Author Topic: CSM Pfalz Dr.1  (Read 37185 times)
Re: CSM Pfalz Dr.1
« Reply #195 on: September 07, 2020, 07:47:16 AM »
Hi guys ! Hey , thanks for the positive comments at this stage it is the only thing which is keeping the spirit alive .
The silvergary is sprayed . For this I mixed Tamiya sky grey XF-19 and flat alum X-16 with a bit of white . Tires got sprayed neutral grey . Bungee cords I painted Tamiya Deck Tan . Cockpit combing is still a work in progress , made a mess of it I did and ended up smearing some down the fuselage side and had to touch that up resulting in walking away and smoking a joint !
Feel much better now and the right side has been touch up . I'm hoping that it will blend in better once the finally sealing coats have been applied . Some of the seams didn't turn out over well this time around . But at this stage the resin is paper thin and can't with stand to much more sanding and lacquer thinner wiping away any excess will make the resin brittle ending in cracks .
Also didn't do any shading on the ribs . When the Baron test flew this it was still new so wouldn't show a lot of aging or wear . So weathering will be kept on the light side . Clear coating is finished as well and once this is dried it's off to decalling . While this drying detail painting engine is taking place and works on the prop laminations .
Re: CSM Pfalz Dr.1
« Reply #196 on: September 07, 2020, 07:47:40 AM »
Offline smperry
Re: CSM Pfalz Dr.1
« Reply #197 on: September 07, 2020, 08:06:08 AM »
Now I see why you went to all the interior detail trouble. That is one wide cockpit opening. With the overall silbergrau paint scheme, the colors and details of the cockpit make the perfect contrast. This is going to be a model that grabs the eye.
sp
Offline Old Man
Re: CSM Pfalz Dr.1
« Reply #198 on: September 07, 2020, 08:06:19 AM »
That is shaping up great!
Difficulties have their good points --- I have found things that make the best stories to tell were usually no fun at all at the time....
Re: CSM Pfalz Dr.1
« Reply #199 on: September 07, 2020, 08:23:49 AM »
Now that is stunning work Terri! I agree with all SP said!
Re: CSM Pfalz Dr.1
« Reply #200 on: September 07, 2020, 12:33:01 PM »
You guys are awesome ! Thanks again  :)
Moving forward the decals are on and to my surprise they work very well after all these years . I had a few crack and lift resulting in touch up with black paint . I will let these dry overnight and seal them tomorrow . Detail painting on the engine is almost finished with a few more washes to apply and paint the fire wall , still haven't done that yet . Other then that this is as far as I got today . Also forgot to drill the rigging holes so extra care will be needed now with those .
Re: CSM Pfalz Dr.1
« Reply #201 on: September 07, 2020, 12:33:27 PM »
Re: CSM Pfalz Dr.1
« Reply #202 on: September 07, 2020, 12:33:59 PM »
 :) Have a few touch ups  ::)
Re: CSM Pfalz Dr.1
« Reply #203 on: September 07, 2020, 12:34:27 PM »
Offline Radarman
Re: CSM Pfalz Dr.1
« Reply #204 on: September 07, 2020, 12:37:02 PM »
Terri,
It looks like you've had a very productive Sunday. Soon you'll be free-wheeling to home with this build.
        Kevin
Re: CSM Pfalz Dr.1
« Reply #205 on: September 07, 2020, 09:12:16 PM »
Thanks Kevin , it was a good day in front of the bench  :)
Re: CSM Pfalz Dr.1
« Reply #206 on: September 08, 2020, 10:15:40 AM »
Weekend comes to an end ...those four days went by really fast ! Didn't make a start on the rigging yet but I'm very close , very very close . Rigging holes still need to be drilled and the joys of making turnbuckles can begin . The wheels haven't been sealed yet nor the guns . These will get a flat coat for further weathering . The laminations did't turn out so shit hot and the prop was strip and sprayed Tamiya deck tan and will redo this . I also found my Copper State Prop Boss's so I can do this detail now . ! I used Flory's dark dirt for the wash and this was only added the the metal fittings and flight controls . The parts have been sealed with a satin finish to cut down on the shine and for the oil slight oil streaking on lower chin . So this is where I'm at now . I must admit that it is looking pretty dame good even with my errors  ::)
« Last Edit: September 08, 2020, 10:25:20 AM by Terri »
Re: CSM Pfalz Dr.1
« Reply #207 on: September 08, 2020, 10:16:08 AM »
Re: CSM Pfalz Dr.1
« Reply #208 on: September 08, 2020, 04:44:55 PM »
Lovely job Terri,
I like the silver grey - looks great!
Re: CSM Pfalz Dr.1
« Reply #209 on: September 08, 2020, 09:50:40 PM »
Thanks Guy  :)
