Author Topic: HB W.29 Aircraft 2760 in British Markings  (Read 18775 times)
Re: HB W.29 Aircraft 2760 in British Markings
« Reply #45 on: February 17, 2021, 02:18:22 AM »
Better and Better with each post! The engine looks great in place!!
Offline fredjocko
« Reply #46 on: February 19, 2021, 01:12:12 AM »
After cleaning up the fuselage and the cockpit coaming I thought I would put the wings on to see how it would look...and I LIKE IT!!! I worked on the radiator some more and I think I probably need to make it thicker; but, I'm happy with the overall shape. The radiator hose from the engine doesn't quite reach the radiator, so I will switch out the plastic molded part and add a length of solder in its place.
« Reply #47 on: February 19, 2021, 01:19:26 AM »
The wings do look great in place. The radiator is also looking very nice!
Offline Fvdm
« Reply #48 on: February 20, 2021, 07:47:03 PM »
It certainly looks great. The wings, radiator, cockpit. Great progress.
« Reply #49 on: February 20, 2021, 11:02:49 PM »
She does look good in British livery !
Offline fredjocko
« Reply #50 on: February 21, 2021, 11:04:31 AM »
I decided to redo the radiator. I like the new one better.
The first radiator is the kit’s, the second one was my first attempt, and the third is the new one.
« Reply #51 on: February 21, 2021, 11:37:25 AM »
It seems like the copious amounts of bourbon are paying great dividends. Very nice work. Is it Jack Daniels I should try?  ;)
« Reply #52 on: February 21, 2021, 11:55:52 AM »
Nice progression on the radiators. Your last/latest looks great!
Offline fredjocko
« Reply #53 on: February 21, 2021, 01:06:31 PM »
Thank you so much. I like Buffalo Trace; but, Jack Daniels works, too.  :)
Offline fredjocko
« Reply #54 on: February 21, 2021, 01:09:13 PM »
Thank you. I am liking it and the side panels fit against it better. I’m glad I made it about 2mm thick, instead of .75mm.
Offline fredjocko
« Reply #55 on: February 21, 2021, 01:17:19 PM »
The plane definitely looks different when it’s wearing something other than German colors. It’s too bad the British and US didn’t use the plane like other countries did.
Offline fredjocko
« Reply #56 on: February 21, 2021, 01:17:50 PM »
Thank you
Offline fredjocko
« Reply #57 on: February 21, 2021, 01:18:38 PM »
Thank you. I’m surprised how fast things move after the woodwork is done.
« Reply #58 on: February 22, 2021, 04:44:09 AM »
I have missed some of your updates: the fuselage interior and engine are first class. The wing attachment looks good too. I had not heard of this machine until I started to read your build log - fascinating piece of history being reproduced at the highest level of quality here.
Offline fredjocko
« Reply #59 on: February 23, 2021, 11:26:55 PM »
Thank you, sir.
