Author Topic: Nieuport 17, late version, Copper State Models 1:32  (Read 26734 times)
Re: Nieuport 17, late version, Copper State Models 1:32
« Reply #15 on: January 17, 2019, 11:51:24 PM »
Nice work! Looking forward to more updates.
« Reply #16 on: January 18, 2019, 08:28:27 AM »
Thank you very much, guys, for your encouraging words! They mean a lot for me.
Lance, I used a Tamiya paint for the blue, it’s XF-18 I think (I can only read a half of the „8“ because I once smeared some of the paint over the label when I splashed around with my paints...  :-\
I finished the interior besides some last touch ups with a thin brush here and there. After gluing the rear fuselage together, which consists of six parts that fit like a dream, this rear part is glued onto the back of the interior structure which is quite a unique parts breakdown for a fuselage. But it went together without any problems. Also the forward decking is no problem to try fit in neither had been the fit of the interior structure on the single lower wing part. here I had used a piece of Uschi van der Rostens wood grain decal for the floor. But the fit of the side panels is a little bit tricky and I spent some time to scratch down its thickness and also to reduce the upper main bars of the interior structure. i hope it fits also with glue after spraying the inside of these panels in a light ocre shade for the wood grain. Well, it starts to look like a Nieuport...
Best regards
« Last Edit: January 26, 2019, 11:21:58 PM by Borsos »
« Reply #17 on: January 18, 2019, 09:31:09 AM »
   Thanks for the reply on the paint Andreas. It has to be XF-18 Medium Blue, I have some and it looks like a match. Great finish on the cockpit, looking very nice indeed!
« Reply #18 on: January 19, 2019, 05:10:00 AM »
Asalways I am blown away by the quality of the finish and detail that you manage on your models. This is no exception.
« Reply #19 on: January 19, 2019, 09:20:50 AM »
Beautifully done Andreas I am Blown away like others!! I closed mine up so I wouldn't have to compare  :o
« Reply #20 on: January 21, 2019, 05:06:33 AM »
I'm following this build very carefully, Andreas - some beautiful work! I really appreciate the detailed explanations - I learn a lot! Regards, Marc
« Reply #21 on: January 24, 2019, 02:41:10 AM »
Andreas, if you can paint wood, like the seat and the headrest on this picture :o you don't need to work with real wood.
I'm deeply impressed, really!
Offline xmald
« Reply #22 on: January 24, 2019, 03:11:44 AM »
Great work! I really love the woodgrain - extremely realistic. Keep up the good work.
Best regards
Filip
Offline xan
« Reply #23 on: January 25, 2019, 07:24:15 AM »
One month and I didn't saw your mount!!!
you are doing a winderfull job!
congretulations!
Herbelin 's marking are outstanding!
Xan
« Reply #24 on: January 25, 2019, 09:26:33 AM »
Simply gorgeous Andreas. I see much that I can and will do better on my next Nieuport 17!
« Reply #25 on: January 25, 2019, 04:28:47 PM »
The completed interior looks great, and a good reference when building this excellent kit.
« Reply #26 on: January 26, 2019, 06:49:44 AM »
Lance, Stephen, Rick, Marc, Frank, xmald, Xan and Giuseppe, thank you very much for your kind words!
I painted the interior of the side panels and the forward fuselage cover. On the edges I had to remove some material to make the panels fit the fuselage frame:
Meanwhile I closed the fuselage. I used Vallejo putty for the first time to close some minor seams and it works really fine with a watered fingertip.
I also glued together some subassemblies. I dryfitted the fuselage and the engine cover. The fit is very good.
Best regards
« Last Edit: January 29, 2019, 07:44:00 AM by Borsos »
« Reply #27 on: January 26, 2019, 07:19:56 AM »
I completely agree with Frank: your wood pinting is so good it really does look like the real thing. This model is coming together very quickly but there is no loss of quality as a resuly. Simply marvellous.
« Reply #28 on: January 26, 2019, 08:18:29 AM »
Andreas, your talent + this great kit = a beautiful result.  Looks fantastic.
« Reply #29 on: January 26, 2019, 10:25:35 AM »
Beautiful work. As others have said the wood finish is excellent!!
