Author Topic: Dual Build: Roden 1/32nd Albatros DIII (OAW): Jasta 10, WNW ALbatrosDV: Jasta11  (Read 154092 times)
She's really looking good!  I think the matte helps most around the tail.
Really coming along well!
Gaz
Gaz
Thanks Gaz. The Flat finish was applied in a thin coat more to give a slight difference between the wood areas and the painted areas. It is subtle but I know there is a difference  8)
It is a Biplane Now! Added the upper wing and radiator. Just some touch up then rigging.
« Last Edit: June 17, 2018, 05:28:57 AM by RAGIII »
That looks superb Rick. The wood finish on the fuselage looks better every time I see it. This will be a stunner when it is rigged.
Offline Trackpad
Very nice, Rick: well done! More motivation for my glacially moving build!   8)
Cheers!
Thanks Stephen. I appreciate the comment!
Thanks Gary. I think my build qualifies as a Much More Glacial build than yours  8)
Rick,
   That looks superb!
You're gonna have to tell me just how you plan to get those 4 leads from the fuselage into the upper wing.  Looks like a difficult operation on my D.V.
Gaz
Rick,
   That looks superb!
Gaz
Thanks Gaz! About those leads, I am thinking I may end up doing the same as my first DV...snip off the lines and run sprue from the top. The PE panel is not glued on the upper surface so I can bend it up either to run the lines through as planned or run the sprue down if needed  :-X
That is a great idea!  Kinda makes rigging the inside a bit redundant, though.  Still easier than trying to measure the correct depth and hope that all four will stick up in there the way you want.
Gaz
Absolutely gorgeous, Amigo!  And no banana struts!
Thanks Amigo I appreciate the compliment! Nope, No Banana struts or wing... yet  ::)
Catching up yet again. I love the muted colours with the "just enough" flat coat on. She looks great!!!
Thanks Steve, greatly appreciated!
Looking good !!!
