Author Topic: 1/72 Zeppelin-Lindau (Dornier) Rs II  (Read 43665 times)
Offline RLWP
  • Bodger
Re: 1/72 Zeppelin-Lindau (Dornier) Rs II
« Reply #75 on: November 19, 2017, 09:37:46 AM »
Looking really, really good
Not necessarily aeroplane shaped yet, still good
« Reply #76 on: November 19, 2017, 11:09:07 AM »
Very nice! A little colour always starts to bring things to life. I need to try metal primer, I'm tired of having the paint come off while trying to fit brass rod.
« Reply #77 on: November 20, 2017, 04:25:13 AM »
Ian, If you do use primer be careful because it can be very thick, but if you add too much thinner it does not work either! On the booms the thicker paint matters less than it would have done on very thin metal.
« Reply #78 on: November 20, 2017, 05:04:40 AM »
A great scratchbuilding tutorial. Thank you for sharing.
Giuseppe.
« Reply #79 on: November 20, 2017, 09:17:25 AM »
Absolutely beautiful work! The crosses came out beautifully!
« Reply #80 on: November 20, 2017, 04:42:48 PM »
Wow, the seaplane looks just great! Now with paint on it it looks mindblowing, so retro and so futuristic at the same time.
« Reply #81 on: November 21, 2017, 04:54:37 AM »
What a beast she is - but a pretty one. Very nice scratchbuild!
Borsos
« Reply #82 on: November 21, 2017, 04:59:16 AM »
She is taking shape beautifully Stephen, you are doing a superb job.
Offline Whiteknuckles
« Reply #83 on: November 21, 2017, 09:35:51 AM »
What a wonderful piece of modelling Stephen, or should I say art!! :)
Very inspiring!!
Eternal Apprentice
« Reply #84 on: November 24, 2017, 05:12:45 AM »
Evening All,
My thanks to Guiseppe, Rick, Manni, Andreas, Des and Andrew for your very kind and positive comments - I really appreciate them all and am pleased that this build is of such interest to so many.
I have rigged the lower part of the tail boom together with the vertical sections as shown in the photos. Experience has taught me that rigging parts of a model like this is strongly advised as they become much less accessible later when there are large parts such as wings etc to catch on when one is trying to get the tweezers and wire into tiny spaces. I use rolled 40 SWG copper wire: I measure the length needed directly from the model using a pair of dividers. l then cut a piece of wire which is slightly longer than needed and roll it flat with a piece of brass strip on a hardwood base. The wire is offered to the space where it is supposed to fit and by the use of Mk 1 eyeball I estimate how much needs to be trimmed. A second, and if necessary third, attempt is made until the wire is the correct length. A tiny blob of CA is added to the model at both ends where the wire is to be attached and the wire carefully placed in position. The CA usually grabs the wire and holds it firm. Sometimes I will put one end on and then use tweezers or a knife blade to gently ease the other end of the wire into place if it is difficult to get to. By using wire I do not have to drill and fill lots of holes, and in the case of this boom structure which is made from brass, I do not have to drill into metal which would be extremely difficult and time consuming. The results look like this:
Whilst I was in rigging mode I decided to complete the elevator so that I could store it where it cannot be damaged. This will be one of the very last parts to be added to the model so I need to keep it safe in the meantime.
Just a reminder of size and how much rigging there is on this aeroplane, here again is the Avro biplane with the rigged and painted elevator: remember this will be at the very rear of the flying boat and is a relatively small part of it!
I have been thinking hard about how I am going to attach the large V struts under the wings to the hull sides. On the original aircraft they came to a common joint and were attached to the hull side and probably to a large piece of frame inside the hull. I do not think that it will be practical to make the ends of 4 pieces of plastic come together and simultaneously be able to fix them to the hull sides, so I have decided to make two small attachment pieces from 60 thou card, drill holes in them and the hull and attach them with wire and CA. However I needed to make the attachment pieces the correct size: the struts will be made from 120 thou x 30 thou Evergreen strip shaped to aerofiol section, (the original struts were huge as the photos show). So I cut two small pieces of strip and made a tapered joint so that they would come together with a combined width of 60 thou. I could then cut the attachment pieces to fit exactly the strut ends:
The hull attachment parts have an angled face which will be glued to the hull side and be reinforced with a piece of wire which I took from a piece of telephone cable. The opposite side will then be angled upwards so that the ends of the struts will fit directly on to it and will form a butt joint. The wing is completely rigid so the V struts should not be carrying any weight. The completed attachment lugs look like this:
These have been CA'd to the hull.
I have also done some work on the engine nacelles: by the use of a file and glass paper I have shaped them to match the drawings and then I drilled out two slots, one at each end on the top, into which I am going to insert some short pieces of 60 thou rod to represent the cylinder ends. I have called this a retro model for good reasons: I am not intending to add a huge amount of cockpit and engine detail only to cover it all up - this model will resemble some of the early Frog and Airfix models from the 1950's where there were no wheel wells, cockpit openings, or other recesses! I have also resorted to talcum powder and dope as a filler - another 1960's, pre-resin aftermarket solution to a modelling problem! The engine tops will have some detail which will hopefully disguise to all but the most serious onlooker the small liberties that I am taking with this model. The rear engines will be nearly hidden under the wing anyway and all will have radiators mounted above them which will also help to obscure the view!
There is some tidying up to do around the edges of the slots but that will be easy to do and when paint is on they should pass muster. Various holes have been drilled in the sides and front and rear which represent various orifices on the originals, but I have no idea why they were there, they are just clearly visible in the photos
Thanks for looking.
Offline RLWP
  • Bodger
« Reply #85 on: November 24, 2017, 05:39:16 AM »
Are you kidding?! A large and unusual prototype, interesting techniques, well executed and brilliantly and honestly described
Doesn't get much better than this, Stephen
Still doesn't look much like an aeroplane yet...
« Reply #86 on: November 24, 2017, 04:30:22 PM »
Beside all the fine work on rigging and plane I really like the engines - cool!
Offline davec
« Reply #87 on: November 24, 2017, 09:58:33 PM »
amazing rigging!
« Reply #88 on: November 25, 2017, 12:32:13 AM »
Stephen,
    Your solution to attaching the struts to the hull is pure genius, great scratch building skills on your part....... again! The rear boom rigging is beautifully clean and the elevator assembly as well. This is shaping up to be your best work yet, it's a real pleasure to follow your progress! 8) 8) 8)
« Reply #89 on: November 26, 2017, 01:31:07 AM »
Stephen,
I'll second that. Beautiful, clean, work throughout. The only possible problem I can see is where to put it when it's finished!
