Author Topic: CSM Pfalz Dr.1  (Read 37236 times)
Re: CSM Pfalz Dr.1
« Reply #165 on: August 30, 2020, 02:46:19 PM »
Thanks Fredrik  :)
I managed to mess up my struts , I wasn't paying attention to the direction and made those cuts on the wrong strut ...so ...back to the drawing board .  :o ::)
Re: CSM Pfalz Dr.1
« Reply #166 on: August 31, 2020, 03:51:21 AM »
Okay got the new undercarriage struts remade and I actually got everything pinned .For the cab struts I used steel pins and for the middle wings and inter struts I used brass pins . Stablizers are steel pins as well.
« Last Edit: September 02, 2020, 09:24:33 PM by Terri »
Re: CSM Pfalz Dr.1
« Reply #167 on: August 31, 2020, 06:24:33 AM »
I guess the "Y"-strut stands for YES!
 ;D
Re: CSM Pfalz Dr.1
« Reply #168 on: August 31, 2020, 06:25:49 AM »
Metal pins for struts are always better than plastic if the parts are small. Takes longer but saves the risk of disaster later.
Re: CSM Pfalz Dr.1
« Reply #169 on: August 31, 2020, 08:50:50 AM »
The Y does stand for yes Frank  ;)
Stephen , I always use metal for pins and replace plastic with metal . Even it it takes longer you are right that the end results are worth the effort .
That " hole " on the lower chin is now filled and sanded smooth . This was a two part affair by first filling the hole with scraps filling in more of the void and then putty was placed over top . The hinge slots on the fin are opened up . I didn't get to the primer stage yet . Still a bit of work to do on the struts and get the landing gear test fitted followed by assembly .
Re: CSM Pfalz Dr.1
« Reply #170 on: August 31, 2020, 08:51:17 AM »
Re: CSM Pfalz Dr.1
« Reply #171 on: September 02, 2020, 02:31:44 AM »
You are making great progress on a challenging kit Terri!
Re: CSM Pfalz Dr.1
« Reply #172 on: September 02, 2020, 03:21:05 AM »
This does seem to need a lot of work to achieve an acceptable model, but you are certainly doing it very well.
Re: CSM Pfalz Dr.1
« Reply #173 on: September 03, 2020, 09:52:34 AM »
Rick and Stephen , thanks for the continuing support  :) It's my Friday tomorrow so a four day weekend for me starts a 4pm  :)Few things to around the yard and the rest is bench time  ;D
I think what caused some of those challenges are my own errors from rushing and not paying attention to what I was doing and I 'm very positive the this will be repeated during the rest of the construction of this kit  ;)
Offline fredjocko
Re: CSM Pfalz Dr.1
« Reply #174 on: September 05, 2020, 03:43:53 AM »
This is looking really cool.
Re: CSM Pfalz Dr.1
« Reply #175 on: September 05, 2020, 09:50:24 AM »
Thank you sir  :)
My order for Ultracast arrived Today ....so off to the bench I went and already have them sprayed black for the next step .
Over the past few nights I have been working on the push rods and I must admit that I had a hard time seeing what the hell I was doing this time around . Got her done though and black based for the Vallejo Metal coat as well as the cowl I ended up using the side panels for the cowl even though they are oversized compared to scale drawings   Still dealing with the seems and I did have to lengthen the slots for the guns and ended up breaking free the ammo bin  >:( yup , few colourful works were used I can sure you that !
Re: CSM Pfalz Dr.1
« Reply #176 on: September 05, 2020, 09:50:51 AM »
Re: CSM Pfalz Dr.1
« Reply #177 on: September 05, 2020, 09:51:19 AM »
Re: CSM Pfalz Dr.1
« Reply #178 on: September 05, 2020, 09:51:50 AM »
Offline Radarman
Re: CSM Pfalz Dr.1
« Reply #179 on: September 05, 2020, 12:53:14 PM »
Looking good Terri.
As for the colourful words, a wide-ranging vocabulary is a sign of a superior intellect.
Keep up the progress and express your frustrations as needed.
        Kevin
