Author Topic: HB W.29 Aircraft 2760 in British Markings  (Read 18778 times)
Offline rhwinter
Re: HB W.29 Aircraft 2760 in British Markings
« Reply #15 on: December 12, 2020, 08:00:58 PM »
WOW, Carl! I’ve just seen your thread. Great topic: I love those well known airplanes with a „twist“! Will follow your build eagerly.
Offline Fvdm
« Reply #16 on: December 13, 2020, 01:25:43 AM »
Indeed a great topic. I like the floats as they are but I can understand why you want to spray some weathered black.
Offline fredjocko
« Reply #17 on: December 14, 2020, 02:00:29 PM »
I redid the floats. I lightly sanded the oil paints and put on some Proper Plane light wood decals. Then I sprayed some Tamiya clear yellow and sealed with an Alclad gloss coat. I like it better than the original.
Offline fredjocko
« Reply #18 on: December 14, 2020, 02:53:42 PM »
Thank you
Offline fredjocko
« Reply #19 on: December 14, 2020, 02:54:16 PM »
I think you have done an outstanding job on all, including the roundels! The floats look fine to Me but it is your build  8)
Thank you, sir
Offline fredjocko
« Reply #20 on: December 14, 2020, 02:54:55 PM »
Excellent job on masking the national markings . Those floats are nice looking as well  :)
Thank you. Maybe I am over thinking it.
Offline fredjocko
« Reply #21 on: February 13, 2021, 02:24:42 AM »
Finally had an opportunity to work on the engine. This is the 185hp Benz Bz.IIIa from the Roland D.VIb. The later W.29's were upgraded from the 150hp Benz Bz.III. I added .3mm plastic rod for the lifters, twisted copper wire for the sparkplug wires, and pieces from HGW's Bz.III engine set. Still much more work to do; but, it was nice to finally get started again.
Offline Radarman
« Reply #22 on: February 13, 2021, 02:28:44 AM »
It's great to see an update on this build. The engine is looking good.
        Kevin
« Reply #23 on: February 13, 2021, 02:32:59 AM »
        Kevin
I agree with Kevin. Your added details are excellent!
« Reply #24 on: February 14, 2021, 04:53:21 AM »
I had not seen this before - some remarkable detailing on that engine. The floats look really good too - worn but not overdone. I will keep a closer eye in future.
« Reply #25 on: February 14, 2021, 05:19:38 AM »
I've been missing this build, very fine wood parts and painting of fabric covered parts. Well done with the new engine.
« Reply #26 on: February 14, 2021, 06:01:36 AM »
Great work so far - I'm extremely impressed with your painted-on wing roundels.
« Reply #27 on: February 14, 2021, 08:25:09 AM »
Fantastic progress with the engine , lovely details !
Offline fredjocko
« Reply #28 on: February 16, 2021, 03:19:28 AM »
        Kevin
Thank you so much.
Offline fredjocko
« Reply #29 on: February 16, 2021, 03:21:28 AM »
Thank you so much.
