Author Topic: The Gotha  (Read 66895 times)
Offline krow113
Re: The Gotha
« Reply #90 on: May 26, 2018, 03:08:18 AM »
Manni , RIII - Thank you.
 Back to the wing some black and Paynes grey wash' were ran into the edges and tops respectively:
Re: The Gotha
« Reply #91 on: May 26, 2018, 06:18:29 AM »
Great updates, I like all the paint job.
Offline krow113
Re: The Gotha
« Reply #92 on: May 28, 2018, 11:58:15 AM »
Thank you Giuseppe...
The struggle is real!
 The Taurus engine set is testing my skills and patience . Crusty blobs of unworkable cyano are not what I need on my model. Nothing seems to stick to the flexible resin supplied. There are no where near enough parts included in the kit. As parts are removed the attrition rate is pretty much 50% .Some of the rocker arms broke as soon as I touched them with the razor saw! I removed all of the stands and removed the caked on cyano , most of it falling off , and glued them all again with a pva glue.
See page three for the ongoing saga.....
Re: The Gotha
« Reply #93 on: May 28, 2018, 09:29:22 PM »
I feel your pain with the engines. On the plus side those worn areas look more awesome with each update!
Re: The Gotha
« Reply #94 on: May 29, 2018, 06:50:46 PM »
The painting looks very nice indeed.  Sorry to hear about the engines.  I have a love/hate relationship with CA.
Offline krow113
Re: The Gotha
« Reply #95 on: May 31, 2018, 02:09:42 AM »
Thanks you guys!
I'm contemplating replacing the valve springs at the moment. I'll have a look at the parts I have but I don't think they will make the cut. Adhesion problems have been sorted with the use of Weldbond PVA glue. Attaching with full-strength and then wicking in thinned down glue  until I was satisfied worked well:
All the parts shown are very well attached and show very little if any glue marks.
Again page three has the whole story to date.
Re: The Gotha
« Reply #96 on: May 31, 2018, 06:27:42 PM »
Looks fab!
I might have to reconsider using PVA for certain things.  I seem to have trouble getting CA to do what I want it to very, very often.
GAz
Re: The Gotha
« Reply #97 on: May 31, 2018, 09:14:16 PM »
I am glad to see you have your Resin Engine issues sorted out. Really looking forward to the next updates on this beauty!
Offline krow113
Re: The Gotha
« Reply #98 on: June 01, 2018, 02:21:32 AM »
Thanks Gaz!
 I recommend the Weldbond shown , or Formula 560 a purpose produced PVA for canopies.
RIII Thank you.
The resin engine bits job is only a third done , camshaft in place. Springs next , then the rocker arms.
Solving the attachment issue was a great step forward. The PVA sucks into the parts , rather than occluding and crusting up into a mess of pustulous caked on cyano. , that wont hold diddeley in place.
My little island is beginning to get the summers visitors so work here will become sporadic again , bear with me...
« Last Edit: June 01, 2018, 02:32:11 AM by krow113 »
Offline krow113
Re: The Gotha
« Reply #99 on: June 04, 2018, 02:01:09 PM »
 ** CONTINUATION OF  THE TAURUS PROCEDURES FROM PAGE 3 **
 Springs.
 The springs are in two lengths , these must be matched for height. After removal start matching up sets of springs. I cut off the post and tried to be accurate. when I sorted the springs I tried to match set lengths. I can see that there will be gnashing of the teeth:
You can see the length diff in the two pairs at the bottom.
 My little paper valve angle template was applied and the engine clamped to have it vertically oriented:
 Now for a final set matching...
 And right out of the gate things dont line up:
The springs look good on their landings , but the centerline of the rocker arm space is out, the 'T' shows the amount. The price for mounting the camshaft backwards and concentrating too much on the 'T's.
Prolly cant see it in the pics , but I held some thin flat bar between the camshaft box's and its easy to see the misalignment. So I'll soak the parts apart and try again.
 So.
 I tore off the camshaft , it peeled off without breaking or losing any of the 'T's . I take that as a signal that things are turning around.
 The camshaft was turned end for end and the holes for the longer 'T's were drilled deeper , the whole assy went on properly without any fuss, a little adjusting to make sure everything was in line and a strip of paper folded in half was used to check the alignment and centering of the rocker arms to the respective ports:
A final wicking in of the 50/50 water /Weldbond PVA and you can see the web around the bottom of the 'T's that will capillary in and secure the parts finally:
 I think with patience , parts prep , proper adhesive choice , some rudimentary templates and an understanding of the layout of the parts is what is required for this set. I'll get set up for the springs again and see if I can get a row on.
Template on:
 A row of springs was applied. The template allowed an end view to be realized , with the top of the 15degree angle line visible and nice for lining up. After this a strip of business card was put in place:
This put an edge and a space behind the springs for alignmnent, another srtip of card was used ,very carefully to tease the springs into a line:
Keep the card edges parallel and in line with the engine top.
 Th glue was used full strength and allowed alignment to take place , if the capillary action of the glue drying , or shrinking , pulls the springs outta line , we'll see.
 A word on the springs.
Soft , crumbly ,all diff lengths. no matter how careful intitial cutting is, they will need to be matched in pairs. Matching is NOT to be avoided or left out. I couldnt tell which was top or bottom , there is little visual diff between the top and bottom. I chose to use the cast in round plate as the bottom , for a better bond . I lost a compressed spring , I was wary of this with NO SPARES , I did the exhaust side first for this reason. I should be able to fabricate a replacement spring , when it flew off I was very close to just making my own springs but decided to forge ahead with the set.
 Last pic of the work today:
Maybe not.
POed at losing the spring , a sheet of transfer tape was used to grab anything that was on the floor , found the spring.
And re-visiting the alignment issue a couple of strips of business card were used to great effect .One inserted and angled to suit the template at the front and another was used to help align the angle:
I felt slightly better after this.
I'll take it.
The springs are matched and all in a line:
Part 3 The Rocker Arms next.
 And my word as good as gold , here is a rocker arm placed to check the fit and whether the springs are in the right place. I stated that the job had turned around , or went in a better direction , when I unbackwardized the camshaft and that statement is ringing true as the rocker looks perfect to me , nice and straight and nicely on top of the springs:
 A word about the rocker arms , branch rockers they are called because of the 2 spring contact points .
They are  the most fragile parts of the set - the part that sits between the boxes will break off with little pressure .If you drop one DO NOT attempt to pick it up by hand , I broke a few that way before cluing in . Tweezer handling only , cleanup is a chore ,even more than usual , I cannot emphasize enough the careful handling these parts need.
And finally a side of valve train has been completed. To the end the struggle was real , the rocker arm that goes between the camshaft boxes were too wide. Any manipulation of the arm results in breaking it off. I recommend checking this and opening up the space between the camshaft housings to allow the arm to drop in. Then a drop of 50/50 water /pva to start in between the boxes and that should hold it while you manipulate the springs and the contact points to line up. The springs still have some movement , and allow a small amount of adjustment. They look good when its all straight and in line:
And I'll leave it at that.
 To show timeline and the amount of time needed for these operations , I just did alla the intake springs in 40 minutes:
The fun never stops. Rocker arms come 8 on a sprue. I started with a full sprue. Only ONE rocker made it with the arm attached. There are multiple ways to break the part and attrition in the learning curve is horrendous. Heres the last side of valve train, I glued the broken rocker part on the tops of the springs , hopefully I can get the broken off arms in place after the glue sets for a while:
 So I did wait and the glue is fantastic -  holding the parts and allowing movement and alignment. I think this is the key to getting this set done. So here it is , I fitted the broken off arms as best as I could , aligned the springs a few times and got them all lined up nice. The rocker arms as well lined up as this is the only way this set will look good , everything has to be in line:
 I have also gone in wicking the 50/50 mix into alla the little contact points , this glue is perfect , it sucks into the joints pulling them together , just perfect. So procedure for gluing was use a small amount of full strength glue to contacy and hold , wait a few minutes to allow adhesion , then manipulate the parts according to visual cues and the templates and alignment guides, a good press on the parts to set them and then after 10 minutes or so start to wick in the thinned mixture to get the final bond.
So using simple visual templates and some simple strips of business card to space and align the springs ,and glue that will allow some movement is key as well ,  things just got way better for the use of this set. I hope someone wants to give this a shot , as peer validation is the best proof of worth , let me know.
  ** TAURUS PROCEDURES CONCLUDED , HAVE A NICE DAY **
« Last Edit: June 25, 2018, 01:41:58 PM by krow113 »
Offline krow113
Re: The Gotha
« Reply #100 on: June 18, 2018, 02:17:23 AM »
  While the glue dries.
 A list of additions to the engine quickly ran up to 30 plus . Many of these are lines , wires etc. I like to pin the lines , so drilling for a pin starts with a tiny pin prick then starting with a .2 mm drill and working up to a .5 in some case'. Holes are cleared and dressed with a quickly spinning , lightly applied .9 mm drill. All operations by finger tip. Drills from DU on this forum.
 Here are the parts drilled for pinning the hot water feed to the carb and the return to the pump:
...and the HV wire tube ends:
 Leaving the parts on the sprue has its advantages while work is completed. Sprue can be sectioned away for access too.
Re: The Gotha
« Reply #101 on: June 18, 2018, 03:06:58 AM »
Your trials with the engine seem to be a real PITA! It looks as though you have things in hand now! Looking forward to the end result.
Offline krow113
Re: The Gotha
« Reply #102 on: June 18, 2018, 04:27:15 AM »
RIII -Thank you.
 With a little time on my hands and curious as to whether the part would take the perforation , I went on with the HV wire tubes. And they will take the abuse!
 The same procedure was used for the drilling. The part did fracture but applications of plastic cement joined and smoothed the part. Do all of the seam work , thin out the brackets before drilling and handling the part post perforation wont be nessecary. Five holes in the top tube and six in the bottom , and the ends drilled out , smoothing and scraping all told took just over an hour working steadily.
 Nice to be able to use the kit parts;
Re: The Gotha
« Reply #103 on: June 18, 2018, 05:17:49 AM »
Steve,
    I found the same however I used "Mono" for the wires and found it too stiff and uncontrollable so had to step back and scratch the tubes from brass tube. Thinking back I think I'll use Modelkasten in future, what are you planning to use?
Offline krow113
Re: The Gotha
« Reply #104 on: June 18, 2018, 05:45:57 AM »
 Thank you Lance.
 I remember asking about the wires you mention.
I'll most likely scour this forum and steal someone else's method !
  Most of the wires I have referenced through phorto's only look  to be a simple wire with a thin insulate. Some pics suggest a texture , like some one manually wrapped the wire with linen or some other organic material  ,as plastic was not in existance yet.
 HV requires a heavy guage stranded wire I just measured some at 1.75 mm at 1/32 scale thats .055 mm . The plug end looks like a simple ring terminal.
 So I thought a single strand of copper wire with a loop in the plug end and some thick primer brushed on the show the insulate,
 A nice easy one and with all of the work to come I'll prolly take it.
