets even better!
Axle
Today I took a closer look at the photos while having a coffee, among other things a large-sized picture of the front. I noticed the suspension in detail. The people at Fokker welded small cross tubes on the axle and small limiting plates on the sides to prevent the rubbers from slipping. How should I mount it durable? It falls apart again when I solder it! ???
So I remembered my equipment for brazing with silver solder (a paste with flux, 610°C). Careful, the burner reaches 1300°C!
With this I brazed 0.6mm brass pieces to the axle of 1.0mm piano wire.
This was easy because the axis lies flat on the pieces.
Then I could solder small pieces of thin brass sheet metal on the side with an electric soldering iron without endangering the other connection. I then filed the sheets into shape.
This is how the struts of the kit will look like. If I get caught, I will exchange them as well.  8)
Actually I wanted to continue building the cockpit to be able to close the fuselage. But I really wanted to see if the idea works and I could get the axle done with brazing.
I love this feeling of happiness when it works! :)
Ok, I built also a pump for the cockpit.
Offline Dave Brewer
Re: Fokker D.V, Special Hobby 1/48; Update 15.11.20 Axle
« Reply #44 on: November 16, 2020, 09:20:05 AM »
Wonderful detail work again Frank,thanks for the new update.
Dave.
