Author Topic: SPAD XIII C.1 in 1:32 scale  (Read 36132 times)
Re: SPAD XIII C.1 in 1:32 scale
« Reply #45 on: April 18, 2018, 06:21:04 PM »
Nice!  Thanks for the 'strutter' talk.  Very useful.
« Reply #46 on: April 18, 2018, 09:58:43 PM »
Thanks for the detailed information on the "Strutter", Mike. I've been considering this tool for years and, after seeing your work here, ordered one last night. Not  a small price however I think it will get good use!
« Reply #47 on: April 19, 2018, 02:34:48 AM »
Hi Lance,
Your welcome.
Yes not cheap and especially shipping to Canada (weight cost), but I think you will get a lot of use out of it.
Originally I bought the Strutter for when I build my larger WNW kits (Felixstowe, Gotha etc) - for constucting undercarriages and wing struts etc.
That said I've only used it on my Fokker EV and the Spad so far, but the combination of brass tube and rod plus either soft solder or CA adhesive (VMS - Flexy 5 CA) makes for a much stronger structural strength.
You might have noticed on their site, if you get onto it, that they also sell pre-cut micro-tube for either 1:32 or 1:48 scale turnbuckles - not a bad price if you don't want to cut them yourself.
Mike.
« Reply #48 on: April 19, 2018, 03:03:39 AM »
At first I want to express my compliments for building the old Hobbycraft SPAD in such a great manner. I especially love the work on the struts.
Secondly I also can only recommend the Strutter. I frequently use it not just for squeezing brass tube but also for squeezing veneer for carving wooden props.
Borsos
« Reply #49 on: April 19, 2018, 03:39:08 AM »
Borsos
Borsos,
     Brilliant, I hadn't thought of that however since I laminate and carve most of my own props it will get a lot of use there as well, Thanks!
« Reply #50 on: April 20, 2018, 04:09:23 AM »
Spectacular work, Mike!
Offline aliluke
« Reply #51 on: April 20, 2018, 07:49:07 PM »
Amazing Mike!
This is in the category of serious modelling that is beyond my skills but which I admire and aspire too.
Thanks for sharing,
Alistair
« Reply #52 on: April 26, 2018, 07:05:16 AM »
I've completed the basic engine for the Spad XIII.  It's a Wingnut Wings Hispano-Suiza engine for their SE5a, which I've heavily modified to represent the Hispano-Suiza fitted to the Spad XIII.
Modifications carried out:
Forward engine support beams.
Air intake for the carburettor manifold.
Coolant filler and return pipe assembly.
Coolant return pipes from manifold and both cylinder blocks.
Manifold fuel intake primer valves.
Ignition leads.
Ignition lead support tubes.
Ignition lead connections to both magnetos.
Coolant temperatures sensor.
Forward external gear oil supply pipes.
Forward camshaft external oil supply pipes.
Air breather valve and pipe.
The following will be fitted on engine installation into the fuselage:
Carburettor control linkage.Coolant temperatures sensor.
Fuel pipe connection to carburettor.
Coolant supply connection to filler and return assembly.
Now it's on to the cockpit detailing!!
« Reply #53 on: April 26, 2018, 07:17:05 AM »
Great engine!
« Reply #54 on: April 26, 2018, 07:53:37 AM »
Excellent!
« Reply #55 on: April 26, 2018, 08:04:44 AM »
 Mike,
Outstanding work on her Hisso my friend. I can appreciate the work to took to modify the WNW  Hispano-Suiza for the SPAD XIII. It would have been much easier task for a SPAN XII (37 mm Canon Armed). Of course it would much more work on the fuselage though. Keep up the excellence and keep those updates coming.
Offline Syd Solo
« Reply #56 on: April 27, 2018, 12:23:36 AM »
This is a brilliant build.
Syd
« Reply #57 on: April 28, 2018, 10:30:15 AM »
Nice!
« Reply #58 on: May 01, 2018, 10:44:58 PM »
Excellent work!!
« Reply #59 on: May 01, 2018, 11:31:08 PM »
Moving onto the cockpit detailing now.
The kit lacks certain pipes so again, these were made from various sized micro-tubes and soft soldered where required.
The shot below shows these pipes dry fitted and prior to painting.
