Author Topic: Fokker D.V, Special Hobby 1/48; Update 21.12.20 Finished  (Read 41609 times)
Fokker D.V, Special Hobby 1/48; Update 27.10.20 Oberursel U.I rotary engine
« Reply #15 on: October 28, 2020, 04:49:06 AM »
Oberursel U.I
This Fokker needs an Oberursel U.I with 100 hp. Luckily this type of rotary engine is available from Small Stuff and I had it in my stash.
It needs 46 parts. Some spare parts are also included. Yesterday I mounted already the cylinders to the crankcase.
Now all parts are painted with different Alclads.
The rotary engine again alone. I used Dark aluminum, Exhaust Manifold on the heads, Hot metal sepia.
As little joke I used on one cylinder hot metal blue. It was replaced or running hotter ;D
To insert the small "brass" bushes I use a 0.2mm drill instead of the provided tool.
The finished engine from the back. I added thin copper wires.
And the front view in artificial light. It is very early so dark now :(
The whole action here included painting, mounting and weathering with oil paint took 2 hours 40 minutes. This was not my first engine made by Small Stuff 8)
Again a important step done in this build.
Offline Radarman
Re: Fokker D.V, Special Hobby 1/48; Update 27.10.20 Oberursel U.I rotary
« Reply #16 on: October 28, 2020, 05:26:53 AM »
Frank,
That's a very realistic looking Oberursel. I can almost smell the burnt castor oil.
        Kevin
« Reply #17 on: October 28, 2020, 06:40:31 AM »
I can think of No One that paints and details rotary engines better than you Frank! This one as always is outstanding!!
Offline Dave Brewer
« Reply #18 on: October 28, 2020, 09:36:48 AM »
Beautiful work Frank, those Small Stuff engines are exquisite items.
Dave.
« Reply #19 on: October 28, 2020, 05:39:23 PM »
Vrooom! But in my head aircraft engines don't really make that kind of sound... Anyway, great looking build so far and the engine is outstanding!
« Reply #20 on: October 28, 2020, 06:06:38 PM »
Gorgeous streaking and engine, Frank.
« Reply #21 on: October 28, 2020, 06:13:33 PM »
Nice subject Frank.... and nice progress with it.
I have a soft spot for these lesser known types and can't wait to see it finished.
« Reply #22 on: October 29, 2020, 01:35:25 AM »
A fine looking engine, Frank.
If only Small Stuff made big stuff...   :'(
« Reply #23 on: October 29, 2020, 04:18:49 AM »
Thank you all for your nice words!
Kevin, the smell of the oil paints on my bench is a bit different.
Would using the correct smell put model making on a new level? ;)
Rick, what a compliment! Now I have to ask Dave W to add a red face smiley to the editor, because I have one now.
Oh yes Dave! I only have the strong wish to get the Gnome N and the Bentley B.R.2 added to the line. I asked already and he do not refuse the idea, so I have some hope. For now I have enough kits to build using types which are available.
Fredrik, I can really confirm that the engine is not running. ???
Not yet. 8)
Giuseppe, I hope I'm able to replicate this on the fuselage, but for that I have to do the cockpit first.
Sandy, even though this type is rare, I can't believe that this is the first build of this type in the forum!
Ken, for Eugeny it is big stuff, since he is addicted to 1/72. That's why those engine are available in 1/72 too (if I remeber right at first in this scale).
« Reply #24 on: November 01, 2020, 02:48:39 AM »
Catching up Frank. That engine just needs oil and fuel and a generator to get it going - I can small the burnt oil!
Small Stuff engines really are excellent - as good as the WNW accessory kits.
« Last Edit: November 02, 2020, 04:23:08 AM by lone modeller »
Fokker D.V, Special Hobby 1/48; Update 1.11.20 Tail plane
« Reply #25 on: November 02, 2020, 04:07:29 AM »
Thank you Stephen!
Tail plane
At first an addition to the last update. I forgot to show the kit engine, in case someone wants to build this kit out of the box.
As next I thought about mounting of tail plane. I created two holders made from nickel silver and brass sleeves.
Instead of a thick plastic axle between both tail plane halves I used 0.6mm nickel silver wire. I made one piece control horns with a hole in the middle (instead of the four from kit PE horns) and soldered them to the new axle.
Later I need only two thin cuts in the end of the fuselage and can glue the unit in.
Re: Fokker D.V, Special Hobby 1/48; Update 1.11.20 Tail plane
« Reply #26 on: November 02, 2020, 04:24:15 AM »
More incredible micro-detail Frank!
« Reply #27 on: November 02, 2020, 04:51:59 AM »
I agree 100%
« Last Edit: November 03, 2020, 12:01:42 AM by RAGIII »
« Reply #28 on: November 02, 2020, 11:16:17 PM »
There you go with that big Euro cent coin again!
Your details are exceptional, Frank, Bravo!
« Reply #29 on: November 02, 2020, 11:51:25 PM »
  Wonderful detail work as with all of your projects Frank, and that engine is sheer magic! It's a pleasure to follow your progress and so many things to learn!
