Author Topic: CSM Pfalz Dr.1  (Read 37295 times)
Offline Radarman
Re: CSM Pfalz Dr.1
« Reply #135 on: August 23, 2020, 05:49:41 AM »
Terri,
I'm taking a break from working outside, eating lunch and really enjoying your update. That's
one nice build you're cooking up.
                                           Kevin
Re: CSM Pfalz Dr.1
« Reply #136 on: August 23, 2020, 07:54:11 AM »
Awesome work, Terri!
Re: CSM Pfalz Dr.1
« Reply #137 on: August 23, 2020, 11:14:18 AM »
Thank you Kevin and Gary . Seems are cleaned up waiting a coat of primer to see how well I actually did on the filling but there is a few things first . Also made on start on getting the engine by getting it cleaned up . More progress to follow  :)
Re: CSM Pfalz Dr.1
« Reply #138 on: August 24, 2020, 05:48:45 AM »
This is shaping up really well Terri. Forward thinking and planning always pays off in my experience, although it is not always possible to avoid filler! However if the parts fit closely that it good enough - filler deals with the remainder!!
Re: CSM Pfalz Dr.1
« Reply #139 on: August 24, 2020, 08:51:20 AM »
Thanks Stephen  :)
I do try to get the best possible fit and that can be challenging at times . The less putty the better  ;)
 Since the forward fuselage is sanded so thing doesn't leave a lot of gluing surface for the cowl which is also thinned . So the front frame work sits 1mm past the resin fuselage . The inner cowl fits this perfectly giving me a second gluing edge for added strength . The cowl is almost ready for primer , still need to thin around the three lower cooling holes . The PE parts for the cowl side excess panels are to big . My PE parts bin might have something more suited if not will be making new ones .
I opened up a air bubble on the under side of the fuselage which was okay I still have some blending at the join line . I knew a head of time that the left side of the fuselage is 1. 3 mm shorter then the right side . It was easier to address this once the halves where finally joined at the hip  ;) A piece of square scraps was super glued in sanded then filled and sanded again . Middle wings have their slots opened up for the inter/struts
Rest of the parts are cleaned up but the Struts still need to be pinned and make the landing gear legs . These aren't included in the kit ( this production run ) . So I need to find something that will be suited for this . The engine is together waiting for the push rods . Which brings me to the end of the weekend progress report  ;)
Re: CSM Pfalz Dr.1
« Reply #140 on: August 24, 2020, 08:51:44 AM »
Re: CSM Pfalz Dr.1
« Reply #141 on: August 24, 2020, 08:52:11 AM »
Re: CSM Pfalz Dr.1
« Reply #142 on: August 24, 2020, 08:52:36 AM »
Re: CSM Pfalz Dr.1
« Reply #143 on: August 24, 2020, 08:53:00 AM »
Re: CSM Pfalz Dr.1
« Reply #144 on: August 24, 2020, 08:53:26 AM »
Offline Old Man
Re: CSM Pfalz Dr.1
« Reply #145 on: August 24, 2020, 10:13:06 AM »
Excellent progress, Ma'am.
Looks like tricky little beastie....
Offline fredjocko
Re: CSM Pfalz Dr.1
« Reply #146 on: August 24, 2020, 09:49:17 PM »
This is moving along nicely. I was not aware that there was more than the Fokker tridecker.
Re: CSM Pfalz Dr.1
« Reply #147 on: August 25, 2020, 01:13:11 AM »
Superb, Terri!
Does the Eduard engine fits below the cowling? That would be good news!
Re: CSM Pfalz Dr.1
« Reply #148 on: August 25, 2020, 02:25:29 AM »
Excellent progress Terri. I am looking forward to the next update!
Re: CSM Pfalz Dr.1
« Reply #149 on: August 25, 2020, 05:28:22 AM »
This is moving along quite quickly now Terri. Good to read that you have been able to fill the holes and hide them with plastic - far better than filler!
