Author Topic: SPAD XIII C.1 in 1:32 scale  (Read 35670 times)
Re: SPAD XIII C.1 in 1:32 scale
« Reply #75 on: May 17, 2018, 04:10:21 AM »
Yeah it was.
I've over sprayed to 'knock' it back.
So now on goes the clay wash for weathering.
« Reply #76 on: May 17, 2018, 07:54:26 AM »
Outstanding job on the masking. your in progress photos are interesting. I am on the edge of my seat to see the next phase of your painting processes!
« Reply #77 on: May 17, 2018, 12:39:40 PM »
 Mike,
Outstanding progress my friend.
« Reply #78 on: May 17, 2018, 04:48:07 PM »
Looking forward to seeing how that underside comes out.  I think with these canvas birds, highlighting the structure is very important.
Gaz
« Reply #79 on: May 17, 2018, 06:28:39 PM »
Photographs of Frank Luke Jnr's Spad ‘26’ of the 27th Aero Squadron show evidence of surface dirt and paint chipped surfaces and it looking to be in a fairly ‘war weary’ condition. Therefore I decided to create this ‘dirty’ effect with the weathering on the CDL surfaces. As usual I used a fine 'grime' clay wash from 'Flory Models' to create the effect. The clay wash is very simple to use and you can add or remove as much as you like using a dry or a damp brush, then seal it all with a top coat of appropriate sealer.
« Reply #80 on: May 17, 2018, 08:24:46 PM »
Excellent results! War weary indeed.
« Reply #81 on: May 17, 2018, 11:01:15 PM »
Very realistic. The best build of this kit I have ever seen!
Borsos
« Reply #82 on: May 22, 2018, 04:19:15 AM »
The underside is finished now so it's onto the topside camouflage colour scheme now.
« Reply #83 on: May 22, 2018, 03:45:11 PM »
Great work, Mike. The shading looks really great. Looking forward to your next steps.
Bye, Manni
« Reply #84 on: May 24, 2018, 08:15:04 AM »
Thanks.
The three figures are done now.
« Reply #85 on: May 24, 2018, 08:30:02 AM »
Nicely done figures
« Reply #86 on: May 24, 2018, 07:18:08 PM »
This will all look very good when it comes together. I like your use of the Flory wash. I tried these for the first time on a 1/35 Mark V Female and was very impressed with the effects that are obtainable. You've used it to great effect on this build.
« Reply #87 on: May 25, 2018, 05:11:27 AM »
This build is just awesome. Can anybody explain me what’s the special thing with these “Flory” washes?
Thanks
Borsos
« Reply #88 on: May 25, 2018, 05:24:23 AM »
Hi Boros,
Some years ago Phil Flory of 'Flory Models' developed a range of washes which are extremely fine clay pigments in fluid.
These washes come in various shades and consist of a very fine clay pigment.  They are brushed over the surface to be weathered and dry in around 30 minutes.  When dry, use either a piece of good, absorbent kitchen roll or a brush used for oil paint (as the bristles are harder than normal painting brushes) to remove as much of the clay wash as you need to achieve the desired effect.  Once dampened, the dried clay is re-activated and the clay wash can be removed or worked as required.
First I seal the surface with airbrushed Alclad Klear Light Sheen (ALC-311), which dries quickly. A gloss coat tends to stop the clay wash ‘gripping’ the surface when it is  applied and it can run off or just puddle.  A matte coat can cause the clay wash to ‘grip’ too much, making it very difficult to remove or even to wash it off completely.
To apply the clay wash is just a matter of brushing all over the surface to be weathered.  It doesn’t matter really how much is applied and it can be left on for any period of time, as it is
easily removed without any effect on the surface underneath. The washes I tend to use are Flory Clay Wash ’Grime’ and ’Dark Dirt’ .
I use an oil brush to brush off the clay wash, but for smearing effects, an only very slightly damp brush or absorbent paper can be used, but even then I dab them onto a dry piece of the paper.  That’s how ‘damp’ it needs to be.  Any wetter and you’ll find that you are removing too much of the clay wash.  If that happens you would have to re-apply the wash and start again.
That said, if you not happy with the final effect, you can easily remove the clay wash by brushing with a wet brush or even airbrush water over the surface.  Dry off the surfaces washed and then re-apply the clay wash and try again until you are satisfied.
The technique is to brush over the surface to re-activate the clay wash and at the same time, to smear it over areas that had no clay wash.  It’ll dry more or less straight away.
Then I’ll very lightly stiff brush and/or use a piece of damp absorbent paper or brush to remove as much as I want until I get the desired effect.  If I remove too much I just reapply clay wash to that area and repeat the removal procedure.
Once finished, just run the brush under a tap to rinse out any residual clay pigments.
Finally I seal the surface with airbrushed Alclad Klear Light Sheen (ALC-311), which will seal in the applied clay wash.
NOTE: Flory washes can be mixed to create other colour blends.
Flory Home page (washes etc are in the P & M link)
http://www.florymodels.co.uk/
« Reply #89 on: May 25, 2018, 05:57:17 AM »
Thanks for the info and link. Very interesting and something I will try
