Author Topic: Pfalz DIII / DIIIa 1/48 Group Build After Build  (Read 48403 times)
Re: Pfalz DIII / DIIIa 1/48 Group Build After Build
« Reply #60 on: December 02, 2019, 03:10:49 AM »
Hallo dear forum mates, I finally succeeded in getting back to the workbench for some hour, I completed the two cockpits and here are some pictures.
I ask the forum mods to move this thread to the "Under construction" section.
Thanks
BLUE MAX kit, For this kit everything was scratch built but the control stick...
here is the port half, I had to cut a bit the horizontal elements otherwise the seat woul have not fitted
Starboard half
EDUARD Kit. On this kit I was able to use some parts provided into the box.
Port half
Starboard half
The EDUARD fuselage is now closed, I am going to close the BLUE MAX one.
Thanks for watching!
Antonio
Offline Radarman
« Reply #61 on: December 02, 2019, 04:13:41 AM »
Antonio,
It's good to see you back up and posting your build.
I look forward to watching tis one.
                                                  Kevin
« Reply #62 on: December 02, 2019, 04:31:18 AM »
Antonio,
                                                  Kevin
Thanks Kevin, it's nice to be back!
« Reply #63 on: December 02, 2019, 11:28:36 AM »
Great to see you back  :) Nice up-date on your builds , both are coming along really well and I like the detail  8)
« Reply #64 on: December 02, 2019, 01:58:23 PM »
Antonio, nice to see this one still progressing. I'll ask Dave to move it to Under Construction on his return from holiday, I don't have that function available.
« Reply #65 on: December 02, 2019, 04:00:06 PM »
Thanks Terri and Lance, your comments are really appreciated!
Thanks Lance for taking care of this
Antonio
« Reply #66 on: December 02, 2019, 04:17:01 PM »
Nice to see you back. Relax and enjoy your build.
Bye,
« Reply #67 on: December 03, 2019, 06:42:47 AM »
Great to see you back on this one! Looking good!!
« Reply #68 on: December 03, 2019, 06:09:21 PM »
I'm also still off my bench, it's life... Glad to see you back to your build, adding new details.
« Reply #69 on: December 03, 2019, 07:13:09 PM »
Manni, Rick, Giuseppe... thanks for your warm and appreciated greetings!
Antonio
« Reply #70 on: December 06, 2019, 04:54:06 AM »
Only just found this too Andonio. Good to see that it is back in progress again - let's hope that this time you can finish it!
« Reply #71 on: December 08, 2019, 02:15:02 AM »
Thank you Stephen, I have closed both the fuselages, I am working now on the lower wings of the Blue Max.
This is the lower left wing as found in the box
A detail oft the surface:
Here is the lower right wing as I started smoothing it:
Here is the lower surfaces of both the lower wings:
Moreover, here they are compared with the Pfalz D IIIa at war vol.1 schemas (I hope I am not infringing any copyright)
The wings ave a wrong profile at their tips and I am shaping it better, but they also appear to be larger but I won't dare filing that excess...
Thanks for watching.
Antonio
« Last Edit: December 08, 2019, 03:21:35 AM by andonio64 »
« Reply #72 on: December 09, 2019, 12:29:36 AM »
You are doing an excellent job reshaping and smoothing out the wings. Looking forward to the next update.
« Reply #73 on: December 12, 2019, 12:38:38 PM »
The Blumax kit is not an easy one , but you are doing a wonderful job on her . Looking forward on seeing the next stage of your progress . I almost feel like pulling  Pfalz out of the stash  :-X
« Reply #74 on: December 15, 2019, 08:41:36 PM »
Thanks Terri!
Here are the lower wings of the Blue Max (DIIIa) slightly improved on the shape:
Here are the finished wings: I smoothed the surface and used some plasticard strips (Thickness 0.25 mm, width 1 mm on bottom surfaces and 0.75 mm on top).
The white details are scratch built by me.
The center section in the BM kit is separated from the wings and I will use pins to get them together, the Eduard kit is better having cast the bottom wings in a unique piece.
Have a relaxing sunday
Antonio
« Last Edit: December 16, 2019, 12:40:07 AM by andonio64 »
