Author Topic: The Gotha  (Read 66747 times)
Offline krow113
The Gotha
« on: February 11, 2018, 03:28:55 AM »
Returning here with the Gotha GIV kit from WNW.
               **PLEASE BE AWARE OF THE PHILOSOPHY OF THE WORK AS DETAILED IN LINK BELOW**
                           http://www.britmodeller.com/forums/index.php?/topic/235016614-a-gotha/
Here is pretty much everything , there are a lot more figs now:
 Not too much actual assy as I have been working through camo masks and paint masks fr the kit , some shots starting with paint masks:
Camo masks:
 Today I figured outt that the doghouse can be removeable for detail inspection , by cutting almost through the small gun ring part attached to it , gluing the ring piece  in place and then cutting the rest of the doghouse off.
Clamped:
[url=https://ibb.co/nEciBS]
Set:
Cut off:
Still fits:
Made a slurry and filled it:
 As our illustriuous leader said; " Its your model , build it the way you want"
Thanks Des.
« Last Edit: November 13, 2018, 11:27:42 AM by krow113 »
Re: The Gotha
« Reply #1 on: February 11, 2018, 05:18:31 AM »
Terrific work on the masks! Your Gotha is looking spectacular.
Re: The Gotha
« Reply #2 on: February 11, 2018, 05:23:39 AM »
Looking great, glad you are back on this one.  Looking forward to your progress.
Offline krow113
Re: The Gotha
« Reply #3 on: February 12, 2018, 04:57:08 PM »
Thanks Rick and Jaun.
 Slurry sanded:
 Fuselage sanded and ready for primer:
Smallest amount of filler required at the end of the gun tunnel:
  I made the decision to remove the 4 rib tape details from the lower wing center section. This is based on a number of pics that show there was no fabric on the section , being made of plywood like the fuselage.
« Last Edit: March 05, 2018, 07:20:06 PM by krow113 »
Offline Ssasho0
    • Scale Models Club Bulgaria
Re: The Gotha
« Reply #4 on: February 12, 2018, 07:54:20 PM »
Hi Steve,
It looks great so far and I really like the detachable "Dog house" idea. The instrumental pane looks awesome, the wood too and this will turn out great I have no doubt!
I have just started the same kit and as you are ahead of myself I will be keeping an eye here :)
Best regards,
Sasho
Think globally, act locally!
Offline krow113
Re: The Gotha
« Reply #5 on: February 13, 2018, 03:22:03 AM »
Thanks Ssashoo.
 If you look in your instructions for this kit you can see a rendered cockpit by a modeller for WNW , that was the look I was trying for with the wood color.
Re: The Gotha
« Reply #6 on: February 13, 2018, 04:52:37 AM »
Superb work on the interior, Steve!  This one's destined for greatness!
Offline krow113
Re: The Gotha
« Reply #7 on: February 13, 2018, 06:57:35 AM »
Thanks Bud!
 Interior work continues with detailing the gun ring.. The 2 cm Becker would require some reinforcing of the ring. I made a measuring strip and clamped it on:
Then cut the details from hi-po flat black vinyl , 2 strips that cover the seams and look ok ;
 The mount and reinforcement is from pics of other planes with this sort of armament.
Detailing continues with a bombsite cover , and mg mount finishing:
« Last Edit: February 13, 2018, 01:11:05 PM by krow113 »
Re: The Gotha
« Reply #8 on: February 13, 2018, 04:16:09 PM »
Wow, Steve! Really outstanding work. All these additional details, this is right now a stunner.
Bye,
Offline KitRookie37
Re: The Gotha
« Reply #9 on: February 13, 2018, 04:42:35 PM »
Hi mates,
Very, very good job !! I like it !  :)
Best regards.
Alain.
Use the force, Luke.
Re: The Gotha
« Reply #10 on: February 14, 2018, 01:34:42 AM »
Brilliant work!
Offline krow113
Re: The Gotha
« Reply #11 on: February 14, 2018, 07:14:00 AM »
Manni , Rick , Alain ; Thank you.
 Details continue as maskwork and sanding sucks.
So I went ahead and began fabricating a Becker mount , just an amalgum of mounts I've looked at over the last little while:
Offline UFAG
Re: The Gotha
« Reply #12 on: February 14, 2018, 08:05:37 AM »
chapeau..!! very delicate detail..!
Offline krow113
Re: The Gotha
« Reply #13 on: February 16, 2018, 05:14:30 AM »
Thanks UFAG.
Becker mount continuation:
Re: The Gotha
« Reply #14 on: February 17, 2018, 11:40:06 AM »
Continuing to be awesome work.
